Brake (ABS) Question...
Old September 29th, 2009, 07:01 AM   #1
An82Mustang's Avatar
2000 Kona Blue GT Vert
An82Mustang will become famous soon enough
Please tell me I am not the only person that has had this happen... every time that I stop when the car gets to around 1 mph the abs activates for about 2 seconds than the car stops... it is verry annoying... I recently upgraded to the 13" Cobra calipers and rotors in the front but it did this with stock brakes on it as well... There is no ABS light on and no Codes.... Please help...
Old September 29th, 2009, 07:23 AM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Typically, the ABS will only kick in when one or more of the wheels is trying to skid.
Are you braking very aggressively?
Do your tires differ more than 1" in diameter?
I HATE ABS brakes!
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old September 29th, 2009, 11:17 AM   #3
LAWNDART02's Avatar
02 GT
LAWNDART02 is on a distinguished road
I had this happen on a chevy Tahoe-
Turned out to be a wheel bearing was on it's way out and causing additional resitance/intermitent feedback to the ABS sensors.
If you've got a lot of miles on it, that might be something to have checked or replaced.
02 2v 5sp-
9lb KB 2.1L I/C, 90MAF, 75mmStack TB, FLSFC's, Magnaflow C/B, NT555R's, MGW shift, Black Sabbath
Old September 29th, 2009, 11:18 AM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Check your wheel speed sensors. If not that then +1 on Jazzer
Old September 29th, 2009, 06:28 PM   #5
The front and rear tires are the same height and it happens during all types of stopping... hard, soft, slow, fast. I'll have to check the wheel bearings and wss this weekend... Thanks for the tips...
Old September 29th, 2009, 06:38 PM   #6
ajm
Could be a an abs sensor or cracked tone ring.
Old September 29th, 2009, 06:39 PM   #7
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
Also, you may check you balance. You don't want to find out one of your rear wheels is locking up when the others are working just fine.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old September 29th, 2009, 07:52 PM   #8
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
eliminate it (the abs) & be done with it. mine's been gone for two years & I haven't missed it one bit.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old September 30th, 2009, 08:10 AM   #9
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
+1
I had this problem on a Cutlass. It was a cracked abs ring. The sensor read the crack as an additional mark and thought the wheels were turning at different speeds.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Threads Similar to: Brake (ABS) Question...
ABS light and cobra swap question bigred7999 99-04 4 May 6th, 2009 10:30 PM
Abs vs non abs for rear end swap? bansheex 94-95 2 March 17th, 2009 08:09 AM
ABS Brake TCS failure Darwin 2005 - 2010 4 December 15th, 2008 11:48 PM
ABS brake bleeding micldon 99-04 10 August 10th, 2008 01:29 PM
question bout ABS blown96stang V6 Mustangs 3 June 16th, 2007 11:06 PM
