#41 | ||
El Danno
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Since I have a centri blower, I'm not going to make huge numbers at low rpms anyway, so the first gear thing doesnt really matter to me. Even more so since I only drag it a few times a summer. It means that the difference really wouldn't matter, you can neglect it (see the root word there? )
#42 | |
2001 Mustang GT
.23333333 minutes
2001 Mustang GT: 10.5 bullit rims, straight pipes, 180 degree t-stat, rear upper control arms, power slot rotors, hawk pads. fml
#43 |
I love my promotion 3650
![]() Mineral Gray Club Member #2 Just your average 22 year old dumbass If you didn't build your car, and your bragging about it, STFU |
#44 |
2001 Mustang GT
.23333333 minutes
#45 |
El Danno
It also looks like you drag race a lot. A built 3650 might be a better route to go in that situation rather than buying a used T-56 and maybe having to rebuild it anyway. I'm not sure what the price difference is between a new 3650 and a new T56, but if it's not much then why not go with a T-56. You can get one that's geared how you want it. If you really like the gearing in the 3650, get the one that's geared the same except for the extra gear between 4th and 5th.
I think I'm leaning more towards the spirited DD/weekend autocross so I think a T-56 would be a lot better for what I want to do. And Stevi did you build your transmission yourself. If not, according to your sig, you should STFU
#46 | |
2001 Mustang GT
.23333333 minutes
you just got called out yo!
#47 | |
Blown 03 GT
#48 | |
2001 Mustang GT
.23333333 minutes
good info
#49 |
Blown 03 GT
Anyone know if that 108lber can go in our cars?
#50 |
El Danno
I don't see why not, here's the specs on it. T-56 model 1247 108 lbs - Weight 450 lb/ft - Torque Cap 3,460 lbs - GVW Gear Ratios 2.66 1.78 1.3 1.00 0.74 0.5 It's the same specs as the Viper model 1806 except it has a lower torque cap |
#51 | |
I didn't build it but I put the sucker in and tore the old one out. Did my clutch pilot bearing. The thing with the t56. its' the same 6th gear ratio as the 3650's 5th gear. 4th gear ratio's are the same 1:1 in both so for a drag car the difference in mininmal. I personally don't like how tight and notchy the t56 is, thats why I didn't go with it. I paid 1420$ to my door for a carbon syncro'd built to stand my way of driving unit. Only thing different between it and the 750hp unit is that I went wth a 10 spline input shaft. I personally feel that unless you autocross a t56 is just an extra gear you have to shift that isn't worth the extra money. For guys like jazzer the t56 was the way to go.
#52 | ||
El Danno
I know you do a ton of your own work. Building your own transmission probably isn't a whole lot cheaper than just buying one, so you might as well. Plus transmissions are a whole new monster.
I agree, this probably isn't the most cost efficient transmission for a car that sees a lot of drag strip time. Definitely a move to be considered for a car that sees a lot of miles or for an autox car or something like that. For just a weekend cruiser you're probably pissing away money that would do better if put towards other mods. If money doesn't matter though, why not get a T-56? Besides the feel of it (I've never driven one so I don't know) you can get it basically geared the exact same but with the extra overdrive. Jazzer, or anyone else, how much is it for a new T-56? Links would be great! |
#53 |
2001 gt
i am driving my stang as a dd now and with the 4.10's in it, i wish i had the 6th gear on the highway. i hate filling her up every 3 days.
#54 |
3rd Place '11 ROTY
'02 GR-40/SLA Saleen
19.34@42.259
Well, by now my boy Lefty usually chimes in and links my pepes up with the pertinent info, but he seems to be missing in action.
I will track down the link and you guys take a few and listen to some Miles Davis at the Plugged Nickel and the infamous set four from 12-13-65 and ...... reeeeeeellaaaaaxxxxxx a bit ![]() T-3650~T56 swap thread Jazzer ![]() PS.... dcook with some absolutely FAB-U-LUS knowledge dropped for his pepes, yo! |
#55 |
3rd Place '11 ROTY
19.34@42.259
That .8 5th gear of the T-56 is really of no particular use except for cruisin' at sub-highway speeds of 50 MPH or so. I use it going up HWY 101 out of Sausalito to SF and such. Lots of areas around Napa that are in this speed range and had to choose between 2600 rpm 4th or 1600 rpm 5th in my T-3650.
The T-56 and that .8 gear was the purrrfect answer ![]() Jazzer
#56 | |
which one came out of an 03 cobra? |
#57 |
El Danno
1694 Ford Cobra
10 Spline Input shaft 27 Spline Output shaft 425 Torque Cap (no one is real sure what this means, since a lot of termis go over 425 tq on the stock tranny 2.66 -1st 1.78 - 2nd 1.30 - 3rd 1.00 - 4th 0.80 - 5th 0.62 - 6th 32.47 Inches Long |
#58 |
3rd Place '11 ROTY
19.34@42.259
Man.... 2.66 is a tall first gear
![]() One would likely want to go at LEAST 4:10's, if not 4:30's to run that on the 1/4 (I'm not a 1/4 guy, I'm a quarner guy). I cannot tell you much about torque capacity, other than it is ultimately a measurement of the supposed "stress" one can apply to the trans and not break. Depending on how one "applies" that torque, will depend on how long it lasts before it breaks. One could run 1000 HP/1056 T and if you drove your car as I do mine, you could run any trans in the world and not blow it up. My guess is that pretty much 100% of those that run such HP/T numbers, drive their car a bit harder than I do, so buy a trans built for the numbers that feed it ![]() Hitting the 1/4 mile is going to be HARD on the trans, so get one that is best suited for such events. Hit up the drag race forums and search out all the threads of those who 1/4 mile their ride* Listen to SWEET2K as he is VERY much into this endeavor and learned the hard way what works for lauching over time. If you want that taller gear for highway cruising, you are gonna have to go T-56 and be less aggressive on the 1/4 mile. Either that or find someone who will put a .5 final gear in a T-45 ![]() Jazzer ![]() *the booring section of the net
#59 | |
El Danno
I'm not 100% sure but everything that I've ever read says that the 1694 is the tranny that went into the cobras.
Jazzer and Sweet are both going to give you great advice. Sweet leans more towards the 1/4 and Jazzer is more into the cornering aspect, so it's nice to get opinions from different ends of the spectrum. As for me, I haven't decided what the hell I'm going to do with my car. First I though I wanted to drag race it, then I did it a few times and didn't think it was that fun. I looked into doing autocross but there doesn't seem to be many events around here to do. Then I played Need for Speed Carbon and thought it would be a good idea to drift my car, but a drift setup doesnt work too well on a DD and my pockets aren't deep enough to keep buying those tires. Since I'm so undecided, I figured I'll just build a higher HP motor and go from there. After the motor will be a trans, hopefully I have enough money for a built T-56. Then I'll have to decide what I want to do with the car and start re-working my suspension. |
#60 |
3rd Place '11 ROTY
19.34@42.259
twisties twisties twisties twisties twisties twisties twisties
Jazzer.... drawing dcook ever closer to the light
Threads Similar to: T-3650
| T-3650 | UnixHH | 99-04 | 34 | January 9th, 2009 10:31 PM |
| 3650 | tommyd04gt | 99-04 | 2 | October 1st, 2008 10:49 PM |
| My 3650 is different from a 05 3650??? | smccoy916 | 99-04 | 15 | September 30th, 2008 11:57 PM |
| tr-3650 | emgjsdk1 | 99-04 | 18 | May 10th, 2008 09:23 PM |
| 3650...how much will it take? | StuTheMusicEngineer | 99-04 | 1 | December 17th, 2006 05:34 PM |
