synchro problem?
Old November 6th, 2009, 11:48 AM   #1
blue03mach1 can only hope to improve
synchro problem?
In the past my car seemed to have trouble getting into third gear. first i thought i just had a shitty shifter and switched from hurst to i dont remember the name of it but it was pretty good. For about a month it went in fine and when i would be racing or just getting on it in 2nd and shifting into third as fast as i could it would go in fine no problems. Then, third gear started to be a problem again and sometimes it would go in and most of the time it seemed to block me out of third when i would be trying to get into it. This is only at WOT, daily driving its not a problem at all. So i changed shifters again because i didnt really like the other one and switched to MGW(its been in since the middle of just this past summer) and i love it. The past couple days it seems the third gear problem has come back. this morning i got on it and it completely blocked me out. Today,i tried about 4 times getting on it in 2nd and shifting into 3rd and only one time out of the 4 it went into third. What could be the problem? Eliminate the driver part because thats not the problem, i know there is something wrong. I've also tried to push the clutch in for one second and then shifting and it "blocks" me out. I want to say, it wants to push the shifter to the left (into first gear) any thoughts? This is only happens at WOT, from 2nd to 3rd. all other gears are fine.
Old November 6th, 2009, 12:31 PM   #2
anyone?
Old November 6th, 2009, 12:32 PM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Syncro's but could be a bent shift fork. Although the T-45 tranny was more known for bending the shift fork and the 3650 (which you have) is known for the syncro's taking a shit.
Old November 6th, 2009, 12:36 PM   #4
wouldnt you think it would be completely fucked since this has been going on and off for about a year? why would the shifter help get in for a bit and now its having problems?
Old November 6th, 2009, 12:51 PM   #5
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Fluid Change??
Old November 6th, 2009, 12:54 PM   #6
Old November 6th, 2009, 12:58 PM   #7
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Have you done a fluid change at all since you've had the car? / when was the last fluid change?
Old November 6th, 2009, 01:26 PM   #8
ahh i believe it hasnt had a change yet... dont you change it every 30k miles? im not at 30k yet lol
Old November 6th, 2009, 01:54 PM   #9
should it be changed lol?
Old November 6th, 2009, 02:20 PM   #10
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Change the fluid in it and see if that helps.
Threads Similar to: synchro problem?
TR- 3650 "Synchro Kit" scp616 99-04 13 September 14th, 2009 10:55 PM
synchro replacement adrenaline=lifeline 99-04 9 March 27th, 2009 05:29 AM
synchro rev match transmission blakehunter316 The Clubhouse 14 January 4th, 2009 01:43 AM
Synchro position sensor clip? 6stang V6 Mustangs 2 April 26th, 2008 11:59 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
