T-3650 - Page 2
Old November 16th, 2009, 05:01 PM   #21
DiZzyBonne's Avatar
2001 Ford Mustang Bullitt
DiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the roughDiZzyBonne is a jewel in the rough
Send a message via AIM to DiZzyBonne
What about a TKO-500 or TKO-600?
Current mods:
  • Maximum Motorsports XL Full Length Subframe Connectors
  • Catted Bassani X-Pipe
  • Borla Stinger Catbacks
  • H&R Super Sport Springs
MM Bullitt Crew Founder and Member #1
Old November 16th, 2009, 05:09 PM   #22
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Dammit, I've been mixing up t-45s and t-56s.
Here's a link to the different T-56 specs.
TTC: TREMEC Transmissions
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old November 16th, 2009, 05:12 PM   #23
3rd Place '11 ROTY
Jazzer The Cat's Avatar
'02 GR-40/SLA Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
I have heard some mixed reviews on these two models, so would do some research if considering either of these.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Jazzer The Ego HD Vids | C/A Livernois beast build
Man those are some fantastic milk transporting devices... "
Old November 16th, 2009, 05:17 PM   #24
El Danno
dcook_14's Avatar
iTrader: 7 reviews
If you switch from a 3650 w/ stock rear gear to a t56 with stock rear gear, you're gonna lose some on the launch. If you switched to a 3.67 (I know they don't make that, just for arguments sake) with the t56 it will be exactly the same first gear as a 3650 with stock gears. So go with some 4.10s with the t56 and it'll be like running 3.73s with a 3650.
Danno hoping that his math is right and stealing Jazzers signoff as well
Old November 16th, 2009, 05:27 PM   #25
3rd Place '11 ROTY
19.34@42.259
Danno's got a Jazzer confused......
Take a CLOSE look at all the ratios available for the T-56. Now take a look at the ONLY ratios available for the T-3650/T-5/T-45 (with exception of having a custom built one, of course) and can figure it out.
I installed the #1260 because my T-3650 was dying and HATED (< X10000 ) the mega-gap between 4th~5th gears. I also liked the somewhat taller first gear so also not such a big gap to 2nd.
All that said, the T-56 is not for everybody as most don't seem to mind the gap soo much, but is a pure blessing on 50 MPH roads and 3:55 gears
Jazzer... secure enough for Danno to use his sign-offs
Old November 16th, 2009, 06:07 PM   #26
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Okay, this post is comparing being in first gear in a T3650 with being in first on a T-56 Model #1260. Everyone rips on the tall first gears of the T-56.
3650 = 3.38 I believe and a T-56 = 2.97. Basically what I meant was that if you just swap in a T-56, you're gonna be hurting your launch a little bit at the strip due to the difference in ratios. Maybe breaking it down this way will help. In first gear:
A T-56 w/ a 3.73 rear gear is gonna behave like a 3650 w/ stock gears
A T-56 w/ a *4.30* rear gear is gonna behave likea 3650 w/ 3.73s
Basically what I'm saying is the tall first gear of a T-56 is easily remedied by a shorter rear gear.
Glad to hear I could use it, that was a one time thing though I don't think I'm knowledgeable enough to have a cool signoff like you do
Anyway, my dream transmission would be a T-56 Model 1260 with the 5th and 6th gears swapped out for the 1806 (Viper spec) 5th and 6th gears. I'd get some 4.30s out back.
My first gear would be shorter than a stock GT with 3.73s (better for launching) but my sixth gear would be taller than a stock GT with stock gears (better for DD). Plus I'd get nice even steps between my first four gears and an extra gear to fill in the gap after fourth.
Old November 16th, 2009, 08:01 PM   #27
3rd Place '11 ROTY
19.34@42.259
Yup, the taller first gear seems to be the rub on the T-56 when it comes to lauching, but pepe this:
Take a look at the T-3650/T-45/T-5
3.38
2.00
1.32
1.00
0.68
... now the #1386 T-56
3.36 < nearly identical to the T-3650/T-45/T-5
2.07
1.35
1.00
0.8 < check out THIS bad boy
0.62
... now the #1260 T-56
2.97 < my first gear
2.07
1.43
1.00
0.62
I did some MPH/RPM readings on all my gears before/after my swap. It was impossible to tell via "feel" or by the numbers on any gears except 1st and the new "inbetween" 5th of my T56. I can just about guarantee you would never tell the #1386 T-56 from ANY T-3650/T-45/T-5.
Jazzer... speakin' the gospel to his pepes
PS... Danno is plenty cool enough to run The Jazzers sign off
Old November 17th, 2009, 11:24 AM   #28
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Hey Jazzer,
I was looking at this site TTC Automotive and the 1386-000-025 looks like just about what I want. Same gears as yours for 1-4, a little shorter 5th and a little taller 6th. But the Torque Cap. (I'm assuming that means torque capacity) is only 385 foot pounds. What's up with that? The highest capacity besides the Viper spec tranny is 450... Can these trannys really not handle more torque than that? When my car is all finished in about 5 years I want to be putting out about 700 hp and 650 lb/ft of torque at the crank. Would I have to build these T56s to handle more or what?
Old November 17th, 2009, 12:13 PM   #29
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
Nice info jazzer. I always hear/read the same thing. Don't get a T56. Gear ratios suck. Blah Blah Blah. That 1386 fits the bill perfect for me. That will be the way I go if I ever need to replace this 3650 in the car. Those 5th and 6th gears will make for nice 45-55mph highway and interstate driving with my 4.10s as well.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old November 17th, 2009, 12:36 PM   #30
3rd Place '11 ROTY
19.34@42.259
Danno... I would call TTC and speak with Bruce at Modern Driveline. He can tell you TONS more than I can about torque capacity and such. He can also build you the trans with the gears you like with the parts to handle the HP/T numbers of your ride.
He was VERY helpful and well before I committed to buying from him. He must have spent three 10-minute calls with me to help diagnose the issues I was having with my T-3650 before he recommended the T-56 #1260 to me.
Jazzer
Old November 17th, 2009, 01:07 PM   #31
El Danno
dcook_14's Avatar
iTrader: 7 reviews
I'll be sure to give them a call when the time comes. Thanks a lot Jazzer.
Old November 17th, 2009, 01:53 PM   #32
3rd Place '11 ROTY
19.34@42.259
word
Old November 17th, 2009, 02:28 PM   #33
huggy bear's Avatar
2001 Mustang GT
.23333333 minutes
huggy bear is on a distinguished road
3.38
2.00
1.32
1.00
0.68
2.07
1.35
1.00
0.62
2.07
1.43
1.00
0.62
Man I am retared don't understand any of this can anyone explain?? Awesome info though knowledge is power yo!
2001 Mustang GT: 10.5 bullit rims, straight pipes, 180 degree t-stat, rear upper control arms, power slot rotors, hawk pads. fml
Old November 17th, 2009, 02:37 PM   #34
El Danno
dcook_14's Avatar
iTrader: 7 reviews
What Jazzer posted are just the different ratios for each gear in the transmissions. Each gear has a different ratio, and that's the point of the transmission. They work kinda like rear end gears. The higher the ratio number, the more zip it's gonna have but the faster it's gonna run out. The lower the ratio number, the faster you're going to be able to go in that gear, but you're going to have to stay in that gear longer (feels like it's less powerful)
The main reason people rip on the T-56 Six speed is because they have a ratio in first gear of 2.97:1 (depending on the model of T-56, there's a bunch of them with different ratio combinations). That means for every 2.97 times the crank goes around, the driveshaft will go around once. The TR3650 (stock 5 speed in my '04) has a first gear ratio of 3.38:1. Higher ratio means better launches for drag racing, so people rag on the T56 with the lower gear ratio.
But what we're saying is that the lower gear ratio in the T-56 can be made up for on the backside by higher rear end gears. Make sense?
Old November 17th, 2009, 02:39 PM   #35
huggy bear's Avatar
2001 Mustang GT
.23333333 minutes
Thanks man just needed some clarification and its clear now! reps to all yo
Old November 17th, 2009, 02:45 PM   #36
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Also, people don't realize that they can get a T-56 in one of the 1386 models that is basically the exact same thing ratio-wise as a stock mustang trans, except it has the extra gear. It makes up for the huge gap between fourth and fifth on a TR3650. Jazzer posted that little jem
From Jazzer:
Compare the ratios for the TR3650 and the ratios for the T-56 Model 1386.
3.38 - First Gear
2.00 - Second Gear
1.32 - Third Gear
1.00 - Fourth Gear
0.68 - Fifth Gear (Notice the huge gap between fourth and fifth)
3.36 - First Gear < nearly identical to the T-3650/T-45/T-5
2.07 - Second Gear < nearly identical to the T-3650/T-45/T-5
1.35 - Third Gear < nearly identical to the T-3650/T-45/T-5
1.00 - Fourth Gear < identical to the T-3650/T-45/T-5
0.8 - Fifth Gear< check out THIS bad boy, it makes up for the gap that the stock trans has
0.62 - Sixth Gear < nearly identical to the T-3650/T-45/T-5, actually going to get better gas mileage with the lower ratio, but probably not enough to notice
From Danno:
T56>T3650
Old November 17th, 2009, 02:50 PM   #37
huggy bear's Avatar
2001 Mustang GT
.23333333 minutes
a t-56 is ideal then right? cause of the 6th gear? but its heavier right? Also I looked into getting one like 2 years ago and found that I have to do cross member mods and relocate the reverse light wire. is it worth it in thinking that way? Dcook I know you were talking about the torque rating on the t-56 but I have heard of termis pushing well over 500 plus with the 385 you said that wouldn't make any sense since the termis make 410??
Old November 17th, 2009, 02:59 PM   #38
Blown 03 GT
03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough
The weight difference is negligible, as well as the 1st gear difference. The slightly taller 1st will help you not light up the tires when you start putting more power down.
Old November 17th, 2009, 03:01 PM   #39
huggy bear's Avatar
2001 Mustang GT
.23333333 minutes
negligible??????
Old November 17th, 2009, 03:12 PM   #40
Blown 03 GT
yeah it means a small change the has little affect and you wont be able to notice the change.
Threads Similar to: T-3650
T-3650 UnixHH 99-04 34 January 9th, 2009 10:31 PM
3650 tommyd04gt 99-04 2 October 1st, 2008 10:49 PM
My 3650 is different from a 05 3650??? smccoy916 99-04 15 September 30th, 2008 11:57 PM
tr-3650 emgjsdk1 99-04 18 May 10th, 2008 09:23 PM
3650...how much will it take? StuTheMusicEngineer 99-04 1 December 17th, 2006 05:34 PM
