S/C question
Old October 29th, 2009, 11:45 PM   #1
hollagraphik's Avatar
Shake ñ Bake!
hollagraphik is on a distinguished road
S/C question
im thinking about getting the 2.1 intercooled kenne bell kit soon and just wondering besides everything that comes in the kit what else should i be looking to upgrade/replace. ive read about some replacing the clutch, control arms, rearend rebuilds, and other various things but i dunno for sure what i should be looking to replace, also im gonna run about 10lbs. kenne bell says the kit is made for a completely stock car, which it might be ok, but i says they need to get a reality check. i guess leaving it completely stock would be alright but i think i would be good to upgrade a few things but im not sure exactly what lol. i dont wanna do all this work and then not have a car to drive because of something minor so any advice is much appriciated, thanks.
40th anniversary GT - MGW, SCTX3 93oct, K&N Intake, MAC Prochamber, MAC Catback, March UDP, Mach 1 grille delete, 6k HIDs
Future Mods:
03-04 Cobra!
Old October 29th, 2009, 11:56 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
fuel pump, injectors, MAF, and tune are the things you need. Dont know what all will come with the kit but those are the things that you HAVE to have.
Old October 29th, 2009, 11:59 PM   #3
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
what you change greatly depends on what your intentions are...if you wanna throw on a set of slicks and go racing you had better do some body stiffening, rear suspension, beefed up rear end etc. Clutch is a give in regardless....it just wont hold long lol They claim that a BAP gets the job done but I refuse to believe that so an svt focus pump or a gt pump should do the job. The 2.1 is a really nice kit all in all. Oh, and by all means get a 90mm maf, JLT fenderwell intake (my personal prefference), and a 75mm TB...otherwise it'l be like trying to suck a football through a garden hose lol
edit: if you look in my garage you'll get a better idea of what comes with it and what doesnt and what you'll need etc. my build is on a tight budget so thats the bare minimum lol
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Old October 30th, 2009, 12:03 AM   #4
BakerFX4's Avatar
iTrader: 14 reviews
i was just speaking of things NEEDED to make the car run....
All the other stuff is just other mods.
Old October 30th, 2009, 12:14 AM   #5
I only meant the stuff pertaing to the blower set up. base kit includes everything needed to make the car run and drive minus gauges and a custom tune...but thats it. the only other options on a 2.1 are the big tube intake with 90mm maf and 75mm tb and the other option is polishing. items needed to make it perform the way it should are the big tube kit, upgraded clutch, gauges (fuel, boost, and wideband), sfc's, and a custom dyno tune, and upgraded fuel pump (IMHO). anything past that is unnecessary right off the bat to go out on the STREET and have some fun..but thats just me lol If you wanna go to the track some attention needs to be paid to the rear end/suspension
Old October 30th, 2009, 07:19 PM   #6
Shake ñ Bake!
its mainly going to be a fun street car. a fuel pump versus the BAP sounds like a good idea, as well as the MAF and TB. gauges for sure i forgot to mention those but im definitely getting them, also why is a fuel gauge important if i have one already? as for the intake, will any fenderwell be ok and what size? i will most likely upgrade the clutch as well when i install the kit, what clutch should i look at getting?
Future Mods:
03-04 Cobra!
Old October 30th, 2009, 07:27 PM   #7
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
fuel gauge? i wouldn't worry about that..
AFR, boost, and your choice on the 3rd on it you want 3...
FRPP Big Bore Boss 4V swap coming Winter of 2012/2013
Old October 31st, 2009, 03:00 AM   #8
Shake ñ Bake!
i see a lot of people with 2 fuel gauges so im just wondering if there is something i dont know, to me it seems pointless.
Future Mods:
03-04 Cobra!
Old October 31st, 2009, 09:12 AM   #9
Shake ñ Bake!
are the 36# injectors ok that come with the kit or should i get bigger ones?
Future Mods:
03-04 Cobra!
Old October 31st, 2009, 02:34 PM   #10
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
The ones that come in kit will be fine,actually they are 38's(thats what I recieved). Just buy the kit,install a good cai,75 tb,90mm maf and go have fun. upgrade as power level increase's.
I am running a stock clutch,long block, susp etc and it is holding up great and I don't baby it that much since I have another engine I am putting together for it,in fact, if it blew I might get motivated to finish it
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old October 31st, 2009, 02:41 PM   #11
Blitz34's Avatar
13.907@99.85
Blitz34 will become famous soon enoughBlitz34 will become famous soon enough
iTrader: 11 reviews
Send a message via AIM to Blitz34 Send a message via Yahoo to Blitz34
Technically kenne Bell's kits are complete and come with everything you need.
Its up to you on whether you buy their intercooled kit or not. They should all have the neccessities to install, including fuel injectors, and boost a pump, but you need an maf. Like Baker said though the tune is key. Good tune will make it safer on your car.
Heres the link and it tells you everything that comes with it.
'96-'04 Mustang 4.6 2V 2.1L Supercharger
Old November 1st, 2009, 09:08 PM   #12
Shake ñ Bake!
what are some gauge recommendations? i like the pod that replaces the dash bezel and if i had 3 id get the piece on the steering coloumn, but what are the 3 most people get. i know boost and wideband A/F but whats the other?
Future Mods:
03-04 Cobra!
Old November 1st, 2009, 09:55 PM   #13
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
I have vac/boost and fuel pressure gages. The vac/boost gage reminds me that the supercharger is still working. After almost 50,000 miles I've gotten used to the power and need a reminder once in a while. Besides a boost gage is a suttle way of telling people what your running. I consider the fuel pressure gage interesting but worthless. Under normal conditions the needle swings up and down from 30 psi to 50 psi. I had originally thought it might tell me if I was loosing fuel pressure but it's not like a return style system. You might consider a wide-band AFR gage instead.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 1st, 2009, 09:58 PM   #14
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
mounder27 will become famous soon enough
wide band FTW, you can never be too careful when under boost just a better way to see what the engine is doing....
www.wmdracing.net
Old November 1st, 2009, 09:59 PM   #15
BYAHHHH!
2001 Mustang GT
13.874
the AFR and Boost is IMO the most important. for a 3rd kinda up to u...
Old November 1st, 2009, 10:00 PM   #16
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
i run boost and a/f but if there is a third, i would want to have fuel for sure
www.wmdracing.net
Old November 1st, 2009, 10:08 PM   #17
BYAHHHH!
2001 Mustang GT
13.874
fuel pressure or level?
Old November 1st, 2009, 10:18 PM   #18
Shake ñ Bake!
maybe there is a reason to have fuel pressure, i dont really see the need but i dont know why either. it seems to me that a fuel pressure gauge would be good if you thought it was too low/high but outside of that i dont see the need. wideband and boost for sure, those are give in's but i see a lot of people with 3 gauges so that why i was wondering really. id say wideband and boost are the 2 main for sure and with those you'd be straight but since i dont really know, id like to lol.
whats a good brand for gauges, what size and best place to find em? im not in a hurry to get stuff right away so piecing it together is no issue.
Future Mods:
03-04 Cobra!
Old November 1st, 2009, 10:52 PM   #19
BYAHHHH!
2001 Mustang GT
13.874
autometer 2 1/16 guages.
Old November 1st, 2009, 10:57 PM   #20
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
everything that you need comes with the kit..... minus the tuner....wise to get the AFR and boost gauges, and clutch
2000 kenne bell GT (440HP-432TQ)
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Threads Similar to: S/C question
Exhaust question and tuner question.....dont laugh lol Drick 99-04 19 September 24th, 2009 04:42 PM
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 02:31 PM
Exhaust question + supercharger (warranty) question r00st 2005 - 2010 2 January 31st, 2008 12:07 PM
Muffler question (visual aspect) + Emblem question warrior86 Visual 6 November 20th, 2007 10:55 PM
