Rough Idle and low rpm misfire - Page 2 - Forums at Modded Mustangs
post #21 of 153 Old November 30th, 2009, 02:43 PM Thread Starter
A second test with different multimeter comfirms that the alternator is putting out approximately 13.6 volts with ac on full.
Gamble812 is offline
post #22 of 153 Old November 30th, 2009, 03:27 PM Thread Starter
I also just noticed a sound coming from the rear of the engine. Comparable to a japanese motorcycle at idle in tone, but not volume. maybe a vacuum leak i cant see?
Another idea that crossed my mind is maybe a clogged catalytic converter.
post #23 of 153 Old December 9th, 2009, 09:59 PM
Mike113's Avatar
My car (with a similar problem) is under the knife atm. My mechanic said hes thinkin its the front o2 sensors. I would definitely check into those. When I get it back I'll let you know exactly what he did to fix it and hopefully then for you, you can do the same to fix it.
|Forged Motor||11.1:1 CR||Stage 2 Heads||Custom Bullet Cams||Pacesetter LT's||O/R X||Mac Catback||75mm TB/Plenum||JLT Cai|
317rwhp, 319rwtq
Mike113 is offline
post #24 of 153 Old December 10th, 2009, 02:31 AM
Mustang03's Avatar
yes those are pretty low valuse for a good running alternator. It should be putting out between 14.0-14.6 volts with a load on it. The alternator is causing either a complete misfire or a low spark and thats what causes the studdering and backfiring
Mustang03 is offline
post #25 of 153 Old December 10th, 2009, 02:33 AM
Mustang03's Avatar
when my car was doing this i tried changing the spark plugs and dong everything i could think of and still nothing. Try doing a diagnostic scan on you odometer. i also thought it could be my off road exhaust causing the o2s to send a code throwing my timing off so i tried the spark plug non fowler trick and still didnt fix it
post #26 of 153 Old December 10th, 2009, 02:34 AM
Mustang03's Avatar
your odometer can tell you trouble codes your car is spitting out
post #27 of 153 Old December 10th, 2009, 04:36 AM
BadBlue4.6's Avatar
Send a message via Yahoo to BadBlue4.6 Send a message via Skype™ to BadBlue4.6
I would think the fuel injectors at low rpm they are not putting out enough fuel but at higher rpms the pressure is enough to cause it to flow properly. Fuel injector cleaner is not gonna fix that problem. have is scanned to see if the injectors are pulsing correctly. My buddy is having the same issue but i can't get to it till the 13th of dec. I will post when i fix the issue.
2001 True Blue GT- X-pipe, Full cat back, Throttle Body, Pullys, cold air kit,
BadBlue4.6 is offline
post #28 of 153 Old December 10th, 2009, 04:44 AM
BadBlue4.6's Avatar
also forgot check intake again you can use a dye to look for a leak you could have a leak under the intake that your not aware of.
post #29 of 153 Old December 10th, 2009, 07:29 AM
A few questions:
Did you or a mechanic change the intake manifold?
Where the O-rings replaced on the injectors?
Was one of the injectors dropped accidentally?
Was die-electric grease placed on the wiring connector for the injectors and coils?
Drive it like you stole it
99GT35thLE is offline
post #30 of 153 Old December 10th, 2009, 07:43 AM
Procrastinator
check vacuum, then check/clean your COPs. My car had a problem that sounds very similar, I noticed my cops were dirty when I changed my plugs and half assed cleaned them and I have not heard the miss in a while. Not sure if it cured the problem but its a start.
DickH is offline
post #31 of 153 Old December 10th, 2009, 11:25 AM
Mustang03's Avatar
i checked all that stuff too when my car was doing it and it didnt fix shit you have to replace your alternator because its not giving off a good enough spark to run the engine at idle or lower rpms
post #32 of 153 Old December 15th, 2009, 04:37 PM Thread Starter
i replaced the intake manifold myself. I did replace the o-rings and i made sure I did not drop them or get them dirty at all. I was very careful about that. I also replaced the COP's in the last few days with no improvement. I bought a little handheld computer that gives live PCM data and graphs the data and whatnot. The driver side o2 sensor had a nice little sine curve that tightened up as i accelerate. The passenger side o2 sensor had a rough sine curve that turned into garble BS when i accelerate. Also the long term fuel trim on the passenger side did not change hardly at all when accelerating, while the driver side LTFT varied greatly. However, the driver side LTFT sits right at 25% when at idle while the passenger side is around 0%, varying just a tad. When i plugged the thing into my brother's trans am, both o2 sensors had an identical sine wave, and the fuel trims fluctuated at identical intervals. both fuel trims sat around 0% at idle on his car.
I dont know much about fuel trim or o2 sensors, but it seems to me that this could have something to do with my problem. If anyone thinks it may help, I think i can actually upload the data to my computer and post it on the forums.
post #33 of 153 Old January 13th, 2010, 10:45 AM Thread Starter
Update: Not the front o2 sensors. Replace them and it fixed the fuel trim issue i was having, but it still has the rough idles and misfire through mid range rpms. so here's a list of what its not:
spark plugs
COP's
o2 sensors
MAF
TPS
EGR
alternator
I guess at this point it can only really be a vacuum leak or dirty/bad injectors?
Whats the best way to test for a vacuum leak? And where can i get the equipment for it? and how much does it cost?
A guy at autozone said he saw the same problem with a mustang gt a few weeks ago and it ended up being a small imperfection in the headgasket causing a slow leak. This is the LAST thing I wanna go and try, so any suggestions or opinions on this?
post #34 of 153 Old January 13th, 2010, 01:26 PM
limited's Avatar
swap injector with another one, like on opposite bank, and see if problem follows.pay attention to lower o-ring. have you done a compression or leak down test?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #35 of 153 Old January 13th, 2010, 02:25 PM
im having this Legendary missfire problem also. but on my svo.. im going to test for leaks, and the only way i had come to comclusion was cap of the TB. while at idle and listen for hissing. or if it keeps running then i know i have a major prob. And with your injectors.... i do not believe in injector cleaner when your running 93 octane gas.... think about it. i used gasoline to clean my parts on my car.. and it worked like magic. you really think the injector cleaner will work??? idk that's just . i had a prob with my injectors on my 302 in my bronc. got em supersonic cleaned (if i remember what its called) for like $13 each injector. and omg what a difference! ran soo much better.
also i was thinkin maybe test your ignition coils??? i havnt worked on your year mustang, but one thing that you can add to your list of "things they are not" test your coils. get a DVOM and measure resistance. compare it to specs and see what happens. a weak spark could cause it.
i can get you them specs from SomeData right now. hold on.
MM COBRA MEMBER #75
Spoolin's For sale $h!*
http://www.moddedmustangs.com/forums...es-galore.html
spoolin_84svo is offline
post #36 of 153 Old January 13th, 2010, 02:36 PM Thread Starter
I tested the coils and they are within specs. I even bought a new coil and swapped it around all the cylinders one by one with no improvement. I was thinkin the same thing about the injectors. Always run 93 through em so no point in using injector cleaner.
Did a compression test and all cylinders were good.
fuel pressure test was also good.
I don't even know where to go from here.
also, besides throttle, what affects short term fuel trim?
Cuz now i have a stft problem on one side.
post #37 of 153 Old January 13th, 2010, 02:43 PM
if you are interested there's a TSB for this missfire that shows IN DETAIL ways to go about it. but PM me cuz im not puttin it on here.
***TSB- Technical Service Bulliten (if you didnt know.)
MM COBRA MEMBER #75
post #38 of 153 Old January 13th, 2010, 02:43 PM
limited's Avatar
What makes 93 octane cleaner than 87? actually you will find more additives in 93. 93 will varnish up injectors as easily as 87. fuel inj. cleaner removes this varnish that is put there by the gas/additives so you should use a inj cleaner every now and then, 93 is not self cleaning.
have you swapped injectors?
limited is offline
post #39 of 153 Old January 13th, 2010, 02:46 PM Thread Starter
I did not swap injectors. That would do nothing as the car is throwing no codes so there would be nothing to follow.
post #40 of 153 Old January 13th, 2010, 02:48 PM
limited's Avatar
......The Miss to that cyl..........
limited is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/144613-rough-idle-low-rpm-misfire.html
Mystery Misfire at low RPM not COPs or Fuel? | 4.6L Based Powertrains | Crownvic.net This thread Refback November 20th, 2016 04:40 PM
Mystery Misfire at low RPM not COPs or Fuel? | 4.6L Based Powertrains | Crownvic.net This thread Refback September 2nd, 2015 07:00 PM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback November 20th, 2014 08:17 PM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback November 20th, 2014 06:48 PM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback September 3rd, 2014 02:48 PM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback August 31st, 2014 03:20 PM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback August 31st, 2014 03:15 AM
Mystery Misfire at low RPM not COPs or Fuel? - Crownvic.net This thread Refback August 30th, 2014 02:46 PM
Live Mobile Search This thread Refback December 26th, 2011 07:18 PM
Live Mobile Search This thread Refback December 26th, 2011 07:07 PM
2000 ford 4.6l misfire common problem This thread Refback October 15th, 2010 02:28 PM
