2001 Mustang GT
NA
Heating Springs?
has anyone done this?
Is it good for the springs, hell is it even safe.... Some guy at a speed shop said he did it instead of buying new springs. |
NO!!!!!!!!!! dont do it!!!!
Heating weakens the springs causing the springs to brake or warp or soften over time. Cut em instead if you dont want to spend the moneys to do it right.lol dont use a cutting torch either ha ha. Heats the springs
Official MM Zeppelineers. Crew member #3
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!
YOU WILL KILL THE REBOUND INTEGRITY BY DOING THIS. YOU CAN GET LOWERING SPRINGS FOR $100 FROM EBAY. Cutting in fine and does very little to the spring, but heating the spring totally ruins it. DO NOT DO IT!!!!!!!! Go to the import forums and read their posts on the subjects and you will also hear NO all over the place. Buy drop springs or coilovers. Don't be cheep you will F up your suspension!
======================= "Adding parts to your car DOES NOT make it a tuner - Increasing performance DOES!" - John Ginieczki |
cutting springs isn't good either. just spend some money and get lowering springs, or if you can, coilovers, your mustang will seriously benefit from this. everybody wants to make their mustang faster, but it's already fast, make it handle.
shadow gray '04 Mach 1 magnaflow X-pipe, black/chrome lip FR500 10.5 deep dish rear, 9.0 front, Steeda front and rear sway bars, H&R springs, lowered 1.6 front, 1.75 rear, smoked headlights w/ clear corners, and V6 badging to fool unsuspecting prey. |
#5 | |
Only buy name brand springs from ebay.. (steeda, BBK Eibach fordracing ect) you get what you pay for. Spending $100 on new or used lowering springs from some place in japan is just as bad as heating them in my book. Same thing goes for any car mod on ebay.
#6 | |
Re: Heating Springs?
I would never step foot in that "speed shop" again. That guy must have taken a life insurance policy out on you. People have done it and people do still heat springs but it is not safe at all. The heat ruins the spring and causes fatigue.
2001 Mustang GT
NA
Heating Springs
Thanx guys.... I kinda figured it was not a good thing...I just wanted to hear it from you guys....Thanx for the in-put I will do what I planned on doing in the first place.... Buying a set of sweet springs..........
#8 | |
And cutting springs does very little to the rebound. Trust me, my buddie is a master tach and 10s 5.0 strip guy and had no problem when i brought up the topic. Been running cut fronts (eibachs) for a year and zero difference in feel. Your call and your discression.
No torches on springs. Cut them with a cut off wheel if you do it. Make sure you do it right too. Its fine if you know what you are doing.
2001 YUGO GT
Due just save your money, and buy a set of springs. Get out from under the shade tree...... W.P.
2001 Mustang GT
NA
What springs.......
Id like to so a full Steeda suspension, fron and rear... Anything I should know?
Threads Similar to: Heating Springs?
| over heating | jersey98gt | 96-98 | 40 | September 20th, 2007 01:54 PM |
| still heating up..... | lwhitetrash88l | V6 Mustangs | 20 | June 22nd, 2007 03:13 AM |
| over heating and knocking | Fox2102 | V6 Mustangs | 14 | June 14th, 2007 03:19 PM |
| over heating? | kreil45 | 5.0 Mustangs | 8 | May 24th, 2007 03:47 PM |
| Heating Vents | dr.gonzo! | 5.0 Mustangs | 2 | October 31st, 2006 02:01 PM |
