12.41@109.48 Cams only - Page 2
Old November 24th, 2009, 01:05 PM   #21
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
wow at the nitrous numbers.... tim aka white99stangs car only made like 450 i think on a 150 shot and his car has a 5.0, stage 2 heads and cams..... im confused...
Old November 24th, 2009, 11:17 PM   #22
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
Originally Posted by jivepepper View Post
I thought you would trap would be higher than 120 then? At 515 I averaged 126-127 and a couple 130.x's in cold fall air. What's your elevation there?
DA on that run was +1050'. The window switch was @ 6200 and shut off the N2O about 50' before the traps. So it probably has a bit more in it. Also remember the nitrous pressure is dropping through the whole run, starts at 1000psi and is 900psi after the pass. A N20 car will not MPH as well as a boosted car because of this drop.
Originally Posted by PapaSmurf View Post
Are you sure those bottle numbers are right? Thats 190 hp over your n/a tune and your on a 150 shot. If those are the numbers then DAMN!
This is not uncommon with CMS Stage II cams.
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old November 25th, 2009, 07:53 PM   #23
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
so cms stage 2 cams are known to produce more hp on a nitrous shot than the actual nitrous jet rating?
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old November 25th, 2009, 10:07 PM   #24
I'm cool..
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
Yes. Due to the larger exhaust duration. It takes out the exhaust mass better and nitrous creates A LOT or exhaust mass. I knew it was better but damn didn't know it was that good.
Super Slow 2012 Grabber blue 5.0...
Old November 25th, 2009, 10:10 PM   #25
JayC's Avatar
2001 Mustang GT
I give my tuner a little credit for the good numbers as well. We spent several hours over the last year on the dyno
Old November 25th, 2009, 10:55 PM   #26
I'm cool..
GTRACER88's Avatar
It's mainly in the tune. It's why your car is together. Propper fuel and a great tune makes numbers and reliabillity. It's what I keep telling people... Superflo dyno huh? Doesn't that read like 10% lower than a dynojet?
Old November 25th, 2009, 11:00 PM   #27
UWISHU1's Avatar
2001
11.10@127.88
UWISHU1 will become famous soon enough
nice work, 2V DOIN IT!!
Old November 25th, 2009, 11:13 PM   #28
JayC's Avatar
2001 Mustang GT
Dynojets usually read the highest which is why they are so popular. The Superflow actually loads the car like real conditions. My numbers are uncorrected so they are more than likely a little high.
Old November 27th, 2009, 11:01 AM   #29
11.463@121.50
saxmanJJ will become famous soon enoughsaxmanJJ will become famous soon enough
JayC, how is your powerband for the street?
I know it works great for the strip, but is it soft on the street until you let the rpms rip?
Old November 27th, 2009, 12:31 PM   #30
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
oh, no, JayC, not the dyno number debate on this forum as well...
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old November 27th, 2009, 04:00 PM   #31
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
nitrous FTW!!! lol
Old November 29th, 2009, 12:33 AM   #32
JayC's Avatar
2001 Mustang GT
I noticed no loss at all. These are not high rpm cams.
Threads Similar to: 12.41@109.48 Cams only
lunati cams vs. houston perf. vs. comp cams mylilboostedpony 99-04 0 September 12th, 2009 06:05 PM
Walbro GSL392 pumps for $109.99, and SX Performance fuel systems Matt Cramer DIYAutoTune.com 0 February 12th, 2009 03:45 PM
12.41 @ 109.35 N/A Auto Bolt-ons 2k05gt Drag 12 April 14th, 2008 11:44 PM
