Winter project
Old December 23rd, 2009, 02:50 PM   #1
Evil Klown is on a distinguished road
Winter project
Now that winter is officially here I have parked my GT in the garage for the time being. I want to put down some cash into my car to get it ready for the races. My end goal is not built a drag racing car but to build a closed circuit car. I already made my mind up about what Forced Induction I plan on using, twin turbo, either from HP or Hellion. Since the stock block can handle around 450hp I plan on buying a short block and building it up from there. The problem I am having is choosing which block to go with. Should I stick with a 4.6L block or just go bigger? At the same time I want the car to drive good on the streets, although it is not my daily driver. When it comes to compression ratio, piston sizes, etc., I am not at all experienced. Any help would be appreciated.
Old December 23rd, 2009, 03:25 PM   #2
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
try searching it. every day 2 or more threads are started about block questions on turbo and supercharging motors.
MM + Cleavage member #22
Old December 23rd, 2009, 03:34 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Keep your stock iron 4.6L block man. No need to go bigger bore IMO. The 4.6l will rev faster which will be better to get out of turn with. And your will make more than enough power with a forged 4.6l. A 5.4l is more of a torque motor..from what I have learned on here atleast. Which torque is good but you dont need 600rwhp plus for closed circuit. YOu want snappy revs and quick spools to get into your powerband as quick as possible in the straights. I think a HP 57mm twin/single will be plenty for your application. Also I think HP is a little cheaper then Hellion and is a great turbo kit.
Old December 23rd, 2009, 05:10 PM   #4
well i was looking at some differnt rotating assys and they all have differnt size piston dishes, just cant figure out what to go with.
Old December 23rd, 2009, 11:12 PM   #5
mikestang's Avatar
2001 mustang gt
12.89@104
mikestang is an unknown quantity at this point
go with mmr stroker 950 rotating assembly. And a close friend of mine got there custom cams and he wont shut up about how good they are. They also have notched pistons if you choose a cam that requires them. And sometimes i wont shut up about how good there motor are either
linky:Modular Mustang Racing
go to products, then modular engine componants, and is almost to the bottom, rotating assemblies.
go to 2v parts, and about 3/4 ways down is the turbo cams and there is the heads in there too (trick flows and ported stockers).
Old December 23rd, 2009, 11:21 PM   #6
mikestang's Avatar
2001 mustang gt
12.89@104
pistons
18cc=9.5 to 1 compression
23cc=8.9 to 1
depending on how much boost will depend on piston, but my guess is 6 to 12psi, 9.5 to 1 comp. and 12psi and up go with the 23cc for 8.9 to 1. So basically the more boost you have the less c.r. is required. Hope this helped.
Old December 23rd, 2009, 11:36 PM   #7
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i just got 18cc dished Manley pistons in the mail today from MMR and their 4340 H beams. Modular Mustang Racing is who you need to look up!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old December 24th, 2009, 10:33 AM   #8
Dolbs4082's Avatar
2005 Mustang GT
Baker, you got some pistons now?! i guess that tells me if im pulling the pistons or not. u get them all new or used?
Threads Similar to: Winter project
Some pics of my winter project for the 88. ryans88gt 5.0 Mustangs 129 August 23rd, 2009 03:23 PM
some pics of the winter project e3sean 5.0 Mustangs 41 December 26th, 2008 02:32 PM
Some pics of my winter project for the 88. ryans88gt 5.0 Mustangs 0 December 18th, 2008 03:17 PM
my winter project SleeperStang88 V6 Mustangs 36 November 30th, 2008 09:57 PM
Winter Project Thread Aliate X The Clubhouse 2 March 9th, 2006 09:38 AM
