Just finished Head and Cam install, do i need a new tune?
Old February 24th, 2007, 11:12 PM   #1
MySallyMI is on a distinguished road
I just got done, and notice my low RPM power isnt what it used to be, i know this is a given because i have my heads and cams setup for higher RPMS (stage 2 comp cams, 30lb/hr Steeda injectors & stage 3 Patriot heads). But im somewhat curious, do you guys think i need to get it Dynotuned? Also i think i might be starving the engine of air, i have stock throttle body on right now with a BBK 75mm CAI, and stock MAF. The heads move so much air it sounds like ive got a blower, that or its sucking in so much air the whistle coming from the engine bay is the maximum allowed with the the stock TB and MAF. Any opinions? My powerband is way high. Im thinking i need a new intake, TB and MAF along with a dyno tune. Eventually some Forged Pistons, and rods.
Old February 25th, 2007, 08:38 AM   #2
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
yes you need a tune after a cam and head swap.
Old February 25th, 2007, 08:38 AM   #3
yes you need a tune after a cam and head swap. also a 70 or 75 mm tb and plenum bould be wise before you go get your tune.
Old February 25th, 2007, 08:47 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
air movement is everything in a 4.6, for best perfomance you need the best to go with it. accufab if possible but any after market t/b and plenum combo will ok, do p&p work if possible. as for the maf, not really necessary but up to you, i recommend a c&l maf at least. ive got a c&l maf and inlet tube and it is awsome! with the c&l maf no retunning is necessary for the maf, but with the bigger injectors, cams, and heads the flow rate is so much higher a dyno tune is needed for sure.
Old February 25th, 2007, 01:52 PM   #5
Re: Just finished Head and Cam install, do i need a new tune
Ok is it safe to drive it around as it? How much do dyno tunes usually cost? ive never got one before but have been told $300-$500 is the usual.
Old February 25th, 2007, 02:57 PM   #6
F4iMerlin's Avatar
F4iMerlin is on a distinguished road
Thats about right, my local shop charges around $700 to dyno tune, and that includes an XCal 2. It should be ok to drive, but performance and gas consumption will suffer. I wouldnt get on it too hard until it is tuned either.
Old February 25th, 2007, 06:08 PM   #7
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
Get a SCT XCAL2 or a SCT Eliminator Chip...Then have them tune on that...
The dyno tune cost all depends on how much time it takes to tune it...It could take an hour or it could take 4 or more...
Facebook
Google+
Old February 25th, 2007, 07:19 PM   #8
F4iMerlin's Avatar
My local shop charges the $700 as a flat rate regardless of how long it take to dyno. They also warranty the tune and will adjust for free if the car runs poorly down the road.
Dyno tuning is the BEST way to get a tune. Chipping a car, or just making changes with a handheld unit without a dyno will only get you so far, and may not work for you at all. Even Kenne Bell tunes (they come on a chip) are hit or miss, every car is different.
I know a guy who installed the KB S/C, threw their chip in, and the car would barely run. Dyno tuning matches the tune to your car and modifications 100%. After dropping the $$ for the cams and heads, it only makes sense to top off the install with a proper dyno tune for the very best performance.
Old February 25th, 2007, 07:41 PM   #9
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
The chip they burn do suck IMHO...
I was talking about having the person doing the dyno tune brun the tune on the chip...Most shops can tune the car and then burn it on a chip...
Thats kinda outrageous to charge $700 for a tune...
Where are you located?
I mean that is more then what Tim @ MPH charges and he is like the tuning mesiah...
Facebook
Google+
Old February 25th, 2007, 10:11 PM   #10
F4iMerlin's Avatar
California.....where everything is known to cause cancer in the state, and there is a mandatory mark up of 75% on all normal pricing of everything
Old February 26th, 2007, 04:34 AM   #11
you will be fine driving it but just dont go to WOT. my tuner charges 200 if you already have the xcal
Old February 26th, 2007, 02:33 PM   #12
Alright found a place right down the street that runs out of a napa, $125/hr and have scheduled it for saturday at 1pm CST, ill post my dyno slip when i get it done. The guy says he should have it in an hour or two tops, i cant wait!
Old February 27th, 2007, 02:54 AM   #13
neckbonekat's Avatar
2005 Cadillac STS V8
Yeah, one hour one minute so they can charge you for the extra hour. LOL
ITEMS FOR SALE!
4.10 GEARS + BEARING KIT
Old February 27th, 2007, 12:21 PM   #14
Drgnracin72's Avatar
600-700 is pretty normal for tuning, well nromal for the guys who really know what they are doing. your small shops that dont know everyhting about the cars will charge less but someone who really knows there stuff will charge 125-150 an hour
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old February 27th, 2007, 12:38 PM   #15
i would rather pay more and have someone get the tune right than pay less and get a grenade under my hood.
Old February 27th, 2007, 02:32 PM   #16
x8921375086215873436598714456018750981570841765784 136982376589734658716325897134659843756
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Old February 27th, 2007, 04:05 PM   #17
Ahhhh, grenades are more exciting. Gives that live by the seat of your pants feel. LOL
ITEMS FOR SALE!
Old February 28th, 2007, 03:51 AM   #18
and an empty pocket
Old February 28th, 2007, 10:21 AM   #19
RLY SRS
ChrisJ's Avatar
iTrader: 9 reviews
$650 is centri supercharger install and dynoe time @ MPH...
Most places that I know of charge $75 - $100 per hour...
Facebook
Google+
Old February 28th, 2007, 10:48 AM   #20
mine is a flat rate of $200 for a supercharged car.
Threads Similar to: Just finished Head and Cam install, do i need a new tune?
Looking 4 shop dyno tune and install supercharger in LA AREA Lord Chasnov Southwest 7 January 12th, 2008 03:16 AM
PROJECTOR HEAD LIGHTS INSTALL!!! 04gt 99-04 7 October 10th, 2007 11:14 PM
head unit install (yes another 1) BlackIce Audio/Video 4 February 22nd, 2007 05:34 PM
Need Help With Head Unit Install Teggy_Boy Audio/Video 1 January 18th, 2007 07:54 PM
Gtrac suspension Install...finished!! StuTheMusicEngineer 99-04 7 January 4th, 2007 01:18 PM
