replacing rear main seal...info?
Old November 10th, 2009, 08:07 PM   #1
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
What all is involved once the tranny and flywheel/clutch are out of the way? a writeup would be much appreciated!
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old November 10th, 2009, 09:11 PM   #2
April 2012 ROTM
no one has ever done one of these?
Old November 10th, 2009, 09:14 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
there will be 2 13mm oil pan bolts that will need to be removed, either 4 or 6 8mm rear main cover bolts that will need removed, a lot of wiggling, and the rear main cover will come off. you may have to loosen the pan enough for the rear portion to drop just a little bit. i have always had motor out every time i had to mess with it.
Old November 10th, 2009, 09:18 PM   #4
April 2012 ROTM
so that cast aluminum piece is just a dust cover more or less?
Old November 10th, 2009, 09:27 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
its the seal housing.
Old November 10th, 2009, 09:28 PM   #6
April 2012 ROTM
ic ic...so this really isnt a big deal to change then?
Old November 10th, 2009, 11:04 PM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
kind of a pain in car.
Old November 10th, 2009, 11:17 PM   #8
April 2012 ROTM
it doesnt sound to rediculous....i think im gonna go for it...Im already there so I might as well lol its seeping just a little and its bothering me lol Im gonna replace the pcv's while im at it too....
Old November 11th, 2009, 08:49 AM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
recommend doing a pilot bearing as well while you are there too.
Old November 11th, 2009, 02:41 PM   #10
April 2012 ROTM
I ordered the seal today...it'l be in tomorrow I put a new bearing in it in July when I did the clutch the first time lol
Threads Similar to: replacing rear main seal...info?
Im Stuck - How do i get this Rear Main Seal out?? The Novice 5.0 Mustangs 3 July 14th, 2009 10:38 PM
Question on Replacing Rear Main Seal The Novice 5.0 Mustangs 5 June 27th, 2009 05:38 PM
Replacing Rear Main Seal 5pointZero 5.0 Mustangs 5 June 17th, 2007 08:36 PM
rear main seal? marks87gt 5.0 Mustangs 4 April 26th, 2007 05:16 PM
Rear Main seal 1gunner23 5.0 Mustangs 5 May 11th, 2006 11:53 PM
