Anyone ever installed a cam themself? if so....
Old February 19th, 2007, 02:22 PM   #1
MySallyMI is on a distinguished road
When you installed your cam and went to put the timing chain sprocket back on how did you set the timing right? At the moment i have the crank turned 90degrees counter clockwise from TDC, so can bring it back at any minute, but wanted the valves to clear the pistons while im setting the timing on the cams. So anyways if you did it, how did you do it?
Threads Similar to: Anyone ever installed a cam themself? if so....
Installed my Tri-Ax Mach Boy 99-04 24 October 23rd, 2007 07:54 PM
Installed my First Mod Mach Boy 99-04 24 October 20th, 2007 12:16 AM
installed 4.10s 07stanggt 2005 - 2010 25 October 13th, 2007 09:34 AM
got them installed! Steve O 99-04 22 October 8th, 2007 01:20 PM
8.8 installed Roadhawg V6 Mustangs 4 January 16th, 2006 02:41 PM
