#21 |
!FACEPLATED!
under hood is nothing. Just take your existing pos cable, cut the battery terminal end off, but a ring terminal on it, slid up the little lid on the fuse juntion block, and attact the old positive cable to the stud, then slide the cover back down. And for the new cable, just attact it to the same post on the starter that the other pos cable goes to. and completely disregard the neg cable under the hood. I ran my new neg cable down to where the quad shock bracket was
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ |
#22 |
!FACEPLATED!
and if you want to run at the track, you will have to have a cut off switch also
#23 |
even if I dont run the usual 10.99 or quicker rule?
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno * looking for block busting power...cms stage 3 blower cams on the horizon..[/
#24 | |
#25 |
!FACEPLATED!
you can run the cable up to junction box if you want. but if you look at your factory pos cable, it goes right down the the start from the battery
#26 |
!FACEPLATED!
anything with a battery moved from its stock factory location needs a cut off switch
#27 |
its not gettin a switch so I guess its not goin to the track lol I refuse to put a hole in the trunk lol ok so im runnin a wire from the battery in the trunk directly to the starter then use the existing wire on the starter (stock pos) to give power to the fuse box...correct?
#28 |
!FACEPLATED!
yes
#29 |
you sir have just recieved some reps lol
#30 |
99 GT & 05 GSXR 750
next year
sweet! what gauge wires are you using?
![]() NCMM Treasurer/Coordinator Moto Droid FTMFGDW MM Cares Crew GRAMMAR NAZI |
#31 |
!FACEPLATED!
I used 1 gauge wire
#32 |
99 GT & 05 GSXR 750
next year
cool
#33 |
I have a brail racing battery with a mount for it. It goes where the stock battery goes but it weighs only 17 pounds has 525 crabking amps with 425 cold. Its a lil exspensive but I like it. Go on jegs and check them out. I think there a lil cheaper now too then when I bought mine.
check out my garage for info |
#34 |
Has anyone else seen some ideas for the shutoff switch? The only thing holding me back is cutting a hole in the trunk lid.
#35 |
99 GT & 05 GSXR 750
next year
Ive seen em in the brake lights.
#36 |
2001 Mustang GT
The hole for mine is covered by the license plate. I can remove the handle and only have a small shaft showing.
tuned by SPEEDY DYNO 12.41 @ 109 mph w/ CMS stage II cams 11.13 @ 122 mph NX 150 shot ![]() Launch soft, shift slow, rev low, stay slow
#37 |
99 GT & 05 GSXR 750
next year
#38 |
2001 Mustang GT
#39 | |
Moderator
2010 mustang gt auto
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
#40 |
99 GT & 05 GSXR 750
next year
Threads Similar to: trunk mounted batteries...lets see 'em!
| Optima Batteries | Mr.Stang08 | 2005 - 2010 | 50 | November 24th, 2009 11:53 AM |
| Braille batteries? | fomocoro | 2005 - 2010 | 0 | November 15th, 2009 06:45 PM |
| For w/ trunk mounted Batteries... | flamed 98 gt | 5.0 Mustangs | 33 | February 9th, 2009 11:10 AM |
| help! my batteries keep dieing!!!!!! | xtreme2own | 5.0 Mustangs | 13 | August 8th, 2007 07:08 PM |
