13.000
![]() iTrader: 1 reviews
procharger help
Hello.. I have a 2000 gt with a procharger@ 10 psi. Dose anyone think i would be safe at 12 psi? also i want to put cobra tailpipes . i like how they look would they hit my diff?
Abe
Boost gets you laid
well i dont have much experience with superchargers but from what i've read i wouldn't go 12 psi on stock internals..
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
2005 Mustang GT
From what Ive read 10 psi is prolly max with stock internals.
2005 Mustang GT | Procharger P-1SC-1 @12psi 501 rwhp, 445 torque ![]() Click here for my latest Dyno Pull MILITARY CREW
HMC(SW/AW) |
13.000
anyone know where i can get good internals? im not lookin to build a drag car tho. THANKS!
Abe
13.000
if i got all the internals off an 03 cobra how much boost can i push it then? safely
Abe
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
forged pistons and good rods a must. i have seen stock cranks go back in and do fine but i recommend a forged crank shile you are there. it would be a good idea a worth the money. after that if you have a fuel system that can keep up and some one to tune the set up you can boost up around the 16-18psi mark and even seen 20psi. all up to you, the terminator set ups are rated to around 600hp on their bottom end. depending on what head unit you have you may need to upgrade to a bigger unit.
#7 | |
1990 GT
the 03 04 cobra rods and crank should handle 1000hp if the rest of your motor is built right for it
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
13.000
sweet thanks evryone
Abe
13.000
O Dose any one know where i can get all the cobra internals?
Abe
MM's nicest mod, :)
you can put 12psi through your motor just make sure its tuned good afterwards with the air fuel at 11.5 across the board. I ran over 12lbs on my stock 85k mile motor for over a year and all i did was kill the rings on my piston but i think thats cause i beat the hell out of it too much and used too much race fuel without being tuned for it.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
Does a cobra engine have the same block as a GT with just forged bottom end? Or is it a completely different block?
2001 Mineral Grey GT - 5 Speed -full bolt-ons, 4.10's
13.000
i KNOW YOU CAN PUT THE COBRA CRANK IN THE GT BLOCK AND NEED TO CHANGE THE FLYWHEEL TO AN 8 BOLT
Abe
the cobra block and gt are different but same design only the cobra has a couple extra holes for extra timing compenets. not all of them are made from the same material
#15 | ||
Don't go above 10 on stock, actually... I wouldnt go 10 on stock. I have a 00 GT and i am calling it quits at 8.
I've heard BAD stories and SEEN bad results of 10PSI on stock.
Threads Similar to: procharger help
| Procharger | flattusmaximus78 | V6 Mustangs | 37 | August 24th, 2007 07:22 PM |
| Procharger & MAF??? | mustang_marine | 99-04 | 13 | August 23rd, 2007 08:20 PM |
| new procharger 99-04 | scubasteve041186 | V6 Mustangs | 7 | February 18th, 2007 02:34 PM |
| procharger f1a | Drgnracin72 | General Tech | 8 | April 15th, 2006 02:01 AM |
