Lower control arms idea?? will it work
So I was under my car changing my fuel filter and was thinking, would it be a good idea if we weld a plate of metal to box them in and add some new bushings?? Any ideas or comments? Will doing this yield the same results as buying aftermarket control arms??
P.S I’m not doing this because im cheap, just throwing out some ideas. Thanks to all. |
Priest of the Car Gods
It'll definitely help, but it won't be as strong or light as an aftermarket unit. I'd do it if you're on a tight budget or if you have class restrictions that require retaining the stock arms.
Abyssinian of AX
'02 Saleen
19.34@42.259
I agree that it will work, but would be a lot of work to do correctly and probably add some bind to the rear suspension. This will lessen the flexability of the arms and the bushings will be asked to do all the work. Since you are into AX, I am very surprised you have not gone aftermarket arms anyway.
Jazzer ![]() PS. Pepe The Good Reverends post count... gittin' up there net boy
I am planning on getting the MM control arms, I just had this idea and wanted to run it by you guys since I haven’t seen anybody really discussing this topic. But thanks anyways, I didn’t really think it would work properly but what ever new ideas never hurt right…. lol
Thanks for the input |
#5 | |
Yea i your right, i does make sense.
Threads Similar to: Lower control arms idea?? will it work
| might have new lower control arms now what? | chaosstangman | 5.0 Mustangs | 5 | September 23rd, 2008 07:52 AM |
| Lower Control Arms | joeice14 | 2005 - 2010 | 8 | August 28th, 2008 08:52 AM |
| lower control arms? | Bluehorse | 2005 - 2010 | 28 | February 17th, 2008 12:10 AM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 11:45 AM |
| Steeda lower control arms (Trailing arms)? | kmjsmith | 2005 - 2010 | 6 | July 4th, 2007 04:59 PM |
