12.35 @ 116
Some Vortech Supercharger Questions
I'm looking into getting myself a Vortech supercharger kit, but I am buying the parts separately since it's cheaper and buying a used head unit. I know I need the bracket assembly, discharge assembly, intake, oil feed and oil drain, also injectors and possibly fuel pump. I'm just wondering what else I would need such as MAF wise? Would I want to get a blow through MAF? I want to have a blow off valve blow out to the atmosphere. I'm also hearing things about the IAC on my year model GT's since they're built in the MAF? Any information would be appreciated.
I would sometime like to invest in an FMIC setup for it also.. Last edited by 40thAnnivGT; December 8th, 2009 at 09:20 PM. |
12.35 @ 116
Anyone?
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
get a instrustion manual and see what you need from that. then order from there. I did that with my procharger(to be installed) for them misc items
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
that link should give you all the info you need. good luck
What parts do i need for supercharger? |
12.35 @ 116
Yeah, I have that link saved in my favorites, well, the one posted in that thread.
12.35 @ 116
Wondering if a 90mm Lightning MAF will work with setup? Just trying to get a basic idea of what I need to run 8-9lbs. Also still wondering how the blow off to atmosphere thing works...I'm new to all the centrifugal stuff cause I've only been looking into turbo's and roots style. Any help would be great!
BYAHHHH!
2001 Mustang GT
13.874
The Bypass Valve
Compressor surge is a problem that affects most superchargers and develops when the supercharger is creating boost, but the throttle shaft is closed. Although not a problem on some low-boost (5psi or less) applications This condition can occur under deceleration or while shifting between gears, and can cause the car to sputter and chirp. Under surge, the compressor forces air into the closed throttle body until the pressure inside the throttle body is higher than the amount of pressure being created by the supercharger, and the air tries to pop backward through the supercharger. At that point, pressure is released inside the throttle body and the compressor forces air back through the supercharger and into the throttle body, which again has nowhere to go, and the process repeats. While surge normally is not highly damaging to the engine it is certainly annoying and can cause damage with time. To eliminate these problems under surge conditions, a bypass valve (sometimes called an anti-surge valve) is used to release the excess pressure. The bypass valve is actuated using intake manifold vacuum, which opens the vent valve and releases pressure in the air-intake. Air is either released into the atmosphere (blowoff valve) or recirculated back through the supercharger compressor (bypass valve). How Supercharger & Turbocharger work scroll threw this ^ sounds and what bold words look interesting read it ha.
12.35 @ 116
Ok, now I understand the venting to atmosphere thing which is pretty much what I thought. I was hoping maybe some guys with their centrifugal charged cars would pop in cause I would just like to know how it is setup with a MAF. I'm trying to keep it inexpensive to say the least. Thanks for that write up!
BYAHHHH!
2001 Mustang GT
13.874
howthe BOV and MAF are setup?
12.35 @ 116
Yeah...pretty much everything haha. Cause from pictures I don't see where the hell the MAF goes..
BYAHHHH!
2001 Mustang GT
13.874
is yours before or after the blower?
2003 Mustang GT
Im doing the same thing as you. I bought a used Vortech V1 headunit on eBay for $325.
Im buying the Bracket assembly, air intake assembly, discharge assembly, and oil feed/ drain assembly from superchargersonline.com. Im buying a CX Racing Intercooler, on Buy Ford Racing you can buy 42# Injectors w/ 90mm Lightning MAF. Ford GT Fuel Pump, Wideband Air fuel ratio gauge and boost/vac gauge. V1 Head Unit - $325 (lucky) Assembly for V1 - $745 CXRacing Intercooler - $360 42# Injectors w/ Lightning MAF - $310 Ford GT Fuel Pump - $170 Total - $1,910'ish Minus the gauge's. And Im going to need a new clutch. And I'm sure a few differant things. It's much cheaper this way, and will work just as good. Good luck man
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
12.35 @ 116
BYAHHHH!
2001 Mustang GT
13.874
go with a blow thru setup
#16 | |
12.35 @ 116
V1 S trim, bracket assembly and what not, injectors and MAF, either SVT focus pump or GT, Bypass valve, and gauges and such. I just want to make sure this is everything I really need and want to see how it is setup. |
12.35 @ 116
BYAHHHH!
2001 Mustang GT
13.874
I would suggest intercooled.
12.35 @ 116
So would I, but yet again, I'm trying to keep it as least expensive as i can for now. Once I get more monies saved up after I get everything, then I'll intercool it.
BYAHHHH!
2001 Mustang GT
13.874
You could wait and save up to do it right the first time...or more efficient.
Threads Similar to: Some Vortech Supercharger Questions
| For anyone with a vortech supercharger | theyanks904 | V6 Mustangs | 7 | April 1st, 2010 10:53 PM |
| vortech supercharger | Ryguy33 | 99-04 | 5 | June 23rd, 2009 03:57 AM |
| Vortech supercharger | ia07gt | 2005 - 2010 | 6 | July 4th, 2008 12:35 AM |
| Vortech supercharger | scubasteve041186 | General Tech | 23 | August 25th, 2007 05:43 PM |
| Vortech Supercharger | The eaglenator | General Tech | 7 | September 30th, 2006 12:48 PM |
