5.4 swap
Old September 11th, 2009, 09:56 PM   #1
Boostr's Avatar
1998 Mustang GT
13.8 @ 99mph
Boostr is on a distinguished road
5.4 swap
Im thinking about doing a 2V 5.4 swap. Can I use the KB 2.1 Intercooled kit for 99 up GT on this motor if I get the adapter plates? I will be getting the TFS 2V Heads. Just doing some research. what do you think?
Car's out back
"Excuse me,
Your balls are showing."
Old September 11th, 2009, 09:58 PM   #2
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
can't see why you couldn't
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old September 11th, 2009, 10:11 PM   #3
Boostr's Avatar
1998 Mustang GT
13.8 @ 99mph
Any body know what kind of exhuast modifications I need 2 do? I would like 2 reuse my Ford Racing shorty headers.
Car's out back
"Excuse me,
Old September 11th, 2009, 10:24 PM   #4
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
try searching, there is a few threads on that swap. ok.
Old September 11th, 2009, 10:33 PM   #5
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Yep probably if you use the plates if the pulleys line up.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old September 11th, 2009, 11:30 PM   #6
RALVAREZ26's Avatar
2000 MUSTANG GT
RALVAREZ26 will become famous soon enough
your shorty will fit
http://smokinperformance.com
Slowmatic 2000 GT
Old September 12th, 2009, 08:25 AM   #7
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
last time i checked they didnt make shorties that fit the 5.4's in the mustang?
Old September 12th, 2009, 11:58 AM   #8
liljojo4711's Avatar
liljojo4711 will become famous soon enough
u can get the newly done long tubes, they are $1200. otherwise just stick with the stockers. u dont gain much with shorties. u will need to modify ur h/x pipe. in most cases it needs to widened and lengthened to fit. go here for all ur answers:
Anyone intrested in 5.4L swaps, in here. Need you to opine. - Page 261 - Mustang Forums
TOPLESS MUSTANG CLUB
Originally Posted by I8ACMRO View Post
I'll try the vaseline tonight. Thanks for the tip.
Old September 12th, 2009, 12:11 PM   #9
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
you can reuse your headers.. you will need a huge cowl hood for that to fit though..
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old September 12th, 2009, 12:46 PM   #10
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Why?
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old September 12th, 2009, 11:44 PM   #11
the motor will fit fine, not sure about adding the supercharger. hood might need to be clearanced a little bit, but not cut. i think.
Old January 22nd, 2010, 08:34 PM   #12
Look Ma! My First Post!
mumber1gt is on a distinguished road
5.4 swap in 2000 gt
ok i have a 2000 gt and i want to do a 5.4 swap and i want to use a 3v or 4v engine. how could i use a 3v or 4v engine using the gt computer? could it work because the gt is a 2v engine
Old January 22nd, 2010, 11:46 PM   #13
tons of info
Modular 4.6L Tech - Mustang Forums
Old January 23rd, 2010, 01:06 AM   #14
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
4.6 2V to 5.4 2V
Power Returns:
For those wondering the swap can be done for cheap, and has the "Budget Builder" in mind. You will see a greater gain in Performance when swapping a 5.4 (Rated at 260hp/350tq) to a say 1997 Mustang Gt (Rated at 215hp/290tq) than a 99-04 but both deliver considerable SOTP and dyno gains. A gain of 45hp/60tq right off the bat is common for NPI, stock for stock; not to mention the added cubes make the power earlier in the RPM band. With a 99-04 Mustang Gt (Rated as 260hp/300tq) your gaining ~50ft/lbs or more, usually a little bit of HP (depending on MANY factors) and the added cube effect.
HPS intake vs. Adapter plates:
If you use the HPS intake then the top end picks up quite a bit and you can see gains of 15-30hp or more. Each engine is different so there's no guarantees but these are numbers that are not uncommon and won't set you up for disappointment. The current record NA that we've been able to find is 340/340 to the tires on ported PI heads. The HPS intake allows better underhood clearance and helps stretch the power band on the 5.4 back out to a useful point. Adapter plates move the injector up higher and fuel no longer sprays unimpeded at the back of the valve. This results in higher fuel consumption and a requirement for a good bit more fuel in the tune. The plates are simply a band-aid that has been superseded by the HPS intake. Adapter plates average about 250-375 bucks depending on which brand you get. The HPS intake is 695 and ADDS on average 20-30hp. When's the last time you were able to make an honest 30hp from a bolt-on part for 400 bucks? Exactly. It's worth it and it's stupid easy to bolt up.
Just to give you an idea of cost:
1. motor (330CubeGt) complete from top to bottom with all pulleys, belts, wiring harness, computer, ECU, etc with 40k miles on a "tested" motor got dropped off at my house freight for $1400.
2. motor (r3dn3ck) complete (550) + complete forged rebuild incl. parts (2400) + cams (400) + heads (400) + tuning (500) + injectors (100 used) + fuel system (350 rails,pump,hoses)+ install (1000 ) = $5700.
3. motor (former member) complete (200) + adapter plates (200) + misc (probably around 300 for gaskets, bolts, etc...) and installed himself = < $1000
Technical:
Difficulty:
It’s pretty much a direct swap besides the intake needing the 5.4 to 4.6 adapter plates to use the PI style mustang intake or the use of the HPS intake.
Oil Pan:
With the oil pan you need to use the 4.6 oil pan along with the 4.6 pickup tubes, both bolt directly to the 5.4 with only MINOR modification to the pan. The 4.6 pan has two fins on the shallow side of the pan they need to be bent over about 1/4". Just take a rubber hammer and whack at em' a couple times. Check your crank throw clearance before you install permanently. This needs to be done in order to clear the crank throw. If you don’t do this your crank&rods will hit them and could damage something severely.
Before you put the 5.4 in the car if you're going to use stock manifolds, you need to grind down the passenger side manifold on the flange that the mid pipe bolts up to. (The side that’s closest to the frame rail)
If you don't do this the header/exhaust manifold will hit the frame rail especially if you’re using the stock rubber mounts. You don't want to have to fix it. Do it or get the bang-rattle-bang.
Motor Mounts:
While the motor is out it would not hurt to upgrade to polyurethane motor mounts or a set of solid motor mounts. The 4.6 motor mounts need to be used because the 5.4 truck mounts will not work and yes the 4.6 mounts bolt right to the 5.4 block they share the same bolt pattern.
Exhaust:
The 4.6 and 5.4 are basically the same motor, besides the added deck height (hence the extra stroke). Due to the added deck height the pipes are spread apart a little more and they don't line up in the stock humps (In the transmission cross-member) but they’re close. Look at it like this the motor is a V shape so the taller the deck height the further away the two points become therefore making the motor wider and taller and making your existing pipes effectively shorter. It can get the pipes kinda close to the floor-pan which is a good reason to add some length to the down angled portion of the mid-pipe. When you put the mid pipe on you have to fuss with it a little to get it in the right spot, so be patient. Sometimes simple persuasion will get it there, sometimes you have to cut and weld in a bit of tube and often you'll need to extend the crossover in the stock H-pipe. Not always but often enough. I (330CubeGt) was able to run my Mac pro-chamber and Cat-back with no modification, so any Mustang Mid Pipe or Cat-Back will work with minor modification at worst. Muffler shops can do this for 50-100 bucks if it becomes necessary for your case. Just letting you know because I have heard some people saying you always have to cut/hack/weld your exhaust to make it work and you don't always have to.
Just an FYI: 4.6 long tube headers will absolutely not fit with a 5.4 simply because of the added height/width it will put the headers up into the floor and they would hit all kinds of stuff. 5.4 Long Tube headers are made by FTP. PM Myillwillinc for contact info for FTP. For shorty headers you can use JBA or FRPP right out of the box. BBK's have never fit well without being modded that anyone has reported. Custom longtubes can easily cost several thousand dollars so save the time and money and just call up FTP and get theirs.
Heads:
As far as the heads the 4.6 and 5.4 are the same, so you can use your 4.6 heads if needed.
Clutch/TC:
You will need an 8 bolt flywheel/flexplate. 96-01.5 cars have 10.5" clutches. 01.5-04 have 11" clutches. As far as I (r3d) know the TR3650 trannies are the ones with 11" clutches. You can buy an 8-bolt flywheel for 10.5 clutches, and a 10.5" clutch of your liking, a new TOB and a new pilot bearing (5.4's usually DO NOT come with them) and it'll connect right up. 10.5" clutches are cheaper and easier to find but the 11" will work just as well. This is only really a matter of decision for 01.5-04 cars. r3dn3ck retro-fitted his 11" to a 10.5 and it was stupid easy. Auto's will need the correct flex plate. Details on which one for that should be updated in this post soon.
Fuel System:
Stock rails fit the HPS intake most times. If the crossover tube is too short you can chop it off and replace it with a longer section of high-pressure fuel line. Cost for that fix is usually about 10 bucks. You can buy aftermarket fuel rails for a 4.6 and use those just as easily but for substantially more cost. You get EXACTLY what you pay for in fuel rails. Buy nice ones with screw on brackets. No half-round hold-downs, real brackets. I (r3dn3ck) recommend aeromotive.
Most cars can technically use the stock 19lbs yellow top or 21lbs pink top injectors but they tend get to 100% duty cycle around 5000rpm which is bad. 24lbs is plenty for most applications but 30's are fine as well. If you have heads and cams and headers and bolt-on's then you should definitely step up to a minimum of 24's and really, get the 30's. If you use a power adder, get an injector that can feed it. If you need help figuring out your fuel delivery needs, then ask in the big 5.4 thread.
Your stock fuel pump is enough for direct swaps. If you're doing anything more than that (big heads, cams, nitrous, etc...) then you really need to start with an SVT focus pump and possibly go much larger depending on what power level you're looking at. Don't underestimate the need for fuel delivery. 5.4's are thirsty at high RPM's. A failure to provide enough fuel will stack harm up on your motor.
Tune:
A tune is really a must; just a little mail order street tune to dial in the air fuel ratio is fine (If you have a wide band air/fuel gauge). Or you can put the car on the dynamometer and make a few pulls and get a dyno sheet with your RWHP/RWTQ and AFR read out. Original ECU/computer can be used along with the original engine harness. Use all the sensors from your 4.6 as some of the 5.4 sensors are different even though they share a connector (usually the signal voltage range is different when they're different). Save the hassles and use ALL of your stock 4.6 sensors. Crank position, cam position, FRPS, O2's, water temp, oil pressure, etc...
This write-up is more along the lines of 2V to 2V But going with 3v Heads is Easy but less common, or 4V which is becoming more common with the 5.4 swaps.
The 5.4 N/A or with a Centr/Turbo setup will fit under a stock hood, a Setup like mine obviously don't but if you wanted to go twin screw/tvs style blower most can me tucked under a 3/4 Inch cowl.
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old January 23rd, 2010, 04:38 AM   #15
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
thank you for all the info. i plan on forging the bottom end while the engine is out and throwing a kenne bell supercharger on it
Old January 23rd, 2010, 11:41 AM   #16
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
i wouldnt really suggest using a supercharger with the adapter plates...i mean they were just a bandaid for N/A but if you throw in supercharging...i just dont think that would be all that wise. i mean i could be totally wrong but just my opinion. doesnt kenne bell have a lightning blower you could use? if your going 4v doesnt whipple have a gt500 supercharger as well?
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old January 23rd, 2010, 11:49 AM   #17
86er's Avatar
205 631 3871 shop number for FTP. Im close friends with Tommy myillwillinc and TJ @FTP both guys are great and TJ does great work.
The headers he built for my friends 5.4 swap car are gorgeous
Just a truck
Old January 23rd, 2010, 11:50 AM   #18
86er's Avatar
adding a s/c will not work with just clearancing the hood. You either get a cowl or cut it.
HPS makes an intake to let you stay N/A and keep the stock hood
Just a truck
Old January 23rd, 2010, 01:19 PM   #19
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
iTrader: 14 reviews
I think he was talking more along the lines of being N/A even under a stock hood i had to notch it a tad for the JLT.
And with a Twin screw such as KB or Whipple it should sit under a 3/4 inch cowl.The only time you have to worry about puttin a hole in the hood is with the L blower.
Old January 23rd, 2010, 11:36 PM   #20
number1gt's Avatar
2002 mustang gt
well i looked in to it and kenne bell does make a supercharger for the 5.4 and i was planning on getting a new hood anyways. its either that or i could get a vortech supercharger. but i really love the power that a kenne bell creates!
Threads Similar to: 5.4 swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 08:00 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
4.6 swap bcchambe Modular Mustangs 3 July 9th, 2007 12:36 AM
