![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
8 rib procharger setup....
I found some part numbers but need some clarifying. Bob.... How did you fit an 8 rib with the blower being so close to the motor. Did you have to space it out further? Maybe shims? Here is the thread i found about it with part numbers. Any additional help would be great!!!
f150 crank pulley (8 rib setup) - MustangForums.com
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
would love EVERY part number needed and what is up with the crank pulley ordeal and being bigger vs. smaller?
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
I've posted this stuff up before, but here you go again Baker. I think this is everything you need as far as pulleys go.
Where to find 8 rib pulleys MPH 8 Rib Kit Info
Do the Right Thing, Cook. ~Zip. |
oh shit... you sure did. Thanks again. Can you tell what is needed for the 8 rib setup on my 2000 windsor? Looks like some confusion. Can you tell what year each post was for. Major reps to you if you can tell me the part numbers i need for mine. Major reps and a great deal on a 3.20 or 3.00 pulley if you ever want one!!
Threads Similar to: 8 rib procharger setup....
| procharger 8 rib conversion FAIL | B0B | 99-04 | 18 | December 16th, 2009 12:10 AM |
| procharger 8 rib setup.... | BakerFX4 | 99-04 | 2 | September 20th, 2009 07:45 PM |
| need help converting procharger to 8 rib | B0B | 99-04 | 0 | June 22nd, 2009 04:01 PM |
| procharger setup | 07stanggt | 2005 - 2010 | 22 | July 16th, 2008 11:56 AM |
| finally going 8 rib setup | sonicblue | 99-04 | 10 | September 7th, 2007 11:25 AM |
