BOV or Bypass ???
Old August 15th, 2009, 04:19 PM   #1
SilverGT04 is on a distinguished road
BOV or Bypass ???
okay im getitng in the next week my vortech kit.. are these kits reliable and what kind of BOV or Bypass could i get that sounds loud but sounds good 2.?
Old August 15th, 2009, 05:29 PM   #2
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I'm pretty sure a regular vortech kit is a draw through setup so you're going to have to run a bypass setup rather than a blowoff setup. I don't think they really make loud bypass valves. If you switched over to a blow through setup you could run a BOV though.
Vortech kits are very reliable, just ask Jivepepper
I run a procharger though
Old August 15th, 2009, 05:41 PM   #3
how do you do that change i jsut wan the best sounding.. BOV for a mustang i really dont want a bypass cause it sounds like aleaf blower x10
Old August 15th, 2009, 08:25 PM   #4
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
ok people tend to confuse this so i'll clarify.. there is a difference between a bypass valve and a BOV.. you can't use a BOV on a mustang, it will flutter and make the car run like crap. what you need to do is use a bypass valve but you can always route it to the atmosphere like a BOV and it will still sound cool.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old August 15th, 2009, 09:05 PM   #5
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
I learned this the hard way
Vortech V2 Si
Old August 16th, 2009, 01:07 AM   #6
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
if your vortech is a draw thru (with your maf before the blower) then you must run it back into the system, or you're bleeing off metered air. If you're running it as a draw thru (maf between the head unit and throttle body) you can run it to the atmosphere. if you switch from the stock vortech setup (draw thru) you'll have to get a retune.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old August 16th, 2009, 11:53 PM   #7
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Originally Posted by mustanginky View Post
if your vortech is a draw thru (with your maf before the blower) then you must run it back into the system, or you're bleeing off metered air. If you're running it as a BLOW thru (maf between the head unit and throttle body) you can run it to the atmosphere. if you switch from the stock vortech setup (draw thru) you'll have to get a retune.
Fixed. And +1 on the retune
Old August 16th, 2009, 11:58 PM   #8
2000 gt
yes thanks sorry to the OP i miss-typed.
HARDCORE CREW
Old August 17th, 2009, 12:05 AM   #9
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Why can't you use a BOV on a mustang? I'm assuming you meant on a supercharged mustang, cause I don't see why you couldn't run a BOV on a turbo'd stang.
What is the difference between a BOV and a bypass valve? All I've ever read is that basically they are the same thing, except a BOV vents the air off whereas the bypass valve recirculates the air
I'm not sure because Procharger comes as a blow through. I would say you'd just have to get different piping and maybe a new MAF, then vent you're bypass valve off to the atmosphere
Threads Similar to: BOV or Bypass ???
Setting A BOV shadowgames81 SVO 26 January 7th, 2009 07:13 PM
Supercharger Bov sn94 5.0 Mustangs 1 September 9th, 2008 01:03 AM
BOV? carlos 99-04 5 July 22nd, 2008 02:51 PM
BOV? carlos 99-04 8 July 18th, 2008 04:45 PM
BOV vs BYPASS PERFORMANCE bransdaman78 General Tech 10 May 9th, 2007 06:14 PM
