13.82@100.26
Scraping Sound?
I had to take my calipers off the other day, and reinstalled them. Torqued every bolt and is tight. But the car is making a scraping sound as if the shoes aren't tight like before pumping the brakes. But is like this driving. Sounds HORRIBLE. I just took them apart and reset them, but still does the same thing!
Idk, shoes look pretty worn, but may be the guide pins in the side of the caliper. Any input guys?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Check the caliper slides....The sliding things on the bracket that the caliper bolts thread into. The rear ones have a thing for getting stuck. You may not notice it/it may not get worse until you remove the caliper or put new pads on, then reinstall.
48.47@ 12.58
shoes?
This is for your 02 right? My advice is to lube everything back up.
Also, this may sound weird but... Make sure the dust shield isn't bent and touching the back of the rotor. Mine was bent when I was installing struts and was making a scraping sound. If it is just bend it back to it's normal position.
Mods: UD pullies, shift kit, Super 40's, 75mm TB, C&L Plenum, Diablo Tuner, K&N FIPK, 4.10's, Progress springs, UPR adjustable LCA's and UCA's, UPR CC plates, kyb shocks/struts, steeda bumpsteer kit, x2 ball joints, shorter endlinks, poly iso's |
48.47@ 12.58
not weird at all. You make a very good point man.
I have seen that before.
2001 gt
that or the hardware the pads sit in touching the rotor.
#7 | |
13.82@100.26
Weird. My dad bent it on accident when he handed me some tools.
#8 | |
Seriously I'm glad u got it figured it out.
#9 | |
13.82@100.26
#10 | |
Threads Similar to: Scraping Sound?
| SCRAPING THE COAST | droppedbass87 | General Tech | 7 | May 17th, 2007 01:10 AM |
| SCRAPING THE COAST | droppedbass87 | 94-95 | 2 | May 16th, 2007 03:44 PM |
| SCRAPING THE COAST | droppedbass87 | General Tech | 0 | May 16th, 2007 01:53 AM |
| SCRAPING THE COAST | droppedbass87 | 5.0 Mustangs | 0 | May 16th, 2007 01:52 AM |
| SCRAPING THE COAST | droppedbass87 | 5.0 Mustangs | 0 | May 16th, 2007 01:51 AM |
