prostars with skinnies
Old December 17th, 2009, 10:40 PM   #1
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i am picking up a set of prostars with front runners...comes with all the lugs and "washers"...just wanted to make sure:
i don't have to get new (longer?) wheel studs correct? just as long as i use the lugs that come with the wheels?
and as far as the front, will i need a spacer? what size? i assume i will be fine with the same spacer that the guy is currently using on his 94 cobra.
anything else i should know? i have heard mixed answers on having to get longer studs or just using the right style lugs.
thanks
cams + 150 shot
Old December 17th, 2009, 10:54 PM   #2
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
I would go with longer wheel studs but its not a "Must have" and the spacers you speak of should work.I would say a 1/4 should be plenty.Thats what i ran with my GW's
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old December 17th, 2009, 11:25 PM   #3
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
sweet.
bump
cams + 150 shot
Old December 18th, 2009, 04:40 AM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
If they are Weld Prostars, Longer wheel studs are a must have to be legal at a track
Old December 19th, 2009, 12:13 AM   #5
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
they are weld prostars but since safety won't be an issue i am not worried about getting longer wheel studs...none of the tracks around here will say anything nor have tech inspection lol so even at the track it won't matter.
cams + 150 shot
Old December 19th, 2009, 12:15 AM   #6
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
fyi i had a car snap 4 our of 5 wheel studs off using the stockers. not saying it would happen to you buy if it were mine i would change them
Old December 19th, 2009, 12:17 AM   #7
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
with what kind of wheels??
btw, i saw you reccommended a 1/8th inch spacer...what are we trying to clear? brakes not a problem right?
cams + 150 shot
Old December 19th, 2009, 12:19 AM   #8
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
the were weld drag lites. and its not the brake caliper, its the part on the caliper bracket that rubbed on my wheels. Mine are jegs, not sure if the weld prostarts are the same
Old December 19th, 2009, 12:26 AM   #9
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
alright...well i will use the spacer then...looked on advance auto website and they listed some so maybe they would have some in stock at the store cause i am getting them tomorrow. although the dude may have the spacers...
and on that note i think i will get the longer wheel studs
these look good...
Products - Latemodel Restoration Supply
cams + 150 shot
Old December 19th, 2009, 07:04 AM   #10
Applehead281's Avatar
2004 mustang gt
13.86@ 100.5 street tires
Applehead281 will become famous soon enough
these look good...
i run the weld draglite 15x5 with longer studs and a 5/8 spacer and have no issues. here is where i got my stuff i got 8 new studs and two billet spacers for like 190 i believe including the stud removal tool and insert tool. Mustang Wheel Spacers with longer wheel studs. Check out our kits. hope this helps these guy specialize in new gen mustang spacers and studs.
The usual bolt on's..
Old December 19th, 2009, 07:14 AM   #11
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 13 reviews
i am running ARP 3 inch wheel studs for my prostars. I would recomend upgrading to some as well especially if you are going to be running the prostars
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old December 19th, 2009, 10:59 AM   #12
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Jegs wheels you dont have to
Old December 20th, 2009, 12:46 AM   #13
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
well i got them on...look pretty sick i must say. and i did a straight trade so got them with no money involved
and the fronts did NOT fit even with a 5/16" spacer...we had to cut the bar on the caliper bracket off and use the spacer which thank goodness i picked up just in case (15 bucks for both at pep boys )
i will probably order the 3" wheel studs and knock them in when i get a chance...sure wouldn't hurt to have the added strength and espcially with the spacer up front
cams + 150 shot
Old December 20th, 2009, 12:47 AM   #14
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
that thing looks bad ass
Old December 20th, 2009, 12:51 AM   #15
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
what size tires front and rear??
Old December 20th, 2009, 12:54 AM   #16
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
295/50/15 in the back
165/?/15 up front
cams + 150 shot
Old December 20th, 2009, 12:55 AM   #17
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
looks good. cant wait to get mine on
Old December 20th, 2009, 01:04 AM   #18
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
thanks...you'll like them
cams + 150 shot
Old December 20th, 2009, 01:07 AM   #19
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
my rears are going to be a tad bigger
Old December 20th, 2009, 01:13 AM   #20
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
i gotcha...
i'm not sure if i will do 275's or 325's on the next set lol... either would work
cams + 150 shot
Threads Similar to: prostars with skinnies
Skinnies up front 06GTMustang89 2005 - 2010 4 August 13th, 2009 04:37 PM
Skinnies ivan48humble 2005 - 2010 11 December 15th, 2008 02:01 PM
Skinnies? jivepepper 99-04 2 October 10th, 2008 11:41 PM
driveability with skinnies BWAL 5.0 Mustangs 25 July 5th, 2008 10:08 AM
Skinnies Modern_Muscle 2005 - 2010 2 May 27th, 2007 08:39 PM
