Baker Jr.
Pully?
Car made 436 rwhp with no timing and detuned at 11.2 lbs at 5900 rpm with 3.40 pully, Tuner said to drop pully and he only went to 5900 cause the fuel pump wasnt pumping enough anymore, So im putting the boost a pump on it, Wondering if i should go with 3.60 pully or 3.85, Have to get it right so it dont cost me more at the dyno shop. I want to drop the HP to like 415, 3.60 pully and just take it to like 6000 rpm?
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
STFU... i just told you on the phone what you needed to do!!!!! Quit being gay! Daddy knows best! LOL. You dont want that big ass 3.80 pulley at all! You will have to spin the shit out of the motor to get it to hit 400rwhp every time. 3.60!!!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Baker Jr.
I gotta make sure dick lol, Not spending 550 again you know how it is
12.73@111.36
It's a rough estimate but going from 3.4 to 3.6 should drop your boost by 2 psi. With your mods you should still end up above 400 rwhp. A 3.8 pulley will drop you another 2 psi (basically a stock 8 lb pulley). That configuration on a stock motor is around 350 rwhp. With your cams and off road pipe you would get a little more but I don't know if you would hit 400 rwhp.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; December 13th, 2009 at 07:53 AM. |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
why scared of 436? if your tuner is good then your car will be plenty safe at that power and boost level.
2000 gt
i have a 3.85 or 3.80 pulley on mine (can't remember which) and I made 368 hp on 7 lbs. next spring i'm going to get a different pulley, powerpipe it, and get it up to around 9-10 lbs and see what she makes.
go with a 3.6 IMO
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Well Bandit godo things I send you that for your straight up! Win Win there bro!
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
04 mustang gt
7.21 @ 98
my thoughts as well....
![]() cams + 150 shot |
what does that say again scott?? ha
And bandit just doesnt know how to listen!
Baker Jr.
lol stupid baker, but aight guys, and he said 400-410 is safe and i can rag on the car and stuff, he said above that then your risking it with the rods, he said if there is one weak spot it will find it quick, Im going to put it at 415
BYAHHHH!
2001 Mustang GT
13.874
yeah I think the highest I'd go would be 435rwhp TOPS
Baker Jr.
Yeah it did 436 at 5900 and no timing and him trying to detune it cause the fuel pump wasnt giving enough, it started leaning out at 5100
BYAHHHH!
2001 Mustang GT
13.874
yeah I would BAP my single GT pump
Baker Jr.
Ya you should be fine without cams, i made 370 before and he said dont even put headers on this car or anything else cause my pump was 98% used up on the dyno. But baker told me that id be fine that they all say that
but ya you might want to get a BAP if you even go for 390
Baker Jr.
More $$$$$$$ right lol.
Fix the fuel keep the same pully and make sure to run low timing and a rich a/f. I would also run it to 6400 rpm. It should make 470 on a good tune and if you don't beat the crap out of it everytime you see a ricer it will be fine. If you run a SGS tune I wouldn't worry a bit.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Baker Jr.
Lol no way im running 470 jive!!!
mm's nitrous mod
2000 mustang gt
98% and you going to leave it at that? change the pump (or add BAP) and get the duty cycle down! install a set of headers, get the air out of there! moving the air more efficiently will make more power and help make it last. why people so scared if all supporting mods are done? grow a set of balls and make that power safely.
Threads Similar to: Pully?
| Looking at doing a pully swap | 86ttops | 96-98 | 7 | April 20th, 2008 09:11 PM |
| UnderDrive Pully | Mustangrider721 | V6 Mustangs | 5 | April 13th, 2008 10:30 PM |
| cobra pully | RC02GT | 4V / SVT | 40 | March 4th, 2008 05:51 PM |
| Underdrive Pully | motorhead6776 | V6 Mustangs | 15 | November 24th, 2007 05:00 PM |
| alternator pully | notsoslo5.0 | 5.0 Mustangs | 5 | July 31st, 2006 05:34 PM |
