quarter mile traction
Old February 23rd, 2007, 07:04 PM   #1
wagwjjr is on a distinguished road
I have a '04 Mustang GT convertible. I am completing a Kenne Bell 2.1 supercharger kit installation with big tube intake. According to kenne bell I will have 428 rwhp. I am looking for suggestions to aid in traction to improve quarter mile times and any recommendations on drag radials, size, mfg., etc. The car has a an automatic trans and 3.27 rear end. Any help or suggestions are appreciated.
Old February 23rd, 2007, 07:10 PM   #2
Timber's Avatar
Timber is on a distinguished road
First thing that comes to mind is subframe connectors. I wouldn't do a thing before that.
http://pic14.picturetrail.com/VOL534/828983/15628081/246397139.jpg
Old February 23rd, 2007, 07:40 PM   #3
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
+1, u definitely wanna get your drivetrain and suspension prepped and modded to handle that extra power better, you'd most likely break something soon runnin that power on all stock components, and I dont think those factory automatics are rated to handle that much hp
and I think you would want actual slicks instead of drag radials, imo
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old February 23rd, 2007, 08:36 PM   #4
according to kenne bell ford the stock components will do fine. It is a matter of a few other modifications for traction and learning to drive the car. Anyone got any other suggestions.
Old February 23rd, 2007, 08:45 PM   #5
Proud American
MustangMatt96GT's Avatar
Well the stiffer u make the car the better traction you will have. esspesally since its a convertible i would do some sub frame connectors and the maybe a 6 point cage, and maybe some lakewood 90/10 Struts and some adjustable shocks.
Old February 23rd, 2007, 08:52 PM   #6
yeah, u will need a roll cage before u can run on most tracks depending on what kind of times your car will do
90 Nissan 300zx
00' Yamaha YZF 600
Old February 23rd, 2007, 09:00 PM   #7
Proud American
And I apoligize, but its not a cage until it goes thru the dash so its acutally only a roll bar at that point but it will still help a bunch.
Old February 23rd, 2007, 09:08 PM   #8
mustangmatt, do u know what ET range a person has to start puttin roll bars or cages in their car at?
90 Nissan 300zx
00' Yamaha YZF 600
Old February 23rd, 2007, 09:19 PM   #9
At my local track it is below 10 sec. times. Kenne Bell swears to me that once I learn to drive the car in stock configuration I will get mid 12 times. They tell me that if I do a few small rear suspension changes I will be able to achieve mid to high elevens depending on what I do and they recommended going to lakewood for some products and a drag radial. That is why I was asking for help in the drag radial area and rear suspension. I don't want to hurt the road handling of the car. For another $700 dollars I can add an significant amount of horsepower but I need to be able to stick it to the ground. Any help or suggestions are appreciated. I will share all good or bad results. So far I have spent many thousands and very pleased with Kenne Bell. I just need a little more help. Please!
Old February 23rd, 2007, 09:20 PM   #10
I need to put this horsepower to the ground.
Old February 23rd, 2007, 09:29 PM   #11
Ive heard quite a few people recommend the Nitto 555 drag radials
90 Nissan 300zx
00' Yamaha YZF 600
Old February 23rd, 2007, 09:31 PM   #12
they're made out of a compound thats really heat sensitive and they're good for everyday street use too. Im gonna put a pair on the front of my car when the sumitomos wear down
90 Nissan 300zx
00' Yamaha YZF 600
Old February 23rd, 2007, 10:50 PM   #13
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
You should get ahold of someone at Lakewood for suspension parts. You can get things like tubular k-members, which will help take weight off of the front of the car. Also, upper and lower control arms, like mustangMatt said some 90/10 struts for the front to help push the nose up on launches, you can also get adjustable style that you can adjust at the track and still retain relatively nice street manners. Subframes are a great way to stiffen a chassis. If you're gonna do subframes then get the weld in kind, much better than the bolt on stuff. For a free mod at the track you can take off your front sway bar for better weight transfer, this would work even better with some front drag style adjustable suspensions parts. There's a ton of things, this is all that I could think of immediately.
Oh yeah, upgrade your axles and get some real slicks.
Old February 24th, 2007, 02:40 AM   #14
neckbonekat's Avatar
2005 Cadillac STS V8
http://rpmoutlet.com/musv8plates.htm
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old February 24th, 2007, 07:37 AM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
for daily driving the 555r is great, but if hooking up is the concern the m/t street radials would be a little better. i run the m/t e.t streets at the track and love them. i recommend control arms, torque box reinforcement, and subframe connectors at least. i put all that on mine and was a ble to tell a night and day difference in the way the car felt, feels so attatched to the road now. i also recommend a 31 spline w/4.10's out back, stall converter, and a good work through on the trans. as for size of tire; 275's on stock wheels and 315 on 10.5 aftermarket for radials, 26x10.5 or 26x11.5 on 15 inch rims as long as you have stock size brakes
Old February 24th, 2007, 07:54 AM   #16
Drgnracin72's Avatar
+10,000 the only thing i would change on his recomendations is going with a 3.73 gear instead of a 4.10. your gonna have a hard enough time hooking with 3.27 gears and itll be extremely difficult with 4.10
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old February 24th, 2007, 08:07 AM   #17
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
good point, but it is also personal preference. my buddy had 4.10's in his with 8psi and a couple of other things and that is what he wanted, it worked great, but i think that i would of went 3.73. like i said though thats all in preferences.
Old February 24th, 2007, 09:08 AM   #18
i just figure with as much torque as the kb puts out downlow that it would even just overwhelm some of the good drs
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old February 24th, 2007, 09:10 AM   #19
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
didn't the verts come with subframe connectors from the factory?
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old February 24th, 2007, 12:49 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Put the biggest slicks or the biggest drag radials you can fit on the car and you will have traction.
Threads Similar to: quarter mile traction
quarter mile? brianstang 96-98 17 April 8th, 2009 12:13 AM
quarter mile time 96gtstang&V6 V6 Mustangs 28 September 25th, 2007 03:44 PM
how mush does 3.73 take of quarter mile Cantbeatblack 99-04 7 July 24th, 2007 05:01 PM
06 gt quarter mile badacestang 2005 - 2010 12 June 14th, 2007 08:37 PM
quarter mile times notsoslo5.0 5.0 Mustangs 11 January 24th, 2007 09:16 PM
