Too good to be true??? 5.4 swap guys.
Old November 16th, 2009, 08:29 PM   #1
norcalam2's Avatar
99 GT & 05 GSXR 750
next year
norcalam2 is a jewel in the roughnorcalam2 is a jewel in the roughnorcalam2 is a jewel in the roughnorcalam2 is a jewel in the rough
Soooo... I found a freshly rebuilt 03 lightning longblock with S/C front cover and oil pan. No tranny, accessories, or tranny for $2300
First off.. My goal is a reliable 400rwhp not too much more and not too much less. Would this be a better way to go than 4v? Ultimately I will be getting the MM max grip box with offset geometry. And I'd like to do some road course/ twisties/ drifting.
Will my accessories and ecu work with the 5.4?
T56 transmission? Better trans options? (I want 6spd)
any other thoughts are appreciated.
NCMM Treasurer/Coordinator
Moto Droid FTMFGDW
MM Cares Crew
GRAMMAR NAZI
Old November 16th, 2009, 09:25 PM   #2
GTermi's Avatar
GTermi will become famous soon enough
make sure its not burning oil or something
My Car- 2004 Mustang GT
Her Car- 2011 V6 Auto Premium
Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide!
Old November 16th, 2009, 10:02 PM   #3
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
My Write-up...
5.4 Swap Write-Up | ::TECH ARTICLES:: | 100% 94-04 Mustang Tech, Articles, Help | SN95Mustangs.com
And thats not to bad of a Price at all...
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old November 16th, 2009, 11:18 PM   #4
norcalam2's Avatar
99 GT & 05 GSXR 750
next year
It's freshly rebuilt 0 miles so I hope it's not burning oil. And thanks for the writeup I was looking for it! Reps
Moto Droid FTMFGDW
MM Cares Crew
GRAMMAR NAZI
Old November 16th, 2009, 11:51 PM   #5
norcalam2's Avatar
99 GT & 05 GSXR 750
next year
330cube, Why do I need to use the 4.6 oil pan? I see that it needs modification but why can't I use the 5.4 pan? Also are there anyways besides X-pipe to raise HP while not raising TQ too much. I don't want to break shit or the tires loose at half throttle. I didn't really understand the flywheel/clutch issue. I will be looking for a T-56 what needs to be done to mate that tranny up?
Is $2400 a good price for a lightning motor?
Moto Droid FTMFGDW
MM Cares Crew
GRAMMAR NAZI
Old November 16th, 2009, 11:58 PM   #6
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
If you are going to do a 5.4 swap, IMO, build up the rear end so that you don't break anything. That and it would be a good thing to do if you plan to drift with it too.
Black Stang Crew #007
Car Built By Me and CraigsList.com
Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads.
More to come! I hope.
Old November 17th, 2009, 12:06 AM   #7
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
the lightning motor will be a torque monster anyways. yes it will be a badass engine and the price is good so long as the engine is good.
you'll have to have a hole in your hood as i've yet to see a hood that clears it.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old November 17th, 2009, 12:23 AM   #8
norcalam2's Avatar
99 GT & 05 GSXR 750
next year
I plan on a cowl hood anyways so that's fine. I have 3.90's should I go down to 3.73's with the 5.4? What's the first thing to go on the rear end? And blackedout, your car is sick.
Moto Droid FTMFGDW
MM Cares Crew
GRAMMAR NAZI
Old November 17th, 2009, 12:28 AM   #9
Thank you.
For the rear end, stronger diff, and axles, the 3.73's will be good as well. You should also look into an axle brace to to help keep things from twisting. You should be fine with an 8.8 rear end unless you want to upgrade to a built 9in rear.
Old November 17th, 2009, 01:12 AM   #10
norcalam2's Avatar
99 GT & 05 GSXR 750
next year
Ya I'm pretty much a newb when it comes to rear ends. the only thing I really know anything about is gears. I'm planning on getting the MM max grip box so I think I will be ok with the 8.8 right? I don't plan on modding the lightning motor too much beyond maybe a pulley, tune, FMIC, and ofcourse exhaust. So that should put me at around 380ish RWHP and 460ish ftlbs. How soon should I be looking at getting a new rear end?
Moto Droid FTMFGDW
MM Cares Crew
GRAMMAR NAZI
Old November 17th, 2009, 02:18 AM   #11
GTermi's Avatar
oh sorry, i almost bought a motor and right before i did the guy was like "oh by the way, it kinda sorta burns oil", just trying to keep an eye out for ya.
Old November 17th, 2009, 02:27 AM   #12
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
Back @ Ya!!
You need to use the 4.6 Pan and Pickup tube.
Reason being the 5.4 pan will hit your Crossmember before the Motor mounts sit all the way down because it is deeper then the 4.6 pan and made for a truck.( I found out the hard way) And if you tryed to use the 5.4 pickup tube like i did you will find out that it hits the bottom of the 4.6 pan because it is a tad deeper.
The pan needs to be modded because the rod caps will hit the fins in the pan the clearances are tight.
The T-56 will bolt right up any tranny that bolts to a 4.6 will bolt to a 5.4.
You just need to make sure you have a 8 bolt flywheel.
IF your looking for low end torque i would say a H pipe or a Pro Chamber but if you rather the HP over the TQ i would go with a X pipe.
$2400 is not bad for a lightning motor if its Rebuilt with low miles.
Just for example i paid $1400 shipped for my motor complete from top to bottom with 40k on it, And then later $700 for the supercharger setup not counting all the other stuff i had to collect to make it work so if i were in your shoes and wanted to do it and had the cash, i would grab the motor being complete it will save you alot of time looking for odds and end parts.
Old November 17th, 2009, 02:36 AM   #13
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
Are you coping me
The Rear is fine, i would consider spending the money and going with a 31 spline unit with new 31 spline axles but not realy needed it all depends on the driving conditions if its just a DD And you Romp on it every so often you will probably be fine.IF your taking it to the track Every or Every other weekend on Slicks or D.Rs its only a matter of time untill it will let go.
Old November 17th, 2009, 04:11 AM   #14
1999 Mustang GT
quiksilver225 is on a distinguished road
should i blow the conch shell one more time???
BBK CAI, March UDPs, Eibach Sportline Springs, MM C/C plates, Koni Yellows, Centerforce DF clutch, FRPP Billet Flywheel, B&M Pro-Ripper Shifter, BBK ceramic LTs, BBK catted X-Pipe, SLP LM1, EBC rotors, 4.10 FRPP gears
5.4 4V coming soon
Old November 17th, 2009, 04:15 AM   #15
99 mustang GT
ForestGRN_Ghost will become famous soon enough
Send a message via MSN to ForestGRN_Ghost
do it.
Old November 17th, 2009, 09:28 AM   #16
Ke^in's Avatar
Ke^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to all
I was told that the new 5.0 engine was basically the same block as the 4.6, with different heads.
If this is true, how hard would it be to convert a 4.6 to a 5.0?
I like to go to Subway because the women there have to make ME a sandwich.
Old November 17th, 2009, 10:30 AM   #17
99 mustang GT
bore it.
stroke it.
Old November 17th, 2009, 11:03 AM   #18
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
@OP, I don't think you're going to be able to drive both road courses/twisties and drift as well. I think (someone correct me if I'm wrong) that for drifting you want the front suspension softer than hell and the back suspension stiffer than hell. I wouldn't want to go diving into corners on a road course with a soft front suspension.
Also if you're drifting, you're proabably going to want an aluminum block. Weight distribution is key for drifting and the Mustangs aren't the best in that department. That's why little 4 banger toyotas with 160 hp can out drift most cars, they are 50/50 weight balanced front to rear. Just some food for thought.
Anyway, that's a good price on the motor. Is that gonna have forged internals? I'm not too familiar with the lightning... The T-56 is gonna be your best bet for a six speed. Jazzer schooled me on them yesterday so he's to credit for the things that I know about them. Jazzer, sorry if I misconstrue anything here. The T-56 comes in a bunch of different flavors, each having their own ratios for each gear. Jazzer runs the 1260 model and loves it. The steps between gears are much more consistent, especially for the 1st/2nd and 4th/5th shift, than a 3650 or T45. I don't really know how fast you usually run around road courses, but I would assume the fifth gear of a T56 with a ratio of .8:1 would be a lot better than having to go into fifth on a 3650 with a gear ratio of .68:1.
I think you'd be fine running the gears you have now. There's not going to be that much of a difference between 3.90s and 3.73s. If you had 4.10s I might step down, but I think you'll be alright. Also I know you'd said that you're worried about breaking the tires loose when you're coming out of corners. If that happens, upgrade your tires and/or suspension!
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old November 17th, 2009, 11:09 AM   #19
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
I would wanna see receipts for the rebuild...other than that it sounds like a pretty decent deal
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Old November 17th, 2009, 04:14 PM   #20
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
<--- *Blows Conch Shell*
+ Back @ Ya!!!
Nothing with these cars are realy hard if you think about it, majority of the swaps, conversions etc can be done on the weekend lol.
And it is, Just a Stroked 4.6 with different heads...
Threads Similar to: Too good to be true??? 5.4 swap guys.
To good to be true?? 87FloridaGT The Clubhouse 16 March 4th, 2009 12:10 AM
to good to be true? thorpedo26 The Clubhouse 13 November 25th, 2008 08:10 PM
Too Good To Be True... oldernewbie The Clubhouse 9 August 6th, 2008 12:49 AM
too good to be true.... atlacatl213 The Clubhouse 17 July 30th, 2008 06:54 PM
WAAAAAAAAAAAAYYYYYYYYY To good to be True newstangmike Modular Mustangs 24 March 19th, 2008 12:48 PM
