Forged Internals
LinkBack (2) Thread Tools
Old December 19th, 2009, 01:13 PM   2 links from elsewhere to this Post. Click to view. #1
Hawaiianbro will become famous soon enough
Send a message via AIM to Hawaiianbro
Question
Forged Internals
Ive been looking to go boost since the power range I want can be done with the 4.6 so to get to my questions.
Im taking my motor in the future and replacing these parts.
All Bearings will be replaced Pistons, Rods, Studs, Keeping stock crank, Gaskets, and other parts etc
Ive been on the Cushman Motorsports website and they have a kit that seems good.
ACE forged H-beam rods
Keith Black forged pistons, rings and rod bearings
handle up to 500hp.
Ive heard of Keith Black and they seem reputable but never heard of ACE though are Keith Black and ACE good forged parts??
I was just wondering if there any good.
Stock Piston CC is 17 correct????
Ill be slapping a Vortech s/c kit aftercooled on. The range I want to reach is 400-430rwhp. I know some of you with vortech kits have reached this range safely on a stock motor.
Im looking at doing the build and s/c at once only cause I want reliability and dont want to dig through the engine bay twice.
B&M Short Shifter / Ford Heavy Duty Clutch / 3.73 gears / Nitto Drag Radials / Steeda CAI / Diablo Tuned / Mac LT Headers / Lethal Cated Xpipe / Pypes Exhaust / Smoked headlights and Tail lights / GT floor mats / PP 70mm TB / Accufab Plenum
Old December 19th, 2009, 01:17 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i would say yea those parts will hold you over at a 430 range. If our stock parts can do that then those forged parts definitely will. I have 150,000+ miles on my car and its been supercharged since about 125,000 miles. Not one single hiccup in my motor and that is at 427rwhp. You really wouldnt be going into it twice. Im just now starting another build for my motor and as you are, i am using my stock crank. But i plan on 550-600rwhp with some good size boost.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old December 19th, 2009, 01:23 PM   #3
Yeah true I figured if our stock internals can a forged parts can. I was hopping you chime in. haha Cause I know your working on a build as well you had alot of miles on your engine.
On your build what cc pistons are you using? I figured I go with 17cc pistons...havent decided if Boring would be worth it.
Also whats the difference between a H beam rod and a I beam rod? I know one handles more power better correct?
Old December 19th, 2009, 01:26 PM   #4
BakerFX4's Avatar
iTrader: 14 reviews
18cc manley pistons w/ rings, MMR 4340 Hbeam rods w/ arp rod bolts, Clevite bearings. H beams are more stout i hear. There are some billet I beams that are better than the 4340 forged H beams.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old December 19th, 2009, 01:31 PM   #5
Ah ok I see. I figured H beams since everyone goes with that.
I have a Feeling I may go Manley everything since the shop that I spoke with to do my engine build uses those parts. So far they where pretty good, getting a deal to get my whole suspension set up as well my rear end and now my engine. I have to go to a body shop and talk about paint and paint on CF.
Thanks for the info and help man +1 rep
Old December 19th, 2009, 01:41 PM   #6
Boostang's Avatar
1997 Mustang GT
11.01@128.32
Boostang will become famous soon enough
Send a message via AIM to Boostang
cant go wrong with manley
If It Dont Flow It Wont Go!!!
forged pistons,teksid block and a romeo cast cranks for sale.. pm if interested..
selling them for next too nothing
Old December 19th, 2009, 02:44 PM   #7
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
I would stick to more of a name brand company for hi-po parts. Keith black makes a hell of a hemi but their piston line is more for the budget minded(less on quality), most of their line is stock replacement. ace rods? maybe cost effective but not something I would want in my engine, to each their own I guess.
build your engine the strongest you can afford even if your plans right now are not that high. Go at least 600( i would not go lower than 900 imo), remember these ratings are fwhp and not rwhp
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old December 19th, 2009, 02:56 PM   #8
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
i own and operate a peformance shop in southwestern Pa, and i have a few customers that use kb pistons because they are cheap to buy... Of all the different pistons i have seen in use, i have seen the most problems with kb, the ring lands crack apart at any sign of detination! I know kb has been in buisiness for a long time and they make really good high end stuff but the lower lines seem to be crap. I feel the best thing to do is to buy a short block already assembled from mmr or someone reputable...just my .02$
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old December 19th, 2009, 06:57 PM   #9
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
+1. 03/04 cobra's got 'em
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old December 19th, 2009, 07:59 PM   #10
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
A stock shortblock can be built to hold 600rw for under $2000. My spare forged teksid shortblock will only have about $1000 in the build.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old December 19th, 2009, 08:24 PM   #11
I'm cool..
GTRACER88's Avatar
GTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura aboutGTRACER88 has a spectacular aura about
Ill buy your spare engine ^^ ill make good use of it. Ill give you $1001.
Super Slow 2012 Grabber blue 5.0...
Old December 19th, 2009, 08:31 PM   #12
limited's Avatar
yes, if you do some smart shopping and assemble it yourself you can build a good motor for cheap.
I will have less than $2500 in a teksid stroker with billet rods,cp pistons,cobra oil pump/billet gears moroso pan and all studs. engine should handle 1100hp
Old December 20th, 2009, 06:23 PM   #13
Thanks for the info.
Yeah Im going to be going all Manley. Im looking at talking to a shop this week and have them budget a build to 600 and 900 and see the price difference.
Thanks +1 rep to everyone
Old December 20th, 2009, 06:38 PM   #14
BakerFX4's Avatar
iTrader: 14 reviews
if you are going all manley then the only determining factor between 600 and 900 will be the crank. Cast=600 forged=900. Price difference of about 350-400 give or take.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old December 20th, 2009, 06:52 PM   #15
Barracuda is on a distinguished road
Get a Forged Crank...spend the $300...they are bulletproof and no worries, your going through the whole motor anyways. I've built alot of motors and this is one spot I would not save some pesos on.
99' GT 5 Speed
Stroked w/All forged Internals
Vortech V2
Details in Garage
65' Plymouth Max Wedge Satellite (9.35 @ 154 all motor)
69' SuperBee- Stroked 500cu BB
05' Silverado/Duramax Mid 13's thanks to EFI LIVE
Old December 20th, 2009, 06:55 PM   #16
GTermi's Avatar
GTermi will become famous soon enough
I got a Cobra crank for sale if u r interested :-)
My Car- 2004 Mustang GT
Her Car- 2011 V6 Auto Premium
Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide!
Old December 20th, 2009, 06:57 PM   #17
^^^^^ get that....Ford felt it important to go Forged
99' GT 5 Speed
Vortech V2
Details in Garage
Old December 20th, 2009, 08:21 PM   #18
y2k02's Avatar
02 Mustang GT
9.91@133
It is not needed if staying under 600rw. Use the $300-400 you will save on the fuel system to support 600rw.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old December 20th, 2009, 08:25 PM   #19
limited's Avatar
to me forged internals is just that
forged crank+forged rods+ forged pistons=forged internals
anything less is just upgraded
Old December 20th, 2009, 09:21 PM   #20
GTermi's Avatar
Do it right the first time and u have nothing to worry about. I have an aluminum block laying around too. i need to get rid of all that crap
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/146999-forged-internals.html
Forged Internals This thread Refback January 16th, 2010 04:31 AM
Forged Internals This thread Refback December 19th, 2009 06:28 PM
Threads Similar to: Forged Internals
Forged Internals? rickyleeitalia V6 Mustangs 4 November 5th, 2009 06:00 PM
Forged Internals leebunnyz 2005 - 2010 15 August 9th, 2007 10:26 AM
Forged internals ByPopularDemand V6 Mustangs 10 May 3rd, 2007 08:36 PM
Going to forged internals...what to get? ltsmash1200 99-04 7 April 22nd, 2007 11:08 PM
forged internals FastBack71 5.0 Mustangs 6 January 17th, 2007 07:58 PM
