#61 |
so what happens if one flows more than the other? the smaller pump gets damaged?
i have a modded fpdm
Vortech V2 Si
#62 |
pretty much yes.. cause it will be recieving more back pressure than its putting out..
#63 |
hopefully that back pressure will make more fuel come out of the injectors instead
Vortech V2 Si
#64 |
uh.. i dont think thats how it works lol.. but we;ll see??
#65 |
02 mustang gt
6.92 @ 99 mph 1/8th
do i need to wire in a second FPDM for the twin cobra pumps?
#66 |
or one 40a BAP!
#67 |
the bap would make a fpdm upgrade even more necessary
Vortech V2 Si
#68 |
i hooked a ford gt pump together with a svt pump with the bap and i have plenty of pump left now.. i blew the bap fuse the 2nd time i tried to start the car so i put a 25 amp fuse instead of a 20
Vortech V2 Si
#69 |
99 limited edition vert
you have the wrong bap,you need the 40 amp version for dual pumps
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#70 |
whats the difference between the 2? would a stage 1 fpdm still be able to handle it?
Vortech V2 Si
#71 |
KB'd GT
One is made to drive one pump, and the 40A is for dual pumps. I don't think a stage 1 fpdm will work. You could use 2 stockers.
#72 |
What about a stock fpdm and a stage 1? how would these be wired together?
Vortech V2 Si
#73 | |
El Danno
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
It sounds like you're kinda finding the cheap way out of everything. Think of how much money you've already dropped on your car. What's another $100-$200 to get a proper fuel setup? |
#74 |
If the cheap way works then why spend extra money that I don't have? It cost about $20 to go from a 100% pegged fuel system to 75%. The hose turned out to be $6/ft.
Vortech V2 Si
#75 |
The answer has presented itself in the form of my car not working anymore. I guess one of the fuel pumps died.
Vortech V2 Si
#76 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
lol... i didnt like what you were doing but....
And this talk about the 20amp BAP not running twin pumps is not true. My BAP has been wired in for a while now with my twin pumps with no problems. I know the 40amp is for the twin pumps but i left my bap hooked up when i swapped pumps and all is good. As far as if its helping i dont know but, i know i havent had any problems.
#77 |
I took the bap completely out and it blew a fuse in the engine compartment so i replaced the fuse with a bigger one. Somehow the car still starts but the fuel pressure on the gauge reads zero and according a datalog the fuel pump is at 95%. The fuel tank is completely full so I don't know how I'm going to fix it, assuming that it is the pump and not something else.
Vortech V2 Si
#78 |
The fuses kept blowing when i try to start the car, not while its running or at wot
Vortech V2 Si
#79 |
sounds to me like you are trying to N*g**r everything. Just clean your car up man. If you need something do it right or chances are it will become more of a problem that may end up costing more money and time. Now you have to drop the tank again with a full tank cause you tried to wing it.
Not trying to be mean or anything but just trying to help you minimize some of these problems.
#80 | |
Vortech V2 Si
Threads Similar to: cobra tank install
| dropping tank, cobra hat/pumps install.... | BakerFX4 | 99-04 | 4 | June 23rd, 2009 12:40 AM |
| pics inside cobra tank? | SWEET2KSTANG | 99-04 | 14 | March 3rd, 2008 07:40 AM |
