my stock bottom end/tranny
Old November 19th, 2009, 03:28 AM   #1
CougarBullitt6801's Avatar
2001 Bullitt
CougarBullitt6801 is on a distinguished road
With the current setup, my Bullitt is making 410rwhp and 399rwtq. From what I gather reading all the threads, my stock 2v bottom end and t3650 shouldn't have any problems handling the decent numbers I'm putting out. Although my buddy swears I'm pushing the car to its limits. And looking at the dynosheet from JBA, the S/C is hitting upwards of 11psi at 6400+RPM with the 3.33" pulley. This is my daily driver, and I hit 6000+RPM maybe once or twice a day. Will my block/drivetrain be fine for quite some time?
Also, would an aluminum driveshaft be worth my time/money?
Thanks for any inputs, guys
'68 Cougar, non-XR7, 289/3spd
2001 Bullitt #185 (410rwhp/399rwtq)
Old November 19th, 2009, 05:19 AM   #2
01MGGT has a spectacular aura about01MGGT has a spectacular aura about
Not sure about the 11 psi but I have heard of people pushing the stock block further than that reliably. As for the drive shaft, it's less rotating mass so I think it would be worth it. It's pretty cheap anyways. People say they are alot smoother too.
375hp 380tq
Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper
vids
http://www.youtube.com/user/01mggt
Mineral Grey Club member #14
Military Crew E-4
Predator Crew Chief Holloman
Old November 19th, 2009, 05:51 AM   #3
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
You rev your car up to 6k once or twice everyday?
Fire it up, burn it down.
Old November 19th, 2009, 07:29 AM   #4
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
if its your daily driver why you hitting 6k twice daily??
the driveshaft if a good investment and i heard they smooth things out alot especially at higher speeds so for your setup it would probably be in your best interest IMO.
and your block should be ok till around 450-500 safely. anything more than that i think you need to strengthen it (correct me if im wrong here guys)
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
Old November 19th, 2009, 08:48 AM   #5
turbot4's Avatar
R.I.P.
twin screwed!!
turbot4 has a spectacular aura aboutturbot4 has a spectacular aura aboutturbot4 has a spectacular aura about
iTrader: 9 reviews
a few of us are running more than 11psi..........you'll be fine..
Old November 19th, 2009, 11:38 AM   #6
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Depending on how it's tuned, the A/F ratios, the timing, the octane rating of the fuel you rn, and the spark plugs you run 400rwhp would be fine. I'm with these guys though, why are you hitting 6k rpm so often. Around here we call that "beating the piss out of it"
The DS wouldn't be a bad idea. Less rotating mass means you'll get more power to the ground (less drivetrain hp loss), without putting more stress on the engine. You can pick them up fairly cheap on ebay or on some of the classifieds.
Is your car auto or manual? At the same RWHP levels, an automatic makes a lot more hp at the crank.
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old November 19th, 2009, 11:38 AM   #7
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
block is good to 1000+....rotating assembly is good to about 450ish (I have been told the crank is good for roughly 600 though) aluminum DS is supposidly a pretty good mod...
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
Old November 19th, 2009, 11:58 AM   #8
UWISHU1's Avatar
2001
11.10@127.88
UWISHU1 will become famous soon enough
yeah you'll be fine 460rwhp is the highest Ive seen. As long as the tune is good and you run good octane fuel you should be fine. Is your car inter cooled?
And FYI I'm still running my stock 3650 trans making 500+ hp
Bob Kurgan Tuned CLICK
Old November 19th, 2009, 12:13 PM   #9
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
I am with these guys, you are fine for now but not much room to grow without forging.
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old November 19th, 2009, 12:48 PM   #10
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
shit it I had a blower I would be on it all the time...then again I am doing a built block next winter but I would have to much fun!
4V swap in the works
Old November 19th, 2009, 08:13 PM   #11
2001 Bullitt
Ok, maybe not once or twice a day hitting up to 6k. More like a couple times a week. I paid good money for that power, might as well enjoy it once in a while, right? Lol
I got a good, safe tune from JBA over here. My numbers are on 91 octane, and yes, my system is intercooled. I really don't desire to make any more power, as I am happy with the way she drives. I just want to be sure that my stock motor is fine.
But I'm sure if I ever plan to take it to the strip in the future, forged internals would be mandatory.
Thanks for the info. I appreciate it
Old November 19th, 2009, 09:20 PM   #12
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
nice cougar bro. i used to have a 67 Xr-7 4 speed with a 302, it was awesome. i also had a 67 xr-7 GT which i regret selling. but oh well. you should be fine with that power as long as you're on street tires. you will be hard pressed to break any drivetrain components on street tires. i'd get your upper torque boxes reinforced though.
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old November 20th, 2009, 11:08 AM   #13
UWISHU1's Avatar
2001
11.10@127.88
you should be fine then
Old November 20th, 2009, 01:23 PM   #14
2001 Bullitt
Damn, 2 XR-7s? I still need to find out if the 289 in mine is worth rebuilding, or if I should throw in a new motor. First things first, gonna put a T-5 (3spd aint that fun), and rebuild the rearend with 3.55 gears.
Awesome
Threads Similar to: my stock bottom end/tranny
Stock bottom end build evan 5.0 Mustangs 2 April 14th, 2009 09:47 PM
Procharger HO On A Stock Bottom End? killermach1 2005 - 2010 15 December 21st, 2007 03:15 PM
How Much HP On Stock Bottom End 5litercobra 2.3 Mustangs 5 November 13th, 2007 03:55 PM
Nitrous on Stock Bottom End Speedstang302 5.0 Mustangs 25 October 27th, 2007 11:15 PM
How Much HP Can Stock GT Bottom End Take? Clutchmaster 99-04 14 March 22nd, 2007 04:58 PM
