#41 |
~C~, The Other White Meat!
im runnin the SCT 2600 and focus svt pump. If I had to do it again, I'd go with the same maf and go with the GT pumps.
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
#42 |
99 limited edition vert
gt40 pumps are single(cobra setups can use 2 and fore setups can use 3) It is not a plug and play pump, the modifications are not hard thou. If you do a search on this forum you should find a how to
I run the gt pump and sct ba2400 maf
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com Last edited by limited; December 11th, 2009 at 01:19 PM. |
#43 | |
![]() will do best I can..remove pump/hat from tank,unbolt fuel connector and sending unit from basket,unplug connector and set hat aside(be careful with the wires to the sending unit)unbolt the top of basket and remove fuel pump,remove stock strainer and rubber mount from pump(will reuse). I drilled 2 7/8 holes on bottom of basket(one was were the check valve is) and several along the front and sides of basket.I did not drill the back,the side with the sock that attach's to the basket,which by the way you can eliminate. take the gt pump out of the white plastic retainer and remove the black fuel line from it,DO NOT TRIM THE NIPPLE ON PUMP. note what term is pos and neg.(there is a + and - on pump) you need this info later.put the rubber piece and stock strainer on gt pump and reinstall in basket,reattach top. remove fuel line from nipple on hat and discard the line and pprv. cut off elect connector and add spade term,make sure it is + to +(old pump should have polarity on it also)attach fuel line(gates) to nipple on hat,be sure to use the whole 1' piece,plug on elect connections,bolt sending unit. now you have to loop the hose so when you hook it to pump and put in tank it does not get crimped. you will see what I mean when you install it in tank.the distance between hat nipple and pump nipple is small(when installed so thats why it is looped).good luck it is pretty straight foward edit-fuel line I was refering to is gates #27093 __________________
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com Last edited by limited; December 11th, 2009 at 02:49 PM. |
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
There needs to be a sticky for this install and that gates fuel line needs to be sure to be in it. I can never remember that gates fuel line number!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
#45 |
02 Mustang GT
9.91@133
95mm pmas meter
Twin walbro return pumps mounted in a cobra hat with 3 -6 fittings. I have 2 -6 feed lines. Each rail has its' own line and a single -6 return line. I kept the frps for logging. I have the 80lb injectors.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
#46 |
yikes ^ lol
#47 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
hold shit that fuel pump will take awhile!
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#48 |
I'm cool..
What about Aeromotive A1000 fuel pump? Or is that to big to have for 450 rwhp for now?
Super Slow 2012 Grabber blue 5.0...
Threads Similar to: Fuel pump and MAF sensors..
| MAF sensors | R0B0T | 5.0 Mustangs | 0 | June 9th, 2008 08:22 PM |
| injectors ,maf and fuel pump | mustangjl | 99-04 | 3 | May 20th, 2008 03:17 PM |
| Fuel pump question. Stock GT pump to GT (supercar) pump. | Nate's4.6 | 99-04 | 15 | May 14th, 2008 02:25 PM |
| maf sensors | JABES | 5.0 Mustangs | 10 | November 29th, 2006 09:47 AM |
