auto drivers with 3.73's - Page 4
Old December 12th, 2009, 01:13 AM   #61
ajm
Originally Posted by Scott2001GT View Post
I see what casper is saying. I think your top speed is abotu 102 or so with stock tires.
When it comes to track times and what works best at the track theres not a person around here id believe over capser he knows his stuff when it comes to the track without a doubt.
Old December 12th, 2009, 01:28 AM   #62
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
this is true ^
Old December 12th, 2009, 07:07 AM   #63
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
Okay im going with 4.10, so let me see if I got it right... I will top about at around 112mph. Is this because of the governor or because that’s as far as the gears in my tranny go?
Im running a normal 17" rim
Black Stang Member #13
315's Crew Founder
My Track Videos
Old December 12th, 2009, 08:51 AM   #64
Stark77's Avatar
2001 Mustang GT
13.2 @ 102 N/A
Stark77 is on a distinguished road
In 3rd gear, with OD off, you will redline at 112-118 depending on how high you rev your engine. I have 3.73's because I drive on the interstate quite often, and at 80mph with OD on I am cruising at 3000 RPM with ze auto.
2001 GT-4R75W, 3.73's,aluminum DS,Mac LT Headers, Mac O/R Prochamber, JLT CAI,Steeda UDP's, PP upper plenum and TB,GMS UCA & LCA.Currently running 50HP jets on a wet kit. Nitto Drag Radials. 265rwhp/299 rwtq N/A
13.1 @ 103 N/A, 1.82 60ft
Old December 12th, 2009, 11:06 AM   #65
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
Redline is 5800 rpms if I remember correctly. The rev limit is set 6200 rpms....
With 4.10's 112 is your rev limit in 3rd gear. you can change your rev limit with a tune but untill you get cams your not making any power up there..and on stock springs.....it's meh
So you would actually start to redline @ about 106-7 and hit the rev limiter @ 111-113 unless you shift into O/D (Which is not good for your tranny...and it's also your longest gear by far...so it's your slowest)
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old December 12th, 2009, 12:19 PM   #66
2001 Mustang GT
So i should just get a t-56....
315's Crew Founder
My Track Videos
Old December 12th, 2009, 02:01 PM   #67
BYAHHHH!
2001 Mustang GT
13.874
I have done over 112 in 3rd but I wasn't paying attention and was at like 6500 rpms haha I first starting hating topping out at 110 to 112 with stock tires and rev. but Then I thought. Ok on the street if I am doing over 90 I am fucked so whats the piont of having to do 130 plus? Also as the track if I am trapping 110 to 112ish you are pretty modded. I am putting a blower and stall in my 4:10'ed AUTO and if I go to the track then I will just use taller tires. I am next year doin cams and LT's and keeping me 4:10s then too. I am going to done to 3:73's when I build my block and go D1sc with spray or an F1 model procharger.
So to finish 4:10s are a great auto gear for street and track IMO and will still be good with a blower and such. You can also do cams and raise your redline and get more out of it also.
Threads Similar to: auto drivers with 3.73's
2 questions..one is only for auto drivers Ryguy33 99-04 27 October 14th, 2009 09:44 AM
all auto drivers out there Ryguy33 99-04 5 June 23rd, 2009 08:10 PM
Auto Zone/ Adv Auto Parts REMAN Engines rusty2407 5.0 Mustangs 19 May 6th, 2008 08:45 AM
drivers window won't stop on auto acobraman 96-98 10 September 27th, 2007 08:38 AM
ok 3:73's or 4:10 Ataylor Modular Mustangs 8 August 14th, 2007 03:12 PM
