Rear end ratio for Supercharged cars
Old September 25th, 2009, 03:41 AM   #1
discogodfather's Avatar
discogodfather is on a distinguished road
I have a 3.27 read end with a roughly 400rwhp vortech supercharged setup. I know 3.27 is a little high, and I never really go 150mph+ and don't care about top speed.
Was thinking about 3.73 or even 4.10's to get some more low end acceleration (which is all my driving style cares about), but something tells me the 3.27's provide a little more traction at launch in 1st gear. First is very useful on my ride. Many fellow S/C modular dudes have told me their 3.73 or 4.10 makes 1st useless- too much wheel-spin and no hookup.
What do you guys think? My perfect setup would be fast off the line, without making 1st gear useless of course, and I don't care much for fuel economy or top speed. What's my best bet ratio??
2000 Factory Roush Stage 2 405whp
Alcon /18" wheels
Roush Stage 2 susp
3.27 LS
MM roll bar
Roush shaker
90mm MAF / 42lbs injectors / Focus SVT pump
V1 S-Trim 3.125" @12psi /air-water IC / 928 Impeller
DF Commando self-tune
Old September 25th, 2009, 04:44 AM   #2
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Do suspension work, launch in higher rpms. What suspension work do you have done?
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old September 25th, 2009, 09:23 AM   #3
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
What tires are you running on the 18" wheels? Tire size affects the way that gears perform. For example, 3.73 gears will behave more like 3.55 gears (it actually calculates to 3.59) if you have 245/45-18 tires because of the larger diameter of the tire (fewer revolution per mile). 3.90s will behave more like 3.73s (3.75).
Conventional wisdom says 3.73s for a supercharged car but it really depends on your horsepower and suspension. Sometimes 4.10s work and sometimes 3.73s are too much. I prefer 3.73s because my car is a daily driver with minimal suspension mods. With my set up I cannot go WOT in first even if I'm already rolling at 25 mph and if I hit second wrong I'm bouncing off the rev limiter going nowhere fast. I would not have been happy with 4.10s.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old September 25th, 2009, 09:55 AM   #4
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
If you're worried about traction then you need to get better tires (DR or extra wheels with slicks) and do some suspension work. I think with my centri blower i'm gonna get 4.10s when the time comes, just because I don't make boost in the lower rpm range so I wanna get into the higher rpms quicker. Either that or I'll go 3.73's and just pulley down for more boost.
Rear end gears can easily be compensated for by changes in tire size. If you get 4.10s and they are too much, run a taller tire. If 3.73s aren't enough go to a shorter tire.
Old September 25th, 2009, 10:08 AM   #5
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
I have 3.73s, stock suspension and 285 tires. Above 4000rpm in second the tires start spinning. Oh Im putting down about 420whp. A lil suspension and Ill have traction. but I wouldnt go with any other gears.
Old September 25th, 2009, 11:02 AM   #6
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
You're only making 420hp with 14psi on a 5.0 stroker???
ΜΟΛΩΝ ΛΑΒΕ
Old September 25th, 2009, 11:38 AM   #7
Blown 03 GT
That was with a brand new motor and gears. I was expecting more. I am still on the stock heads. Im goin to a dyno day October 4th, my fingers are cross that the motor and gears and broken in and the power is up.
Threads Similar to: Rear end ratio for Supercharged cars
High End Cars AMmuslGT The Clubhouse 24 April 11th, 2009 05:34 AM
Stock rear gear ratio? Ntv69 5.0 Mustangs 5 November 16th, 2008 09:14 PM
What gear ratio for a supercharged v6? V6 Stalker V6 Mustangs 40 March 31st, 2008 06:52 PM
rear end gear ratio G.T. Rags 96-98 37 April 24th, 2007 12:31 AM
8.8 Rear end (What Factory cars have it) GreenFaleen V6 Mustangs 43 January 8th, 2007 11:34 PM
