best 1/4 suspension setup - Page 2
Old October 28th, 2009, 02:32 PM   #21
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Originally Posted by dcook_14 View Post
So if you slammed the coilover to be as low as it could go, would you risk bottoming out the strut?
That really depends on how much adjustability you have in your coilover, the length of your spring, and the strut you're using. But, yes, you're definitely losing compression travel if you lower the corner as much as possible.
This is on the rear though, I didn't think there was camber/caster/toe with the rear suspension. I'd def. get MMR CC plates for the front.
Oh, I didn't realize we were talking about the rear. You're correct about the lack of alignment settings so long as we're talking about a straight axle rear end; if you have IRS, you have camber and toe adjustability.
O o
/¯/______________________
\_\
TheUNZippee! is right!
Let us all BOW to his unerring ways in a respectful, nay, obsequious manner!
Old October 28th, 2009, 02:41 PM   #22
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Yeah, sorry forgot to specify. So then are there any ill effects of lowering the rear of a stright axle rear end car for street driving, and then raising it to whatever setting for drag racing other than maybe not being able to find the "sweet spot" again?
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old October 28th, 2009, 03:04 PM   #23
The only effect I know that adjusting ride height for the rear is that you'll change your driveshaft->pinion angle.
However, I don't know why you'd *raise* the rear suspension for drag racing. By keeping the rear low, you're keeping the static weight distibution biased towards the rear, which means more weight on the rear tires. More weight = more grip. The only time I could see you wanting to raise it would be if you're hitting the bump stops on a hard launch and that's causing you to go lose traction.
I guess you might also raise it if you don't have any other way of adjusting the driveshaft->pinion angle, but I honestly don't understand it's relation to launch grip, just that it's important.
O o
\_\
Old October 28th, 2009, 03:25 PM   #24
El Danno
dcook_14's Avatar
iTrader: 7 reviews
I don't know a great deal about suspension, and all I've heard is that lowering springs hurt your launches. Since drag springs don't lower your car at all, I just kinda though that a higher rear end would be better for drag racing.
That makes sense though to leave the back end low for launches, since you generally want the back end to squat and dig. Rev Dexter you are a great help, repped!!
Old October 28th, 2009, 03:42 PM   #25
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Lowering springs hurt your lauches because they are stiff, you take car of that with coil overs because you choose a certain spring rate.
Old October 28th, 2009, 03:49 PM   #26
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Yeah F8L that makes sense too.
Why do drag springs not lower your back end then?
Old October 28th, 2009, 04:20 PM   #27
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
my guess is because of the position of the spring (between the control arm and body) more than likely it has to do with the geometry, the control arms in relation to the springs and pivot points. not 100% sure. maybe rev knows
Old October 28th, 2009, 04:41 PM   #28
I'm honestly not sure why they wouldn't lower the back at all.
I can only assume that it has to do with what you've said, or allowing for enough compression in the rear suspension as to not hit the bumpstops, while staying as low of a spring rate as possible (softer springs == more grip).
There may not be a physics based reason at all, it may just be "how it's always been done", or that people don't like seeing a negative rake and won't buy the springs for the aesthetic reasons.
O o
\_\
Old October 28th, 2009, 07:15 PM   #29
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
mounder27 will become famous soon enough
ok, seeing what has been written here, i have a suspension set that cuts 1.6's maybe 1.5's as predicted with my new anti roll bar, first off i just swapped back to the stock springs and cut them to get the center of gravity between the nose and the rear as a close as possible, alright as far as the the lca's and uca's go with any double adjuble set up, i preferre UPR's stuff, good shit plus its less exspensive, now back to what i was getting at the reason for cutting the stockers is to get help with the wait transfer, the lowering springs are ineffeicent because your nose will dive and unload the tires every time you shift gears, there for slowing you down, coil overs to me are the best rout for the front mainly because you can adjust them base on the launches or just for ride height, basicly you want to ass end to be stiff as possible and the front to be loose so you can transfer the weight....
www.wmdracing.net
Old October 28th, 2009, 11:02 PM   #30
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
In your video the nose drives on every shift. You need to shift faster
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old October 29th, 2009, 10:24 AM   #31
What you've said here doesn't make sense to me.
The front being loose in such a manner as to transfer weight to the rear is looseness in rebound, not looseness in compression. If you're having an issue with nosediving, that tells me that the compression is too soft up front, allowing the nose to come down quickly. I can understand not wanting short springs, but wouldn't stiffer springs keep the nose from coming down on you? Isn't this the point of 90/10 struts, that they have really soft rebound, but really stiff compression, so they help keep the nose of the car up?
For the rear, keeping it really stiff is going to hurt weight from being transferred back. I mean, obviously you want it stiff enough to properly support all the transferred weight, but I would think it's a case of keeping it as soft as practicable, as to make that rearward weight transfer as easy as possible.
But, as I don't drag race, this is all theory and no practice. I'm just trying to understand the logic.
O o
\_\
Old October 29th, 2009, 11:41 AM   #32
El Danno
dcook_14's Avatar
iTrader: 7 reviews
I'm with you rev. I've always heard that the best setup is a soft front and a semi-soft back. A stiff rear suspension would kill weight transfer and you wouldn't squat and dig.
Old October 29th, 2009, 01:38 PM   #33
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
You don't want the rear to drop but plant the tires on the track, so a stiffer spring is preferred. Soft springs let the rear of the car drop using energy that could be propelling the car forward.
Old October 29th, 2009, 06:03 PM   #34
! Post Entirely Way Too Much
2000 GT Vert
14.646 @ 97.41 2.37 60' Need to hit the track with my new mods
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
michael youve got the adjustable rear shocks right? strange shocks if im not mistaken. what setting do you have them on at the track?
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
BAMA Performance Drag Team #3
Old October 29th, 2009, 06:32 PM   #35
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
right now they are set at 4, but i didnt get enough track time to get them fully dialed in
Old October 29th, 2009, 06:38 PM   #36
2000 GT Vert
is that more loose or stiff? im guessing loose.
mods/pics
Old October 29th, 2009, 06:59 PM   #37
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
whats the general consensus on control arms? brand? type? next winter I plan to build the rear end/suspension
True blue crew founder/member #1
378/442 rwhp/rwtq...Don LaSota tuned *on a Mustang dyno *
Old October 29th, 2009, 09:04 PM   #38
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
its a tad more loose. 5 would be 50/50 im about 60/40
Old October 29th, 2009, 09:23 PM   #39
If you're sticking with the 4-link, BMR seems to be the way to go. (I like Maximum Motorsports' LCAs, but they're more expensive than what BMR sells and I'm not honestly sure that there's any difference in quality.) For UCAs, BMR sells (at least) 2 kinds, get the adjustable ones with the spherical joint.
If you're going to a torque arm, Maximum can sell you the whole kit (LCAs, TA, PHB), as can Griggs Racing. Griggs' stuff is stronger, but it's definitely more expensive, and I'm pretty sure it requires that you go to either side exhaust or dumps.
O o
\_\
Old October 29th, 2009, 09:30 PM   #40
what do you think od MM LCA's with the adjustable spring perch?
Threads Similar to: best 1/4 suspension setup
suspension setup help DickH Drag 29 August 30th, 2009 06:31 AM
New Suspension Setup F8L GT 99-04 13 April 3rd, 2009 12:55 PM
Suspension setup Zatrekaz V6 Mustangs 3 February 6th, 2009 04:33 PM
best suspension setup? madhandles97 General Tech 1 October 27th, 2007 12:24 AM
Suspension Setup Dawgs2099 99-04 7 May 30th, 2007 11:45 PM
