#61 |
13.7@103
on the kb site it says that the 2.2l supercharger will need a larger hood for clearence?
#62 |
2003 mustang gt
12.18 @113.22 mph
youll need more money but mph has made more power than that with the 2.2, a p1sc, vortech sq, and all but youll need a new block rotating assembly blower cams at a minimum port the heads and rebuild the transmission, youll most deffinately need a new rear end. go to modularpowerhouse.com go check out or ask about some of there 2v's,2 valve street car runs 9.99@ 140mph - MPH Forums
try that link thats one of them and not the fastest!
vortech sq, 3.73 gears, steeda rear lower control arms, j&m upper rear control arms, h&r race springs, mgw short throw, pype o/r x pipe, magnapacks cat back, vortech after cooler, 3.33 pulley vortech mini race bypass valve 410 rwhp 390 rwtq |
#63 |
99 limited edition vert
the 2.2l is no longer made,been replaced by the 2.6l(the 1.7 was replaced by the 2.1l). it will not fit under a stock gt hood,not sure of the termi hood
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#64 | |
1992 Mustang GT
auto-X only
*jealous*
#65 |
13.7@103
'99-'04 Mustang 4.6 2V 2.6L Competition Supercharger
at the bottem it says ""SPECIAL TUNING NOTE: The 2.6L kit is a "Tuner Kit." It requires custom tuning on a Dynojet and a competent experienced tuner. It is a kick ass 500-750HP+ kit. "" |
#66 |
13.7@103
I've been looking on Jegs all night. When you say i'll need a new rear end do you mean 31 spline axles? or upgrade to a 9" rear end? i found the tranny i'll put in. since im replacing most of this car i found a mustang with no drivetrain.
#67 |
Moderator
2012 300a gt auto
12.10@116
a throughly built 8.8 will support much more than your need's, 9" would be nice ,but not needed.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
#68 |
13.7@103
what would you say is a througholy built 8.8?
#69 |
Moderator
2012 300a gt auto
12.10@116
team Z modified housing, 31 spline axle's & diff of your choice, rear cover with brace, & CHE housing girdle. should about do it.
#70 |
The average efficiency of a centrifuge Sc is 72-75%. So they lose 25-28% at best. I say depending on the set up sometimes a lot more the 60 hp.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#71 |
02 mineral grey GT
SORC 29 miles 13 mins 14 secs
Sorry, I should have been more definitive about the paracitic lose. Ya, you could very well loose more than just 60hp.
#72 |
13.7@103
How hard is it to convert a auto to a manual?
#73 |
Moderator
2012 300a gt auto
12.10@116
it would be one of the worst thing's you could do to a very high horsepower car. leave the auto in there, you'll be sooooooooooo much happier. to answer your question though, the swap it's self is pretty straight forward, if you do end up with the 700 hp you were talking about, the parts will be rather expensive.
#74 |
02 mineral grey GT
A few bolts here, a couple holes there, not to hard. If you got a BFG, even easier. lol
Seriously, you need everything a manual car has as far as the trans goes: clutch pedal assembly, being the biggest pain to put in. They made the cars pretty much modular in design, as far as the chassis goes from manual to auto. So if you get all the parts, its the tedious process of putting them in where they go.
#75 |
02 mineral grey GT
I kind of agree and disagree with what casper said, it all depends on what you are planning for the car. If its a street brute with the occasional road course, then manual all the way, they are more fun, and they are almost a must in a road course. If its a straight line shooter, then auto all the way, your times wont deviate because of missed or short shifts.
#76 | |
Moderator
2012 300a gt auto
12.10@116
#77 |
13.7@103
so you guys are saying if i convery a auto to a manual that it won't be as good? as if i just bought a manual?
#78 |
Moderator
2012 300a gt auto
12.10@116
I don't know what the other guy's are telling you. what I'm telling you is a 700hp car with a 5 spd is a BAD IDEA. buy an auto car to start with & leave it in there.
#79 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
yeah numbers that high would want an auto to be as fast as you can be.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Threads Similar to: GT Build Plan
| new plan on the gt | xXJayManZXx17 | 99-04 | 45 | March 31st, 2009 06:27 PM |
| my build plan (in the making) | Danderson | 99-04 | 6 | February 12th, 2009 10:51 PM |
| My plan... | Zatrekaz | The Clubhouse | 21 | December 29th, 2008 02:54 AM |
| So this is my plan | 98stangv6 | The Clubhouse | 7 | October 9th, 2008 06:59 PM |
| My New Plan | xx9gt6xx | 96-98 | 10 | November 17th, 2006 07:12 PM |
