power adders
ok heres whats on my mind for a long time now. i wanna add a power adder i plan to rebulit my 2v motor from ground up. now i'm stuck between super charger or turbo. i know these 4.6s response to boost very good. i've looked at the tork tech kit which i'm leanin towards but i've got friends tellin me to go towards turbos. i'm lost i want more power and need some opinions to help get goin the right way. thanx
I believe turbo is pricey but you maybe able to find some used kits for a good price.
Look at these s/c kits first before tork tech or turbo. Pro Chargers Vortech Kenne Bell Paxton How much power do you want to create though? Whats your plans as in drag or circuit? I would recommend Vortech its what Ive been looking at and planning on putting on my mustang. Some know I was gonna swap to a 5.4 but....vortech can get me to the range i want than spending more on a swap.
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum |
i'm wantin 500hp min 800hp max and its gonna be a daily driver. and as for superchargers im want screw style. i just love the look of the supercharger on top of the motor. i've looked at tork tech and the tvs one they offer.
02 Mustang GT
i run a kenne bell and its the bomb! also the install directions are very detailed for an easy install.
2001 Mustang GT
well above 450 your gonna need to rebuild alot of the engine like rods and crank
yea i planned on a complete rebuild of the motor from the crank to the throttle body. every piece will get attention i'm even thinking about taking the motor from 4.6 to 5.0 or 5.1 stroker
1990 lx
if i were you, i would go turbo. But thats just my two cents. Sometimes you can come out better if you just buy everything you need separate. I got two 60mm garrett T3/T4's for 750 a piece. The only reason i haven't installed them is because i have to get the money for someone to fabricate all my tubing since its a 5.4. But i think you would be able to achieve you 500 to 600hp goal a little bit easier. But then again, some people just like superchargers for some reason.
1990 LX 5.4 coming soon |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
turbos are badass but can make some serouis HP. BUT superchargers can as well, just robs it while making the power.
For your build you will want a 2.6L Kenne Bell, built block(crank, rods, pistons), a entire fuel system upgrade, around 800rwhp tranny work, chassis stiffening, suspension. Its a lot of power. Its great ohave have 400rwhp and 2000rwhp. BUT putting to the ground is all that matter and suspension is not cheap buit REQUIRED!
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone 4V swap in the works |
5.1 Stroker defetnely way too go as for type of boost is depended on your driving style. If want instant power or want to change in out of lanes when some rice out peice of sht tries you lol or even when your dodging people who cant drive and need to move out of the lane that used to be urs your going to hate big turbo, and by instant do mean when the bottom surface of your shoe touches pedal your going to haul ass tha of course you want Charger.
Also if you are going turbo and you want to have full boost at 2500 your going to have to also get cams besides getting perfect turbo and back housing combination and even than you still wont have the response you have right now
![]() Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne http://www.youtube.com/user/MysticCobra04 |
2003 Mustang GT
13.0 @106.79
I went with a stock 03 Cobra Block for my lower end, got it for 1K from a friend and i know for a fact that it can handle plenty over 800 if not more. A strong foundation is def. the key but you also need a nice H/C/I setup also so that you can get optimal boost usage. I could throw on a Vortech V2 on my car right now and just put 12psi through it and ill clear over 500+ just because of my upgraded Heads with 1.84 Ferrea Intake Valves and 1.45 Ferrea exhaust valves as opposed to stock which is 1.73 intake and 1.38 exhaust. Cams will also help alot, but whatever you do just make sure you do a low compression motor like a nice 8:5.1 ratio, which is what stock 03/04 Cobra motors run with...
yea ive looked at cobra bottom ends and stroker kits which i really like. as for rice and gettin in and out traffic is how i drive and goin to the track is what i want. as for suspension i have a friend with a 03 mach 1 which has tried about every part for suspension and tells me that maximum motorsports is the way to go thats how he plants his power and im most likely gonna throw the whole maximum part list at it. as for top end i'm lookin at the new trick flow heads and tork tech intake as for fuel system havent givin it much thought yet still lookin around. but for trans im most likely gonna do a 6 sp fully built swap, its a 5 sp now.
#12 | |
Yeah thats what I figured cuz that what mustangs are for. Maximum motorsports has good suspension for sure. For Fuel all you need is ford gt fuel pumpms and 60 lbs injesctors.
[QUOTE=MustangBryan03;2429401]I went with a stock 03 Cobra Block for my lower end, got it for 1K from a friend
Was this the whole rotory assembly or just block because if it was just the block your friend robbed you blind. there not worth more than $300 like I said just the block.
1999 3V GT/2007 GT D/D
corner carver
Kenne Bell is my suggestion. I dont think I would ever switch to any other FI myself. $0.02
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
99 limited edition vert
I also recomend the KB 2.6l(even the 2.8l)
As far as a stroker goes,steer away from the 5.1, the overbore required (.080+)is not recomended for boost. although you can get 5.0 with a .020 bore and 3.750 stroke it would be better to go with stock stroke with a 3.70 bore(sleeved)
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
BYAHHHH!
2001 Mustang GT
13.874
i wouldn't stroke with boost..do dishes pistons on stock stroke IMO
Penetration before detonation
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
I want BWAL's setup- quad turbos with nawzzzz!
1997 Mustang GT
Faster than an s4
Really the difference here is going to be a couple things
The turbo tends to be a bit more expensive for a complete kit just because you need a tubular K member to fit the piping. After that its all the same. The next difference is efficiency and power curve. The power of a turbo depends alot on your sizing of the turbo and everything. But in general your not going to have its power really kick in untill about 3500 rpm at the lowest. With a KB its instant and constant. If you decide to romp on it at 2000rpm, a KB will have immediate torque and start pulling. A Turbo will run like your normal n/a car untill about 4000 rpm when it will hit like you like a pissed off redneck prom date. The power curves are totally different, but the efficiency of a turbo is unbeaten. At 800 hp your spending 60+ hp to spin your KB. But with a turbo your doing nothing. And then of course the Boner factor. BOV sound, or twin screw whine?
Aztec Gold 97GT. MM CC Plates, Panhard Bar, SFC's & Tower Brace Eibach Sway Bars H&R Race Springs/Bilstein Shocks MAC CAI, LT's, Catted H and Pro-Dumps KB Boost-a-Spark 04' PI Motor Author of The Official Suspension Guide |
1997 Mustang GT
Faster than an s4
Look up Boost Bash on MM&FF. They had a 2 part series on the different types of boost and their curves.
yea ive looked a little more into the stroker kits and at most ill get 40hp and for $2,500 thats not worth it to me. but for the noise i love the whining of a supercharger as for turbo my only downfall is i dont my car sneezing lol as all my friends say get a that car a tissue. as for the fuel system ive read in few things that the ford gt as well as the svt focus fuel pumps will work with the superchargers. also i have been told by my mach 1 buddy to switch out my shortys for long tube headers which i may end up doin. and i'm on kenne bells website all im seein is the 2.1 and 2.6 where do i find the 2.8. also if buy the 2.6 can i bolt it on to my stock block and keep the boost low will it hurt anything untill i do my complete rebuild.
Threads Similar to: power adders
| Power-Adders | inkmanmac | Modular Mustangs | 11 | November 28th, 2007 01:10 PM |
| 12.6 with no power adders or internal engine modifications | gx1856 | 2005 - 2010 | 5 | May 24th, 2007 12:47 PM |
| Power Adders and fuel pumps | marknlori | V6 Mustangs | 1 | May 21st, 2007 11:07 AM |
| Custom Cams and power adders | ghostdog | 2005 - 2010 | 12 | December 26th, 2006 03:15 AM |
| Power Adders? | Mikes88 | General Tech | 1 | October 24th, 2006 09:05 AM |
