2002 mustang GT
will a short shifter feel smoother
Yea, as the title says, i know the throws will be shorter, but will they be smoother, like silky, mines already pretty smooth, but i would like to know before i spend 200 bucks, any opinions on the Pro 5.0 for the t-3650?
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
PRO 5.0 or MGW are the only 2 options in my opinion.
And no a short shift gives you a SOLID Feel.Gets rid of all the sloppiness of the stock shifter and actually makes you feel like your driving the car so to speak. Great upgrade over stock any day.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
No personal experiance with the pro 5.0 but my buddy has a MGW and that thing goes in and out of gear like butter and it's so tight u just barely touch it and it goes in gear so smooth. Unlike the stock shifter, where u have to put sone decent force into shifts. Don't get me started on the notchy feel of that stocker
![]() Stock Rear Springs FOR SALE! PM Me Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me |
2002 mustang GT
i still dont get it though, how does the shifter make improve feel, it just seems like the same thing, just a shorter throw. Isnt it properties of the transmission that determines the smoothness or notchyness?
That is a good question.. Not sure but maybe better quality materials?
2002 mustang GT
because i have seen the shifter, and i dont see any actual mechanism or difference other than a shorter handle?
Looks can b decieving my friend
2004 Mach 1
12.57 @ 111.72
mine still feels notchy, just feels more solid. stock shifter has a rubber block in it iirc, making it feel a bit sloppy but probably absorbs some vibrations or w/e
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light 2004 Mustang GT - Sold |
Safud: MM's Resident Hadji
My sixxer has a stock shifter and my cobra has a MGW (i believe that is lol). The sixxer feels extremely sloppy and moves around a lot. The cobra on the other hand is very sturdy and sharp so to speak. When you shift in the cobra it actually makes noticeable clicks as it moves.
I could get a video shifting both the sixxer and cobra and i'm sure even in a video you'd be able to tell how much difference there is |
I'd like to see that brutha!
![]() I personally can't wait to get a MGW for my stang
#11 | |
), so i'll get a vid when I get home
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
stockers use plastic bushings that wear, after markes ones dont. that is why they feel so solid. sorry to be out of my 5.0 section but thought another opinion would help. I have a tri ax in my car. it is very similar to pro 5.0. it was in there when i bought it. if i had to buy another, it would be the mgw because it is more adjustable to suit the driver. i am happy with my tri ax though.
2004 mustang gt
13.86@ 100.5 street tires
i have the pro 5.0 and it is just all around a lot more solid and i neeeeever miss a gear its nearly impossible. its not as smooth but i love the solid feel when you go into a gear it is a bit more notchy than the stock one but i will sacrifice a little comfort to save my tranmission cause the 2 to 3 shift in these cars are brutal on the tranny without a aft. shifter. i bent my shift fork with my sloppy stock shifter, get you a shifter sooooooon!
![]() The usual bolt on's.. |
2001 Mustang Bullitt
My MGW is just shorter throws...I complained that it didn't "feel like butter" like other said it would, unless you are sitting still or driving at WOT...all the other times of regular driving, there is some resistance when going into gears.
The MGW has a very strong centering spring which makes popping the car in N or 3 pretty easy. When you shift with an aftermarket shifter the shifts are in a straight line, there is no play in the gear, where you can move the stick around at all. Very tight, very precise. The MGW is pretty notchy and tight the first few weeks, but after that its pretty smooth. I can't imagine a better shifter. Also, if you take the stock shifter out and compare between the aftermarket and stock, you'll find that there are a lot less bushings and rubber, and the little "dradle" that slides through the H pattern, is different.
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
Threads Similar to: will a short shifter feel smoother
| short shifter 4 a t-5? | 87merkur | 2.3 Mustangs | 10 | March 15th, 2011 01:07 PM |
| ok so i want a short shifter | gordon norris | 5.0 Mustangs | 18 | October 20th, 2007 11:45 PM |
| Short shifter | kampa | V6 Mustangs | 2 | July 22nd, 2007 09:59 AM |
| What is the best short shifter? | MonsterSD | 5.0 Mustangs | 11 | June 15th, 2007 04:50 AM |
| short shifter | jagstang96 | 96-98 | 2 | December 8th, 2006 11:04 AM |
