#41 |
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 11 reviews
major props...i could never go that hardcore with weight reduction on my car. Pretty impressive times you were running with a 3400 race weight
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
#42 |
!FACEPLATED!
Thanks Caleb, I'm shooting for 2900-3000
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
#43 |
2003 Mustang GT
12.28 @ 116
i know you can do it. Tim (white99stang) was at 2900 with driver. Ive seen his car in person and it was deffinetelly gutted but at the same time didnt look trashy
#44 |
Proud American
Frank, what are these black boxes you speak of?
#45 |
1994 Mustang 5.0
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
There right behind the Rear tires towards the bottom of the rear pumper and have two little 8 mm bolts holding them in place.The one was so caked with rubber i could not get to the bolts and got pissed and grabbed the box pushed and pulled until i bent the metal bracket that held it and took it the two bolts and half the bracket off in one piece after the bracket snapped, i have no idea what there called or why there even on the car.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- Last edited by 330CubeGt; October 10th, 2009 at 01:40 AM. |
#46 |
!FACEPLATED!
I know what boxes your talking about. Matt, I'll take a picture of them tomorrow
#47 |
2003 gt
5.4 32v on the way
2900-3000lbs... I bet I hit it before you or end up less than you. Pissing contests always motivate for better results, I need someone to beat.
Before asking a gearing related question click THIS link and enjoy all your saved time. Click here for your tuning needs My slow paced budget 5.4 dohc build |
#48 |
!FACEPLATED!
i have all winter, im in no hurry
#49 | |
1994 Mustang 5.0
1996 Mustang V6
Spoken like a true Dick-H
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#50 |
1994 Mustang 5.0
1996 Mustang V6
Im going to be Cruising all winter long
![]() Well if i get this pig to run
#51 | |
2003 gt
5.4 32v on the way
#52 |
saddly i found this thread and i know F8L didnt want me to because ill ask stupid question's like these:
![]() 1. can u go into more details about the trunk lid and making it a pin on, the charcoal canister and lines, dog bone on rear and Hole saw rad supports and other placeslike i said, sorry but im curious
Отряд милиции особого назначения White Mustang Crew Co-Founder |
#53 |
!FACEPLATED!
Nate, why do you want to make the trunk lid pin on? wouldn't make it any lighter. maybe if you did dzus fasteners but they woulding really work with the structure of the truck, maybe if you had just a shell or fiberglass one
#54 |
Proud American
Just weld the trunk shut...
![]() i could not do that because that is where my fuel cell is and my battery.
#55 |
2003 gt
5.4 32v on the way
The dogbone is the weight that hangs on the differential, its cake to remove and weights like 10lbs or so I swear.
#56 |
Proud American
7 pounds....
#57 | ||
1994 Mustang 5.0
1996 Mustang V6
Example Pic: Modular Misfits go to GOOGLE type in"Mustang Weight Reduction" Follor the links plenty of info will pop up,This should keep you busy for a while. +1 for my battery.
#58 |
2003 gt
5.4 32v on the way
Add the bolts too... Whatever, its free weight reduction, and its not scraping away at the chassis for a couple days to remove 5lbs.
#59 | |
1994 Mustang 5.0
1996 Mustang V6
If your gona do it,Do it. if you half ass a weight reduction theres no point in doing it IMO.
#60 | |
Proud American
Then I can take the crash bars out of the doors and the bumper supports and I should be all set.... still all metal or stock body pieces... eventually I will go to a carbon fiber hood, front bumper, rear bumper, and deck lid... but until then I will stick with what i have
Threads Similar to: Weight reduction
| what possible weight reduction? | mystang0673 | 99-04 | 37 | January 13th, 2009 08:12 PM |
| weight reduction | mustang2517 | 99-04 | 24 | October 4th, 2007 03:28 PM |
| weight reduction | ByPopularDemand | V6 Mustangs | 22 | June 13th, 2007 02:15 AM |
| Weight reduction | ByPopularDemand | V6 Mustangs | 36 | April 12th, 2007 12:08 AM |
| Weight Reduction | GTSilver | 99-04 | 6 | September 25th, 2006 12:59 AM |
