k member question
Have longtubes on car and just took out trans to replace clutch. What a nightmare. Had to remove subframe. Want to replace with tubular kmember. Would like info on everything I would need. And also is it really worth it. I was also thinking of getting Shorty headers instead or is that stupid to do
1997 Mustang GT
Faster than an s4
If your replacing the K-member, You might as well stay with LT's. Shorties are for wusses (so old school).
Depending on the K-member you will need new A arms and Coil over. $1400 for complete kit from MM. Or you can find a QA1 or whoever it is that doesn't make you swap your A arms and keep your stock style springs. The result is you lose about 20-30 lbs off the front of the car and a HUGE amount of space. The stock K member is a piece of SHIT sheet metal monstrosity. To do the swap you suspend the engine with a lift of some sort and drop out the k-member. This is also the easiest way to swap out your LT's.
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
Like ModMustang said, there's a couple different ways you can go. UPR has a Kmember kit with A-arms and coilovers for $699 + shipping. I had one on my 03 GT with no issues.
It's a lot lighter and easier to maneuver and if you race at all, you'll notice a difference.
![]() 03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot May it R.I.P. New whip: 1953 Ford Mainline Coupe... let the games begin! |
Boost gets you laid
does the UPR kit come with bushings and stuff? or is there a bunch of other stuff you need for that $699 kit to work
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
#5 | |
Hell, I had a UPR K-member with no coils or A-arms on my 03.
1999 3V GT/2007 GT D/D
corner carver
QA1 has a full kit with A arms, coils, and bushings for 600
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
2003 Mach 1
12.12@112.69
I hear good things about the QA1
Fuck It
corner carver
take that back, it is only $461
I know 3 people that run QA1 on the road course and have nothing but good things to say. The weight redudtion alone is worth the $500
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD Last edited by mustang_gtr_99; November 18th, 2009 at 09:23 PM. |
2003 Mach 1
12.12@112.69
true dat ^
Fuck It
corner carver
I have the kit on order. Add that to the Aluminum 3V I am swaping in will shed at least 150 lbs.
2003 Mach 1
12.12@112.69
yeah front end weight is great to shred off!
Fuck It
2003 Mach 1
12.12@112.69
battery to the trunk is good to do too.
Fuck It
corner carver
Anything to take weight off the strut towers. Well, for road racing anyways. The towers are a week design and dont support the weight of the front of the car
Any issues that you guys have with any of these kmembers?
Noises or knocking or fitment issues? What extra stuff do you need even with the qa1 total kit? Cant imagine it being this easy because its always something. Just want to try to make sure I have everything is there when i do the job... Thanx |
11.10@127.88
![]() iTrader: 1 reviews
I have a QA1 , the ONLY thing I didn't car for was how far the wheels stock out with the stock A-arms and spring. Went to coil overs and shorter tubular A-arms (fox body) and now they're too tucked in, too the point where they rub in full lock turns.
corner carver
struts and CC plates is all you will need if you get the full kit. I helped my buddy install his and it was easy and everything fit perfect. It took a long ass time but no problems with instal or mechanical.
Abyssinian of AX
'02 Saleen
19.34@42.259
CC plates with a tube "K".... NEVER!
![]() (Mod knows wut I'm talkin' 'bout )Jazzer
corner carver
??? explain
jazzer has double a arms.
1997 Mustang GT
Faster than an s4
CC plates are a requirement to get anywhere near good alignment with a tubular K member.
Keep in mind that using camber bolts to get it "close" on a road race car is just stupid. Plus the added strength.
Threads Similar to: k member question
| K Member question | 91Project | 5.0 Mustangs | 14 | May 5th, 2009 10:09 AM |
| K Member Question... | RIDIN5.0 | 5.0 Mustangs | 38 | January 5th, 2009 07:58 PM |
| K member question | 99spaded | 99-04 | 19 | February 29th, 2008 07:08 PM |
| New Member/Question | rsk0528 | 99-04 | 8 | February 13th, 2008 06:38 PM |
| New K-member question | energiesource | 99-04 | 4 | June 24th, 2007 03:47 AM |
