O2 Sensor Problem - Need HELP!!!
Old August 15th, 2009, 10:46 PM   #1
1999 Mustang GT
usmcgrunt is on a distinguished road
Exclamation
I have a 99 GT with a few minor mods and its been running great for about 150,000 miles. The other day the cel comes on and it threw the codes for all four o2 sensors. They all say heater circuit malfunction (codes P0135/P0141/P0155/P0161). I'm having a hard time believing that all 4 sensors went bad at the exact same time. I don"t want to replace the sensors just to find out that the problem is somewhere else. Also, I'm in an emissions state (NC), so the o2 eliminators wont do me any good. Anyone have any ideas on what I should do from here? By the way, I haven't made any mods in a long time to the car and its been running strong until they other day. Its actually running stronger now, but my gas mileage has dropped drastically!!! Gotta love a rich running engine!! Thanks in advance for any help you can give me.
Old August 15th, 2009, 10:52 PM   #2
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
you could get a DMM (Digital Multi Meter and test the resistance in your harness and in your plugs.
Does it have longtubes? If so those circuit codes can appear since the o2 sensor is further down on the header(manifold).
If you have a tuner (Diablo/SCT/Etc) your tuner should be able to clear those codes out since my buddy had them after v6 Long Tube install and Justin @ VMP Cleared some of them.
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Old August 15th, 2009, 11:00 PM   #3
1999 Mustang GT
I forgot one of the most important things when dealing with this... my exhaust is factory from the motor to the cats. I'm wondering if there is some sort of relay other electrical crap that could cause all four heaters to go out at the same time. I love my current Pony, but I miss my old '65 289 4v!!!
Old September 21st, 2009, 10:45 AM   #4
Look Ma! My First Post!
ccaberle is on a distinguished road
Check your fuses. I believe it is F2.8 20 amp. I had the same problem.
Old September 21st, 2009, 03:03 PM   #5
Trick Tuners's Avatar
KB'd GT
Yup, check the fuses and make sure none of the o2 wires shorted out on the headers.
Threads Similar to: O2 Sensor Problem - Need HELP!!!
gas sensor problem red99newedge 99-04 5 August 22nd, 2008 02:12 PM
IAT sensor problem 5.0Madness 5.0 Mustangs 4 February 11th, 2008 04:00 AM
02 sensor problem supercharged03gt 99-04 16 February 11th, 2008 12:37 AM
o2 sensor problem winez31 96-98 2 January 9th, 2007 12:49 PM
Front O2 Sensor Problem mystang428 99-04 2 November 27th, 2006 03:14 PM
