2004 mustang gt
13.86@ 100.5 street tires
iac?
when my car idles it burps a little and it also idles very erratically on a cold start up, i changed the fuel filter and the maf is fine on a cold start it will idle from 1200 1400 back and forth its like its not getting enough of something, i have posted this thread before and some people suggested checking me fuel trim but i have no way of doing it, besides when i start it up after being drove say half an hour later it smells really rich and wants to miss, kinda like its starving for air and if i let it set and idle it clears up it has me stumped HELP.
![]() The usual bolt on's.. |
11.85 @ 125
![]() ![]() iTrader: 2 reviews
it could be. I know that it is money out of pocket but you could get on from the parts store and install it. try it for a couple of cold starts. If it still does the same thing. then just take the part back. They usually say that you can't, but as long as you don't leave any marks on it and clean it off, they will take it back. or borrow a buddies
Just a suggestion. |
2004 mustang gt
yeah its a pretty expensive part 100 bucks i hate to spend the money but i am at my roads end this thing is really pissing me off, performance is kick ass that is what don't make any sense, you would think if it was bad the performance would be affected.
1999 Mustang Gt
how are your upstream o2 sensors doing have they been replaced recently. my car did pretty much the same thing only a little worse thought it was the iac replaced it to no avail turns out i have a bad o2
2004 mustang gt
haven't replaced those, the car only has 30,000 miles on it, i only replace the post o2's then i installed the x pipe
1999 Mustang Gt
i would still check them they dont necessarily have to have alot of miles on them to go bad. also check your fuel trims. do you have any exahust leaks before the o2s?
2004 mustang gt
thats a good possibility because i have a shit pypes brand x pipe leaks like a son of a bitch! bbk one is coming soon i will go ahead and check the o2's then not to sound stupid but how do you check fuel trims?
1999 Mustang Gt
well you need a tuner or a code reader that hooks to a laptop so you can talk to the computer.
2004 mustang gt
i don't have a scanner and i got it tuned at pauls high performance in michigan would the trims shown up when he tuned it?
1999 Mustang Gt
yea i am sure he could look at them but you need to see your trims right now
2004 mustang gt
k thanks!
1992 Lx
11.39@119.24
pull the iac off and clean it with carb cleaner
1999 Mustang Gt
+1
careful to not get much in the motor housing as it could cause damage |
2004 mustang gt
done that already no change
Threads Similar to: iac?
| Which one is the IAC? | 95BlackStang | 94-95 | 12 | November 10th, 2008 12:06 PM |
| Anyone know if i could use an iac from a 94 on 87-93?? | black88 | 5.0 Mustangs | 0 | September 2nd, 2008 12:16 PM |
| IAC | zinc02GT | 99-04 | 18 | May 15th, 2008 07:50 PM |
| IAC | Danderson | V6 Mustangs | 3 | February 4th, 2008 09:12 AM |
| iac | punkafi888 | V6 Mustangs | 10 | April 29th, 2007 10:52 PM |
