Order mix up leads to me having to decide
Old September 1st, 2009, 09:44 PM   #1
TorqueO's Avatar
TorqueO is on a distinguished road
Ok ...I screwed up in ordering and now I have MMR 12"-250lb Rear Coilover
with 3 way adj Drag Shocks from Comp Engineering and Maxium Motorsports
Rear Height Adj Lower Control arms. I was planning on going coilovers in the rear but couldn't pass on these MM LCA's.
My current set up is M/T 315 10.5 DR's, 3.73's, Eibachs Sport lines, UPR Upper and Lower non-adjustable control arms installed already. 31 Spline Superior axles and Frpp 31 spline differental are about to be installed.
I am trying to figure out if its going to be worth doing the MMR coilover kit with the UPR LCA control arms or go with the MM LCA's....and still use the C/E Drag shocks from the coilover kit. Maybe go with a rear drag spring an get rid of the Eibachs.
Any advice or experience is welcomed!
Old September 2nd, 2009, 08:18 AM   #2
TorqueO's Avatar
Opinions on LCA's with coilovers vs height adj LCA's with springs?
Old September 2nd, 2009, 08:30 AM   #3
TorqueO's Avatar
I have been leaning towards the MM height adj LCA's with the C/E 3 way drag shocks. Maybe using the Eibachs that are already there or find better rear springs.
Old September 2nd, 2009, 12:05 PM   #4
BLOWN2V's Avatar
2000
10.67
BLOWN2V will become famous soon enough
I would keep the coilovers. From the susp gurus I gave talked all have said the best thing you can do for a mustangs rear susp is get the spring off of lca
2000 GT
60' 1.42
1/4 10.49
mph 129.8
Old September 2nd, 2009, 01:38 PM   #5
TorqueO's Avatar
ok, so springs on the LCA's are a no go and hurting the performance. Did they give a reason? This is something I would like to know as well.
Thanks
Old September 2nd, 2009, 01:57 PM   #6
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
you arent going to like the shocks, you will have to remove them to adjust them
Old September 2nd, 2009, 06:05 PM   #7
TorqueO's Avatar
Ya that I know, I'm going to keep them at 50/50. I dont drive the Mustang much only on nice days, when I have time and to the drag strip.
Old September 2nd, 2009, 08:43 PM   #8
TorqueO's Avatar
Been looking for an answer the past few days and still up in the air.
Looks like to me that its based on these differences between the two:
Coilovers - are for handling and body roll but you can choose your spring rate which is real good
LCA's w/springs - Seems most people at the strips (from what I see in most peoples set ups) use the LCA's and have real good transfer of power to the ground
am I correct in saying this?
Old September 2nd, 2009, 08:46 PM   #9
TorqueO's Avatar
If I go with the LCA's and spring I would be looking into getting some fox body springs for a convertible....I have a convertible
Old September 2nd, 2009, 09:05 PM   #10
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
This is what i run, but 4 cyl springs. I hook great. I will be fabricating my own coil over set up some time in the near future. You have more adjustments with a coil over set up.
Old September 4th, 2009, 12:28 PM   #11
TorqueO's Avatar
I have this posted on a few other sites and only a handful of people have replied.
Seems there are no pros and cons, which is better, and it all comes down to the springs and what you prefer. I guess for weight savings, body roll, and road course people go with the coilovers?
Why is it that the springs should be off the LCA's?
Old September 4th, 2009, 05:29 PM   #12
TorqueO's Avatar
Just going to run the coilovers...getting mix reviews on and no one really is explaining why this or why that...no big deal I guess. Figure spring rates would be easier to change and like SMS mentioned before so would the adjustments. Anyone want to buy some New MM Ex Duty hgt adt LCA's?
Old September 4th, 2009, 05:46 PM   #13
00mustang00's Avatar
2007 cadillac sts
00mustang00 has a spectacular aura about00mustang00 has a spectacular aura about
if you have any questions about suspension i would pm jazzer the cat he is really helpful with suspension questions
Old September 4th, 2009, 05:47 PM   #14
2007 cadillac sts
btw torqueO i like your avatar i used to have that exact sticker on my hemi ram haha
Threads Similar to: Order mix up leads to me having to decide
Ford Leads Charge As Auto Sales Show Signs of a Rebound Administrator All Other Vehicles 0 July 1st, 2009 06:04 PM
My 80's Mix joejoe8455 The Clubhouse 4 March 29th, 2009 05:04 PM
Mix Turtle tajoerg The Clubhouse 10 February 9th, 2009 05:26 PM
WOT air/fuel mix? takiller 99-04 4 March 6th, 2008 03:11 PM
Mix and Matching MacGill 99-04 2 February 14th, 2008 05:14 PM
