All Tr3650 Owners Read This! - Page 7
LinkBack (6) Thread Tools
Old May 24th, 2011, 11:07 AM   #121
ZenMGT's Avatar
'02 GT 5spd
ZenMGT will become famous soon enough
sorry,,,,sorry,,,so just to be clear GM and Penzoil synchromesh are the SAME?
It doesn't matter which I put into my '02 3650 right?
boringly stock........but running well
Old May 24th, 2011, 11:46 AM   #122
jeep45238's Avatar
2003 Mustang GT
jeep45238 is on a distinguished road
Yes, they fluids are the same specs.
I recently changed all my fluids over, and filled with the 3L of Pens. Synchromesh. No noticeable change on the 1-2 shift at first, all others were a little smoother. After about 200 miles though, all shifts are easy as butter, and it doesn't feel like there's multiple notches when I'm going from 1-2.
Old May 24th, 2011, 01:01 PM   #123
ZenMGT's Avatar
'02 GT 5spd
I've got that same notchiness going on. I changed my fluid to the P. Synchromesh about a year ago, and noticed better shifting right away, and over time.
However it's still a bit notchy/grindy when cold. I've heard that while Penzoil meets the specs. it's not 100% the same fluid (whether its the stock oil used, or friction modifier that's different). I also 'hear' that the GM stuff shifts better while the fluid is still cold.
When we changed out mine, the guy helping me just dumped my fresh fluid into a pump that arleady had some other brand trans fluid it in. So I believe I got a 'mix' of synchromesh, and something else.
Doing the oil in a day or so, and thought I would go ahead and swap the oil out to the GM stuff, just to see if there is any difference.
Old May 24th, 2011, 03:36 PM   #124
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
Holy fucking run-on sentences, danny-boy. Ya know, they invented punctuations for a reason!
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old June 2nd, 2011, 12:07 PM   #125
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
NastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant future
iTrader: 9 reviews
This is the correct fluid, right?
Pennzoil/1 qt. synchromesh manual transmission fluid (3501) | Transmission Fluid | AutoZone.com
I'm currently running Amsoil ATF but I'm going to give this a try based off of what someone claims Tremec says. If Tremec really didn't say that please tell me before I dump out some expensive Amsoil ATF...
Old June 2nd, 2011, 04:56 PM   #126
JustRight's Avatar
01 GT Conv
JustRight is on a distinguished road
Originally Posted by TorqueO View Post
Just wondering ...why not just use Royal Purple Synchromax or ATF?
Personal experience with a TR3650 and the Royal Purple----not good. Shifted poorly and fluid was burnt smelling in less than 400 miles (noticed it while pulling for a new clutch.)
Using Mobile 1 with fill level 3/4" below----life is good again
P.S. Became suspicious of the Royal Purple gear fluid in the rear after seeing the tranny fluid. Yup, 400 miles and the diff fluid was burnt also. Royal Purple----never again for me.
Official member of the anti ethanol-laced gas crusade.
Old June 2nd, 2011, 07:35 PM   #127
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
I ran RP in my trans for 6k miles or so and its was flawless. Got some emails from RP as well assuring me the fluid wont harm the trans. You can see the emails posted a few pages back.
I dont see how you could burn fluid up let alone in 400 miles. RP is pretty quality stuff. there's just the dabate whether it eats internal parts or not.
Old June 2nd, 2011, 11:23 PM   #128
JustRight's Avatar
01 GT Conv
Can't answer that. I can only tell what I found in mine and yes, it was only 400 miles.
I only put about a thousand miles a year on it.
Old August 3rd, 2011, 02:26 AM   #129
yansito is on a distinguished road
Wow, I am really confused now. I called tremec and asked for the specific fluid to use in the tr 3650 and the tech said dexron III or mobil one ATF. I then told him I had heard alot of good things from pennz synchromesh and GM synchromesh and he replied that those synchromesh fluids are only recommended on their aftermarket transmissions such as the tko and not the 3650 ... Oh and he Also said the correct capacity is 6.3 pints which is about 3.17 3.25 quarts ... So what truly is the right fluid pennz synchromesh or what the tech specified...
Old August 3rd, 2011, 03:45 AM   #130
sharpshooter33's Avatar
2003 2008 Mustang GT
sharpshooter33 is on a distinguished road
Wow!
I put my 3qts in and then put more in. I stopped around .2 of the 4th qt, but I felt like there just wasn't any in there. Couldn't feel it with my finger thru the fill hole so I put the 4th qt in thinking what the hell it can't hurt. WRONG
I've been wondering why it still was a PITA to shift when rev'n it up and fighting me on down shifts sometimes.
Think I need to fix that problem before it becomes a $$$$ problem.
Thanks
Old August 3rd, 2011, 09:03 AM   #131
Blown 03 GT
Originally Posted by sharpshooter33 View Post
Wow!
Thanks
Originally you would fill it til it was just at the hole and you could feel it. the revised recommendation is to use 3.2qts. I think it was 3.7 before, either way its a good bit less and you wont feel it.
Old August 16th, 2011, 01:01 AM   #132
Syncromesh manual tranny fluid?
Ok so I've been reading over this link and I just did my tranny this spring. I added the Mercon or whatever auto tranny fluid. Don't remember what it was auto tranny fluid I think it was mobile synthetic...
Anyway I've been reading here about Penzoil Syncromesh here. I go to Autozone and check their website and I see Penzoil Syncromesh manual tranny fluid. Is this what I need?
I'm doing my daughters 99 Cobra this week and thinking about redoing mine since I did add too much before really reading these threads. My 03 GT is a manual T3650 and I'm assuming that the 99 Cobra is the same.
Her carfax shows it was changed at valvoline last year, but it shifts for shit!!!!
Trying to get it in gear when you rev it up is like smashing the shifter against a wall until the rpm slows down. I think the clutch also needs adjustment, but Valvoline instant oil changes "tranny fluid" change also has me worried.
Anyway are we talking the Penzoil Syncromesh manual tranny fluid?
Old August 16th, 2011, 01:12 AM   #133
scp616's Avatar
scp616 is on a distinguished road
Yep, penzoil synchromesh is what I put in mine. Just make sure you only put in 3 liters
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
Old October 12th, 2011, 11:49 AM   #134
AP_Photo's Avatar
AP_Photo is on a distinguished road
So looks like I need to do this with mine. Of those of you who swapped over to Penzoil. Any problems or are things still good?
1955 Ford Victoria 2dr Hardtop
2007 Honda Civic
2004 Mustang GT (stock for now)
www.atlphoto.net
Old October 12th, 2011, 11:51 AM   #135
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
ive put 10-15000 miles on mine since the switch. no porblems.
Old October 12th, 2011, 12:08 PM   #136
Blown 03 GT
Ive put over 6k miles on mine with Royal Purple and 420ftlb and its still good so yeah.
Old October 12th, 2011, 12:27 PM   #137
AP_Photo's Avatar
Thanks for the feedback. I am trying to decide if I want to do Penzoil or the GM Synchromesh (can get it for $10.50 per quart).
2007 Honda Civic
www.atlphoto.net
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/136836-all-tr3650-owners-read.html
Transmission Fluid - Stangs of South Florida This thread Refback December 8th, 2011 09:54 PM
ATTN: All TR-3650 Manual Swap Owners - Crownvic.net This thread Refback July 8th, 2011 07:47 AM
ATTN: All TR-3650 Manual Swap Owners - Crownvic.net This thread Refback July 6th, 2011 09:54 AM
ATTN: All TR-3650 Manual Swap Owners - Crownvic.net This thread Refback July 6th, 2011 08:58 AM
NorthWest Indiana Mustang Club • View topic - gear jammers This thread Refback March 5th, 2010 06:06 PM
NorthWest Indiana Mustang Club • View topic - gear jammers This thread Refback March 2nd, 2010 01:31 AM
Threads Similar to: All Tr3650 Owners Read This!
centri owners please read 06HellFireGT 2005 - 2010 73 December 2nd, 2008 06:58 PM
Iron fist, Lead Foot a must read for termi owners ZOOTOXIN 4V / SVT 3 May 23rd, 2008 11:24 PM
All 05 or newer Mustang Owners Must Read!!!! turismo374 V6 Mustangs 6 May 13th, 2008 02:24 PM
ford whoops.... my bad. COBRA OWNERS NEED TO READ!! cobramac 99-04 0 January 8th, 2008 11:58 AM
CRITICAL READ FOR X-CALIBRATOR OWNERS Geezer 2005 - 2010 1 May 19th, 2007 08:09 AM
