Will my 4.6 2V Modular be okay with 9-10psi of boost off a turbo?
Hello, I am new here. Hope you guys will be able to help me out here since I dont own a mustang, but I own a 2004 Ford Explorer Limited 4.6L V8. At least I am in the Ford family lol?
I am looking to boost my Explorer and I have got a few questions. I normally would ask questions over at explorer forums or something like that but most of them would tell me to find a mustang forum since some of you guys have same engine as mine and had experience with boosting those engines. So I would have better advices from mustang guys compared to explorer guys which most of them are not boosting their vehicles. As far as I know, 99 mustang GTs come with 4.6 modular 2V correct? any other year mustang comes with those engines? Anyway, here is my question- Will I be okay with running 9 to 10 psi of boost from my turbo on my stock engine? I got a STS remote mount universal kit 76mm turbo. I am going to purchase 42# injectors and lightning 90mm MAF. I am interested in purchasing an intercooler or a cooling system for my turbo but I figured that I should go ahead and install the turbo without any cooling system as it is designed to run cooler than normal as I am going to mount the turbo in the muffler area. I am hoping to achieve 9 to 10 psi of boost if possible. Is there any problem in my set up? Is there anything else I should upgrade or look into? I am open to opinions and comments since I am very flexible with what is happening. I am hoping to have it done by January. Sorry about the long post, this is my first post as a member here. Any input would be appreciated! Thanks! Last edited by JarvisB; November 27th, 2009 at 02:34 AM. |
not sure but ik the stock internals on the stangs 4.6 can handle about 400-425 hp if you got pics i would like to see this explorer when its done
Yeah I see that internals might be different. I am trying to get more information on which parts are different, etc.
Down below is a pic of my explorer as of now (I am not even close to 100% completion) It is going to be turbo'd soon and I just got the lowering springs and camber kit so it will go down 2 inches here it is as of now: ![]() and certainly I will keep you updated after I get the turbo in. I've got more performance upgrade ideas on my list, but things will go one by one. I am a broke college student lol. |
I'm cool..
From talking to various turbo companies the average Rwhp per psi is 17-19. Given that info take 19 x 10 psi = 190 rwhp. Add that to what ever your currently putting out which probably is close to 220 rwhp and you have 430 rwhp. For a GT that works perfectly. I'm not to positive on the internals of the explorer. Hovever I am inclined to believe that ford for cost purposes would use the same powdered rods. Also considering that some explorers and GTs were made in the same powerplant leads me to believe that they probably have the same internal rating. Honestly the main killer of rods are the RPMs. However this is just a hunch, using context clues, that leads me to conclude that they have the same power level ratings. Lol. Hope this helps.
Super Slow 2012 Grabber blue 5.0...
Yeah, especially due to the fact that it's driven from your exhaust, you should be fine.
![]() Current mods:
MM Bullitt Crew Founder and Member #1
The modular 4.6 2v is in every mustang GT from 96-04...Most of the GT motors have romeo blocks but in 99 and 00 windsor made a select few of the blocks, this is something you want to know for future mods, the romeo blocks are an 11 bolt valve cover and the windsors are 13. Also the windsor blocks have an 8 bolt flywheel vs the 6 on normal GT's. I know windsor makes the majority of the truck blocks and romeo makes most of the mustang blocks so you most likely have a windsor block. I have a windsor block on my 00 stang and am currently pushing 430rwhp with no problems. Hope this helps!
2.1 KB @11psi B&M Short Throw 36lb Injectors MM Sport Box 75mm Accufab TB Walbro 255lph BBK LT's BBK O/R X Flowmasters FRPP Aluminum DS RAM Powergrip HD Clutch RAM Aluminum Flywheel |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
I would definitely get a front mount intercooler before throwing boost into that thing. The STS turbo kits reduce under hood heat, not the heat of the forced air. The air coming in is still hot (since it's compressed) and that'll lead to dotonation, especially if you're already pushing the limits of the stock bottom end.
Do the Right Thing, Cook. ~Zip. |
2000 gt
imo, 9-10 would be too high on a stock 4.6 with a turbo. the sts kit's, i've heard people say you don't need an intercooler as the long piping acts like an intercooler. i don't buy that, i'm sure it cools down a little bit driving around, but it'd still be very hot. i'd start with like 7-8 lbs, see where you're at powerwise, and if still safe, push it up to 9-10 with a different wastegate spring.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
Sorry, I didn't notice that you didn't want an intercooler. Me, I'd always get one, no matter what.
![]() Current mods:
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Thanks for all of the info.
I might start at 7 or 8 psi to be on the safe side and then I might just push it up to 9 or 10 later on, but that means I will have to have it tuned again lol. For the intercooler, just dont worry, I think I know what am I doing. I am planning on purchasing a fmic in the future but not right now as it is not exactly necessary. But when I step up to higher boost rating, I will definitely get an intercooler, no worries. |
#12 | |
#13 | |
I am curious what are you pushing your stang with? at 430 hp? |
Should I get anything else than 42# injectors and 90mm lightning maf for 7 to 8 psi of boost to begin with?
You need a fuel pump - or a Boost-A-Pump - and new spark plugs.
Weems, I know an intercooler isn't needed, but it's just nice to have. At least, that's my opinion on it.
![]() Current mods:
Which fuel pump would you recommend? I was told that it might be ok with stock fuel pump. But while I am at it I guess I'll just get the fuel pump replaced as well.
it might be ok on ur stock fuel pump if ur goal is too blow it up..
youll need a fuel pump.. im not sure if the exploders have the same fuel pump setups as the mustangs but i would atleast get a 255lph pump.. |
#18 | |
GT40. The stock pump could work with a KB Boost a pump.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
7psi intercooled is safer and will make more then 7psi non intercooled!
#20 | ||
and which one would be a cheaper route- buying a gt40 pump or the KB boost a pump? I am thinking I should go for GT40 while I am at it? I do believe that intercooler is going to be very beneficial but that is not a must so I am going to run without it for now so I can buy injectors, maf, and a fuel pump. So when I got some extra cash I will buy an intercooler. For intercooler, what will I be needing? The intercooler itself, what else? other than fabricating the pipes going from intercooler to intake plenum. and should I get air/air based intercooler? sorry I am still new with intercoolers so fill me in some if you can. thanks Last edited by JarvisB; November 28th, 2009 at 02:12 AM. |
Threads Similar to: Will my 4.6 2V Modular be okay with 9-10psi of boost off a turbo?
| why no boost? come on in turbo experts | daviddunivan | 2.3 Mustangs | 2 | April 29th, 2009 12:03 PM |
| Ford GT Twin Turbo 10PSI break in tune | trev0006 | Videos | 14 | March 20th, 2009 06:01 PM |
| Turbo timers and Boost Controllers? Turbo guys where you at? | 95StangSVT | General Tech | 14 | July 11th, 2008 07:01 AM |
| turbo boost progression | ROUSH STAGE II | General Tech | 23 | March 24th, 2008 10:59 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
