cobra tank install - Page 3
Old October 29th, 2009, 12:01 AM   #41
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
The gates fuel line can easily be crimped. You put the hose clamps on there huh? What are your power levels again?
Old October 29th, 2009, 12:03 AM   #42
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
yeah i put hose clamps on it.. it flows a lot better than the focus pump but not good enough.. probably around 450rwhp
Vortech V2 Si
Old October 29th, 2009, 12:06 AM   #43
BakerFX4's Avatar
iTrader: 14 reviews
oh i didnt know you were that high.... in that case, it MAY be getting close to pegging. Definitely swap to the dual pumps. I would just find the complete setup like i have. 250 bucks is not bad. It actually depends on how far you are going with the car and what your goals are eventually. Dont wanna be doing this shit for a 3rd or 4th time.
Old October 29th, 2009, 12:14 AM   #44
1999 Mustang GT
yeah but if i can put the focus pump in then i only have to spend like $25 since i already have the pumps.. i just need a little bit more
Vortech V2 Si
Old October 29th, 2009, 12:20 AM   #45
BakerFX4's Avatar
iTrader: 14 reviews
put it in there and see what happens. Do you have a way of watching it to see if it is running lean. Hell you might start a new fad of mixing pumps just for a lil extra rather than getting the BAP.
Do you have a BAP?
Old October 29th, 2009, 12:44 AM   #46
1999 Mustang GT
yeah bap cranked all the way up and upgraded wiring
Vortech V2 Si
Old October 29th, 2009, 01:14 AM   #47
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
lol someone needs too move too dual gt pumps and a 40a bap!
Old October 29th, 2009, 01:20 AM   #48
1999 Mustang GT
maybe i should do a triple pump combination.. stock gt, svt focus, and gt supercar
Vortech V2 Si
Old October 29th, 2009, 01:25 AM   #49
Boostang's Avatar
1997 Mustang GT
11.01@128.32
lmfao!!! i dont think thatd be worth the time/hassle.. just go with twin super car pumps!
Old October 29th, 2009, 01:40 AM   #50
1999 Mustang GT
lol i was joking
Vortech V2 Si
Old October 29th, 2009, 01:41 AM   #51
Boostang's Avatar
1997 Mustang GT
11.01@128.32
lol ok.. i was just maing sure.. i dont even see how that's work.. ill find out tommmorw
Old October 29th, 2009, 01:58 AM   #52
1999 Mustang GT
im going to try the focus pump with a gt pump so i dont have to buy another pump
Vortech V2 Si
Old October 29th, 2009, 02:44 AM   #53
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Can't mix the pumps, they have different flow curves and respond different to tuning.
And im running the GT pump with BAP (full) and stage 2 fpdm with the 42lb injectors and im fine. With wiggle room. Cant grow much more but it is good for what im at now with 15 psi.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old October 29th, 2009, 03:20 AM   #54
1999 Mustang GT
Since the pumps would be wired together what difference does it make what their individual flow curves are? As a unit the flow should always be the same as far as tuning goes.
Vortech V2 Si
Old October 29th, 2009, 01:10 PM   #55
Trick Tuners's Avatar
KB'd GT
It may work, but it might be asking for trouble too! In theory it would average out, but what if the GT pump pushes more pressure and creates backpressure on the focus pump?
I've never bought the gates hose, so maybe it is $20-30. I knew it was expensive and i thought $5/ft was expensive!! Even the specialty tubing i buy for biotech is not $20/ foot... well except this special gortex tube we use in big pumps. Its $250 a foot and only comes in one foot lengths!
Old October 29th, 2009, 03:57 PM   #56
1999 Mustang GT
If it doesn't work out I guess I will have to do something else. Wouldn't 2 gt pumps each be putting back pressure on each other too?
Vortech V2 Si
Old October 29th, 2009, 04:27 PM   #57
Boostang's Avatar
1997 Mustang GT
11.01@128.32
yes but they flow the same
Old October 29th, 2009, 04:31 PM   #58
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
beieve you have to run 2 fpdm's or a modded single to run 2 gt pumps. you can run 2 stock cobra pumps on stock fpdm. There is more cost than just adding a pump(gt)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old October 29th, 2009, 04:39 PM   #59
Boostang's Avatar
1997 Mustang GT
11.01@128.32
^^ correct.. i run a 40a BAP with dual super car pumps,
Old October 29th, 2009, 04:44 PM   #60
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
mounder27 will become famous soon enough
Ok good thing this thread came up my 255 pump shit the bed last night and i'm going to pick up a cobra fuel tank with the pumps, there is some thing thats needs to be spliced in to the stock wiring harness can anybody give details as to what and how this is done ....
www.wmdracing.net
Threads Similar to: cobra tank install
dropping tank, cobra hat/pumps install.... BakerFX4 99-04 4 June 23rd, 2009 12:40 AM
pics inside cobra tank? SWEET2KSTANG 99-04 14 March 3rd, 2008 07:40 AM
