2003 Mustang GT
14.03@100
Stock Piston Dish size
what is the stock piston dish size on the 99-04 GT's? More specifically 2003 (if that even makes a difference.)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
17?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
2003 Mustang GT
14.03@100
2001 Mustang GT
no it is 17cc dish so 42cc chamber volume
2003 Mustang GT
14.03@100
Really they're 42cc? I thought the were 44cc...lol
2001 Mustang GT
nope42...
2003 Mustang GT
14.03@100
1997 SVT COBRA
1996 Mustang V6
SOHC 4.6L, 5.4L,and 6.8L
1991 thru 1998 ----- 10.49cc dish 1999 thru 2000 ----- 18.10cc dish 2001 thru 2004 ----- 15.80cc dish DOHC 4.6L 1993 thru 1998 ----- 2.66cc dish 1999 thru 2002 ----- 4.54cc dish DOHC 5.4L 1998 thru 2004 ---- Flattop
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- Last edited by 330CubeGt; December 21st, 2009 at 12:22 AM. |
1997 SVT COBRA
1996 Mustang V6
Wrong...
NPI 52cc PI 44cc The heads share the same 1.752 Intake Valve but went from the 1.339 exhaust valve on the NPI head to a 1.417 on the PI heads
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
#10 | |
2003 Mustang GT
14.03@100
#11 | |
1997 SVT COBRA
1996 Mustang V6
Yessir and no problem.
2001 Mustang GT
1997 SVT COBRA
1996 Mustang V6
Also...
COMPRESSION SPECS PISTON HEADS HEADS DISH CC NPI PI Flatop 10:3:1 11:2:1 2.66cc 10:0:1 10:9:1 4.54cc 9:8:1 10:7:1 10.49cc 8:9:1 9:5:1 15.80cc 8:5:1 9:0:1 18.10cc 8:3:1 8:8:1 Kinda bunched up but you get the idea
2003 Mustang GT
14.03@100
One more thing having to do w/ compression ratios....How much would be too much compression? Was thinking of like a 11:1 NA setup bored 0.020 over and living in CA 91 is as high as I go.
2003 Mustang GT
14.03@100
Check Ford Racing. They don't lie.
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I guess then the 99-00 like boost a lil bit more?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
BYAHHHH!
2001 Mustang GT
13.874
If I was all N/A I would want a 12 or 13 compression
#18 | |
1997 SVT COBRA
1996 Mustang V6
Sean Hylands Heads might not be but stock heads are 44. Maybe you should call FORD RACING and tell them there heads at 42 and not 44
1997 SVT COBRA
1996 Mustang V6
Thats a little much for PUMP GAS...
2001 Mustang GT
He said they are 42 in his book. Not on hisbuilt engines.
Threads Similar to: Stock Piston Dish size
| Stroker Kit - Piston Size | jonnieguns | 2005 - 2010 | 13 | October 28th, 2009 04:54 PM |
| Piston size ? (.20 over) | Reloaded | 4V / SVT | 4 | June 12th, 2009 02:20 AM |
| piston size on mach? | 97S281 | 4V / SVT | 1 | December 22nd, 2008 06:57 PM |
| Will 2.02 Valves Clear Stock Piston? | 95StangSVT | 5.0 Mustangs | 1 | September 30th, 2006 12:37 PM |
