01
Hi.
So i installed my plenum. Now my car surges to 1200 when i start it. It goes like this.
Vrrooooooooom surge surge die. GTRACER88 said it was probably a leak, so i tightened my hose clamps some more but it's too dark outside to see anything else. What else could it be? i will spray carb cleaner to see if the idle changes, but then the car won't idle. It keeps dying. so how else do i check?
U got a leak somewhere, just gotta find it...sounds like a textbook vacuum leak, check everything u installed and find the culprit (get some light too)...if u r gonna check w/ carb cleaner, make sure u do it when the engine is cold (can cause a fire on hot exhaust/motor) and as for how to do it, maybe have a friend hold it at 1500 rpm's?
99' GT 5 Speed Stroked w/All forged Internals Vortech V2 Details in Garage 65' Plymouth Max Wedge Satellite (9.35 @ 154 all motor) 69' SuperBee- Stroked 500cu BB 05' Silverado/Duramax Mid 13's thanks to EFI LIVE |
I Hate Convertibles...
is your maf pluged in? did you unplug the battery for 15 min and plug it back in?
01
the battery was left unplugged overnight. the MAF is in.
48.47@ 12.58
def a vac leak. you missed something.
01
dammit. i don't want to take everything apart again
![]() so should i just disconnect all the hoses and connect them again? or do i have to remove EVERYTHING that i just put on? ![]() sigh.
48.47@ 12.58
come on now. It's isn't all that hard to put on a plenum.
01
no not really. But it took me a day because when i started, it was dark outside, and then i found out that i needed a 10mm deep socket, which i waited till the next day (today) to go out to sears and buy. i guess i'll just poke at it again tomorrow.
Will it eff up my car if i keep trying to start it like that?
2000 GT
Probably a vacc leak like everybody said. Do you have a gasket on the plenum to tb? The manifold has a gasket built into it (pretty sure). If you moved the MAF's position it can cause problems. I have to get retuned if i move mine.
+1 to pretty much what everybody said.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2000 GT
Wont mess it up... just not great to do. You got all the tools now just tear it all apart and triple check it all. electrical connections should make a slight snap sound.
#11 | |
01
i swapped the plenum to manifold gasket too, that orange/red rubber band like thing, although my old one was just fine. I swapped all the gaskets. I did remove the cold air intake tube from the MAF.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
mine surged bad until i got a tune but It rev'd up and down bad and then the rpms would just hang when i did my tb and plenum.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
MM's Orangest
2004 Mach 1 Mustang
EGR? I don't know if it has to be removed on a GT.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
01
Its connected to the plenum
my last question doesnt really matter i guess. look at the back side of the plenum, there is a hose back there. make sure its plugged in. i could see that as an easy thing to miss.
Assistant to the Manager
hmmmm Let's see some pics...and you still have a stock TB right?
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
2011 Mustang GT
12.1 @ 116
Vaccumm leak. Check the one nasty ass hose on the backside of the plenum. That's the most commonly missed one.
Mods in garage. Built suspension and gears since posted times. |
Nah dood I doubt u have a leak. U kno ur shit I don't think u forgot anything. When I installed my plenum and tb it idle WAY high like urs, around 1200-1300 and I took it to a shop and they adjusted it. So just do that or get a handheld tuner and do it that way. Not a technical problem it's a computor problem
![]() Stock Rear Springs FOR SALE! PM Me Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me |
#20 | |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
could also be something with the idle air control ?
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
