I wonder if anyone here had this happen to them.
So im cruising down the highway at 70mph, my cruise control is on and i look down and I see my odometer screen is blank. So i keep driving for about 10 more miles thinking it'll come back on. It doesn't. I get to my buddy's house, turn off the car and crank her back up. odometer works again. Then when leaving my buddy's place, i crank hr back up and the odometer starts flashing at me and goes blank.
i turn her off and crank up one more time and everythings fine. What just happen to me? |
2000 Roush Stage II #2568
dumb question here.. but did you have your dash lights turned down? I know I can turn my odometer off with out turning my dash lights all the way off.. is the reason I ask.
2000 Roush Stage II With Some Mods
This happen during the day in broad daylight. My headlights weren't on. No lights were one. That was the first thing i checked too. I checked my headlights and they were off.
Had the same thing happen in my 99 F150. No one seem to know what it could be and did not want to invest the money to look for the problem so i left it. It still racks up the miles. My guess would be and I did this but could not find any, look for lose wires under the dash.
Everything is snug as a bug under a rug. o_o
slow as sin....
i think it will be fine, dont know if it is messing anything up in your ride tho. just keep track of your miles and hopefully it wont be "miscounting" them.
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears Military Crew - AZ2(AW) Black Stang Member #6 |
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
^ reps 4 you!
2000 mustang GT
Mine did it when my speedometer quit working and I have traced all my wires down and still can't figure out what's wrong with it????
2000 GT comp cams, bbk cold air intake, bbk headers, bbk h-pipe, steeda underdrive pullys, NX 150 shot, All blacked out!!! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
+ what ajm said!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
YAWN!!! what??
ajm could you post the fix or maybe see if a sticky could be started? I have the same issue with my 99.
I dont have much time right now. I will make a more detailed one tomorrow but for the time being. Remove the cluster, its pretty straight forward. Start with the trim that goes around the top of the cluster, then the lower trim, etc. Once the cluster is out remove the bolts on the back of it. They should be 5.5mm. Youll see a small plug on the back of the board, unplug if then carefully separate the board from the cluster it just sits on some pins/pegs. On the bottom left youll see a cut out in the board. Right above it youll see 8 solder joints/pins a space then another joint/pin. Typically that single joint/pin on the right is the one with the issue. The easiest way to find which one it is forsure is to get a magnifying glass and check them all out. Itll be pretty obvious which one is bad. Then get a soldering iron hot as possible and touch it on the bad pin/joint just enough to slightly melt it then remove the soldering iron and problem is fixed.
Moderator
Dont worry about it bro, I went ahead and did it for you
![]() For those that are interested the write up is here http://www.moddedmustangs.com/forums...-lighting.html
![]() ![]() BUILD 2 IN PROGRESS |
Threads Similar to: I wonder if anyone here had this happen to them.
| Does this happen to you? | Arsenical | The Clubhouse | 15 | August 24th, 2009 05:05 PM |
| How often does this happen??? | BlackedOut04GT | 99-04 | 28 | April 28th, 2009 11:06 PM |
| what would happen if... | texas_mustang | 2005 - 2010 | 30 | April 13th, 2008 08:18 PM |
| So how does this happen??? | homebrewed | The Clubhouse | 15 | October 8th, 2007 12:45 PM |
| Anyone else ever had this happen? | Assassin_Dan | V6 Mustangs | 3 | October 7th, 2007 04:23 PM |
