BBK Valve Cover Gasket
Old February 20th, 2007, 05:17 PM   #1
Hotrodvdog is on a distinguished road
Is it supposed to be installed on the head or the valve cover itself?
Old February 21st, 2007, 01:04 PM   #2
punkafi888 is on a distinguished road
does not really matter as long as it is in there. personally i would put it on the cover that way it insures a seal
Old February 21st, 2007, 01:58 PM   #3
Timber's Avatar
Timber is on a distinguished road
Personally, I apply a bead of RTV silicone to the gasket and put it on the valve cover and let it set up. Later on, install the valve cover and gasket on the head. Next time you pull the valve cover off the gasket will come off with it. Most of the time it won't tear and you can reuse it.
http://pic14.picturetrail.com/VOL534/828983/15628081/246397139.jpg
Old February 21st, 2007, 04:05 PM   #4
1999 Mustang
Invictus is on a distinguished road
one side is sticky.. look at the bolt pattern they are not the same. there is only one way the gasket can go on. put the sticky side on first and let it set.. do NOT RTV it at least on the sticky side, it will not bond to it and you'll be in leak heaven.
Old February 21st, 2007, 11:43 PM   #5
MySallyMI is on a distinguished road
Re: BBK Valve cover gasket
+1 except there is a small dab of rtv that i think is needed, where the head and timing cover meet up. I just got done installing mine. What pissed me off bout BBK was, they didnt send enough rubber grommets to replace the old ones.
Old December 23rd, 2007, 12:05 AM   #6
Nemisus's Avatar
Nemisus is on a distinguished road
i'm currently in the middle of installing these! Is there a trick to getting the driver side in place! I can not find enough room to slide the cover in!
Also, in regards to the gasket... the sticky side did no bond at all to the passenger side... what should I do? Since RTV sealer has been deemed bad!
Cheers
Nem
Old December 23rd, 2007, 11:55 AM   #7
Proud American
MustangMatt96GT's Avatar
I heard the drivers side is tough to install, and that somebody has to pull on something to get it to slide in, but I dont know for sure.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old December 23rd, 2007, 12:23 PM   #8
gsjohnson is on a distinguished road
It does matter what side you place the gasket on & do not use RTV form-a-gasket for these valve covers. They are designed to be specifically spaced from the mating surface and they will eventually leak using RTV do to the supplied BBK bolts and torque accessibility. The gaskets must be attached to the cylinder head side, otherwise there is no way for the bolt spacer shims to sit in place without falling off. You will have to add 4 dabs (2 on each side)of silicone underneath the gasket(Cylinder head side) at the timing cover cylinder head seam for the valve cover surface. The drivers side installation is a bitch. You will have to go under the dash a losen completely the brake hydroboost unit. There is 3 bolts under the dash and one on the engine bay side. Don't remove it, just losen the nuts as much as possible so you can rock the booster. That will give you just enough clearance to slide the valve cover on. This is where you have to be careful not to knock one of the valve cover shim spacers out of position. It's a blind install, so be careful. Oh, you will also have to remove the clutch cable and the O2 harness bracket behind the cylinder head besides what the instructions tell you to remove. I took some pics during the install if you think that might help. Hope this helps.
The difference between a girlfriend and wife is about 50 pounds.
Old December 23rd, 2007, 12:29 PM   #9
Nemisus's Avatar
anyone trie and raise that side of the engine... tilting it a bit for a better angle? Might be worth a shot!
I think the gaskets I got were shot from the box.... on one side stuck good enough to the head to stay in place... the passenger side didn't bond at all!
Anyone got any ideas on how to solve that issue? Since using gasket maker is out of the ?
Thanks
Old December 23rd, 2007, 12:59 PM   #10
mjkids's Avatar
mjkids is on a distinguished road
we just installed them on my car, but we did new header and a k member. so my buddy has that tool to drop the engine down so we did it all at the sametime. so it wasn't that bad. but put it on the valve cover.
2000 ford mustang gt convertible
2004 ford lightning truck,,,,,sold
2001 ford mustang/cobra,,,,sold
2008 ford f-350 4x4 truck
1989 ford notch back 5.0
2006 custom build bobber
Old December 23rd, 2007, 03:24 PM   #11
Nemisus's Avatar
how far did you drop the ingine down? Is it easier pull the motor this way? I'm thinking that since I've got some header to do as well I might as well pull the motor... so far I've both covers in, but with the way the gasket are sitting I do not believe I'll ever get the bolts lined up with the compression spacers!
For looks these covers do not seem worth the trouble! However once all said and done I'm sure it will be worth the trouble!
Old December 23rd, 2007, 09:29 PM   #12
I had one gasket that didn't want to stick in some places as well. I wiped the head surface with laquer thinner to insure that there was no remaining oil residue causing them not to stick and that worked for me. There is also a 3m product that you can apply to the gaskets to get them restickyed (Is that a word?) again if necessary. Those gaskets have to be securely stuck to the head surface with the spacer shims perfectly aligned with the bolt holes. The last thing you want to do is have to remove one because you screwed up with the preperation. This is where you've got to do it right. I toyed with losening the motor mounts and moving the motor up and down at the time. I opted for the hydrobooster losening, but I wasn't installing headers at the same time either. I really like the look, but was it worth it? Borderline...Here's 3 pics. The first 2 are of the spacer shims inserted into the gasket prior to installing the valve covers. The last pic is of the final look. I opted for the titanium powder coated versions, rather than the polished(Chrome) or the silver powder coated. Hope this helps.
BBK Valve Cover Gasket-mvc-030s.jpg   BBK Valve Cover Gasket-mvc-029s.jpg   BBK Valve Cover Gasket-mvc-045s.jpg
Old December 24th, 2007, 12:45 AM   #13
Nemisus's Avatar
I got the job done... although I am worried about the passenger side! Before reading any of this I had that side done and did what has said was the worst thing... used Gasket maker to get the gasket to stick! Ofcourse now its too late.... but it did keep me from doing it to both sides!
For the Drivers side I ended up removing the bottem two hydrolic lines... this allowed me to move the Booster assembly completely out of the way! Makes doing the Driver side really easy!
Anyhow... I started the car and let it run for awhile... haven't noticed any leaks... which I know is too soon to tell! And just for the record..... I used "Ultra Blue RTV gasket maker" on the passenger side! Sure wish I had done my research before starting this! I suppose if any leaks to start to appear on the RTV'd cover... its the easiest of the two to remove!
Anyhow... maybe I'll get luck and the cover wont leak?!?
Cheers
Nem
Old December 24th, 2007, 02:05 AM   #14
Well the good news is the pass side is the easiest of the two to replace.
Old December 24th, 2007, 08:47 AM   #15
Nemisus's Avatar
your confindent GSJONHSON that its going to leak?! Was hoping I might get lucky!
Old December 24th, 2007, 11:26 AM   #16
You may get lucky, but with all of the complaints that I have heard that these valve covers always leak, I have found numerous inconsistencies with the installation process, including using RTV. Everyone seems to stray away from installing these things properly due to the difficulty factor. If done right, they do not leak!
Old December 24th, 2007, 11:35 AM   #17
mjkids's Avatar
good to here you got them in good job. i have no leaks in my, so i think you will be fine if you don't see any leaks now.
Old December 24th, 2007, 11:36 AM   #18
Proud American
I would like to see pics! Some with out some stupid round blower in there! LOL
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 11:44 AM   #19
I know you don't mean me...lol
Old December 24th, 2007, 04:55 PM   #20
Nemisus's Avatar
The lighting outside suck... but for now this will give you an idea
as long as I don't get any leaks I'll be happy!
Cheers
Nem
Threads Similar to: BBK Valve Cover Gasket
changed valve cover gasket caintcatchmyGT 96-98 1 November 4th, 2007 01:32 PM
timing cover gasket cali 5.0 5.0 Mustangs 5 August 20th, 2007 08:42 PM
Timing cover gasket, need help fast 99v6stang V6 Mustangs 1 August 6th, 2007 07:08 PM
valve cover gasket terribleonexx88 5.0 Mustangs 5 July 25th, 2007 03:20 PM
Need instruction on gasket on the timing cover OTreborO General Tech 1 June 19th, 2006 02:01 PM
