BEST spring setup for drag - Page 2
LinkBack (1) Thread Tools
Old November 25th, 2009, 04:21 AM   #21
2001gt's Avatar
2001 mustang gt
2001gt is on a distinguished road
so you dont need your fron and rear sway bar or quad shock if its ment for drag racing? how much was it to have the torque boxes and subframe connectors weld in?
Old November 25th, 2009, 10:35 AM   #22
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
You *might* need a sway bar for drag racing, but not in the front. You can ditch the quad shocks if you go to good tubular or boxed LCAs, and when I had my MM full-length SFCs get welded in, it cost me ~$180 (they decided to charge me by the hour and had some rookie do it who took forever )
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old November 25th, 2009, 11:13 AM   #23
Blackbird1084 will become famous soon enough
I'm running almost all stock suspension except dbl adj uca's,lca's,sfc's and slicks. With just those I cut a 1.67 60ft on the spray. Best on motor is 1.81 I need to take the front sway bar and maybe I could get some 1.7's.
79 Buick regal 13.70 @102 350 sbc
97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir
04 SRT-4 13.42@113.55 2.37 60ft
04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot
06 Mustang GT 12.2929@114.30 2.01 60ft
MM Bracket Racing Crew Member #4
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/141225-best-spring-setup-drag.html
Untitled document This thread Refback January 25th, 2011 09:49 PM
Threads Similar to: BEST spring setup for drag
Drag Spring question laztug 5.0 Mustangs 67 April 28th, 2009 04:42 PM
Question on DRAG spring and shocks? 93HatchsBFF 99-04 12 August 23rd, 2008 02:43 PM
Drag Spring Air bag MustangMatt96GT General Tech 2 May 14th, 2008 12:01 PM
Best drag setup for 91 notch cams-shelbycobra07 General Tech 7 August 13th, 2007 10:13 AM
Drag Suspension Setup? 5.0newbee 5.0 Mustangs 8 March 2nd, 2007 12:35 PM
