2000 Gt Idle surge
Old December 20th, 2009, 03:52 AM   #1
polystang is on a distinguished road
2000 Gt Idle surge
When the car is idling with the trans in neutral and i am running the defroster, once and awhile I will hear the a/c clutch engade and at that same moment. My idle will jump from about 800 to 1200 rpms and then settle down to a smooth 800. That doesn't seem normal to me, or is it? Do I need a new a/c switch? Or is it the IAC starting to go out? When running striaght a/c it does not seem to surge or when running on just the heater vents. The car runs and idles perfect besides the ocasonal surgering during defrost mode.
Thanks
Old December 20th, 2009, 10:47 AM   #2
Dancing Naked In The Rain
mcqueen's Avatar
Try cleaning the IAC and MAF.
Old December 20th, 2009, 10:55 AM   #3
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
do you have the a/c on when running the heater? If so, i wonder if the a/c kicks on every now and then just to dry the heat out. Ive always heard people run the a/c with the heat just to take the moisture out of the heat.
Id say it seems close to normal to me.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old December 20th, 2009, 12:45 PM   #4
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
+1 on that
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old December 20th, 2009, 01:04 PM   #5
I Hate Convertibles...
2000 GT Vert
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
the heater doesnt use the ac pump but the defroster does
my car does the same thing but doesnt jump that high.... my car idles a little lower though. might just be normal, ive never really worried about it with my car.
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
Old December 20th, 2009, 03:36 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
You can turn the a/c on when you turn the heat on even when not using the defroster..^People do this to keep the moisture out of it.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old December 20th, 2009, 03:50 PM   #7
2000 GT Vert
i see what your sayin now baker... for some reason i didnt understand what you were sayin. but yeah he said he has his defrost on so the pump is engaging every once and a while. sounds pretty normal.
mods/pics
Old December 20th, 2009, 04:37 PM   #8
carnut59's Avatar
2001 gt
carnut59 is on a distinguished road
yes its normal. when the a/c comes on, it puts a load on the motor, so the iac raises the rpms to keep the motor from dieing. but it shouldnt go that high, only a few hundred rpms higher.
Old December 20th, 2009, 04:42 PM   #9
Barracuda is on a distinguished road
It's funny...all this idle talk (and mine is a pain in the arse w/ idiling and the cams...) and the funny part is, I remember the old 5.0's having the same querky idling. I remember putting an E303 cam and converting to MAF on my 87' (only way it would even consider idling). Then switch the A/C on...poof, would stall at a light. My father works on city crown vic's (police cars) and sez they often having idling problems and "shut-offs" after a hard run then stopping. weird
But, the reason I actually posted On the Ford trucks...even if A/C is NOT selected on heat mode...the only position on the knob that will NOT use the compressor is the Lower/Foot heat option. Even if u put the selector on basic upper vent, it will use the compressor...use to drive me nutz listening to that thing cycling in the cold on my old powerstroke superduty...wondering if the stangs are similar, my AC is gone so...i wouldn't know.
99' GT 5 Speed
Stroked w/All forged Internals
Vortech V2
Details in Garage
65' Plymouth Max Wedge Satellite (9.35 @ 154 all motor)
69' SuperBee- Stroked 500cu BB
05' Silverado/Duramax Mid 13's thanks to EFI LIVE
Threads Similar to: 2000 Gt Idle surge
Mustang idle surge and base idle reset 1slo5.0 5.0 Mustangs 47 July 26th, 2011 10:52 PM
Idle Surge Need Help!!! fofiddykid 96-98 10 November 17th, 2009 08:03 PM
Idle surge Tompo 5.0 Mustangs 2 October 26th, 2009 05:55 PM
Idle surge izze01 5.0 Mustangs 1 July 1st, 2007 01:32 AM
help idle surge! bambam88 General Tech 1 April 10th, 2007 11:26 PM
