spitting code
p0305 misfire in cylider 5.
is it more likely to be coil. or actual spark plug. just want to know before i go out and by one or the other. or maybe both.
1999 Mustang GT
8.30 1/8th mile
i would try plug first, 3 bucks is better than whatever a coil is.
Diagnostic Trouble Code (DTC) p0305
DTC Definition: Cylinder 5 Misfire Detected this could be both or one or the other. you can switch the COP with another cylinders COP and see if the code switches cylinders. If it don't it could be the plug. |
1999 Mustang GT
I had the exact same problem in mine. I ended having to change out the 5 and 6 cop's. Try changing that plug first... its cheaper. If you are going to swap out the cop with one from a different cylinder, I'd recommend you use one from the 1-4 bank of the engine. Also, if you have to replace a cop, an you can afford the few extra bucks, go with the OEM from the dealership. Its worth it to use a factory cop.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Use a little critical thinking.
Check the coil with a dvom. If readings are horribly off chances are its shot. If not go to next step. Swap plug, coil, and injector from #5 with plug,coil, injector from xxx cylinder. If the code comes back on the cylinder you switched to change the plug. It the code comes back again to xxx cylinder you changed to check the coil and injector once again. Chances are it would be the coil as the mechanical failure rate of injectors is extremely low. That should solve your problem. If the miss still comes back on cylinder 5 after swapping coil & plugs with another cylinder chances are the problem is beyond something simple as a plug, coil, or injector. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
yeah i think you pretty much answered your own question in your original post. cant be much to it and the most i see this costing to fix... ehhh... 10 bucks.
thank all
The Doctor
'01 Cobra Vert.
That's what we're here for
Threads Similar to: spitting code
| Watch out 4 spitting venom this friday!!!!!!!!!!!!!! | WilltheThrill | The Clubhouse | 17 | February 1st, 2009 03:24 PM |
| fuel spitting up from the car | cobra911 | 5.0 Mustangs | 5 | May 7th, 2008 05:01 PM |
| 4.6 spitting problem | suds488 | 96-98 | 5 | October 10th, 2007 01:39 AM |
| Spitting Cobra | 07stanggt | Modular Mustangs | 28 | June 4th, 2007 10:29 PM |
| 86 Jeep spitting antifreeze | 97Cobra | All Other Vehicles | 3 | November 28th, 2006 11:49 AM |
