frozen caliper slide pin?
Old January 7th, 2010, 11:36 PM   #1
Slower than your ability to post a question that can easily be found via search
GidEup is on a distinguished road
One of the two rear caliper pins is sticking; the pins that the caliper sides left to right on. The grease seems to solidify and then the pin starts stick and the brake starts to drag. Last time I regreased both pins, I could barely remove the pin that was sticking.
What I've tried:
-regreasing with regular grease; solves the problem for awhile but then goes bad.
-using higher temp grease; lasts longer but still happens.
-checking the pin for bends etc; its straight and dent free.
-dug as much of the solidified grease out of the pin pocket as possible and replaced.
-swapping the top and bottom pins; still happens.
Suggestions (short of replacing everything)?
I'd upgrade to something like willwood or brembo but I cant afford that option at this point in time.
Old January 7th, 2010, 11:56 PM   #2
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
take it all apart and clean out the slide bore with a cue tip or stuff a paper towel into it with a screwdriver and clean it out that way. start all over with the hi-temp grease. it only takes one little grain of sand to make it hang up.
True blue crew founder/member #1 Newest Project: 1996 F250 XL PSD SCLB ZF5...79k stock miles Rollin' Coal Crew Founder
Old January 8th, 2010, 12:03 AM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
what are you greasing them with?? If its regular grease that could be your problem. Try some caliper slide grease
Old January 8th, 2010, 12:08 AM   #4
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
use some of the motorcraft die electric caliper grease...what we use at the shop and works fine
405rwhp on 8psi
Kurgan tuned
Unicorn Club Member #7
Old January 8th, 2010, 12:29 AM   #5
1st attempt was with some ford/merc multi purpose by valvoline
2nd was with lucas x-tra heavy duty grease.
(only choices I had at the local parts store)
wishihada5.0-thanks i'll give that a try.
f8l Gt- any suggestions for brand etc? I may have to mail order the stuff.
mrbigjeep - happen to have a sku handy?
Old January 26th, 2010, 04:50 PM   #6
slonlow2000's Avatar
01 Mustang GT
slonlow2000 is on a distinguished road
I'm gonna bump this, even tho its a little old. I finally got my car out of the garage today, its been sitting through the cold crappy weather. It was finally sunny today and with more bad weather coming tomorrow I figured it needs to be driven. Anyways when I got back from a 30 min easy drive I could smell my front pass side brake had been dragging and was hot. I've already cleaned them out and regreased before but just used some lithium grease, and I guess that wasnt good enough.
So if you guys could post up what kinda grease yours using and where to buy that would be awesome.
04 GT DSG - Lowered on H&R springs, Maximum Motorsports C/C Plates, BBK O/R x-pipe, MAC Catback
2004 Chevy Silverado Z71
01 GT-Lowered, UPR CAI, Mach 1 Chin Spoiler, 18" Bullitts, Magnaflow Magnapack Catback - SOLD
02 Xtreme Blazer, Bagged - SOLD
Old September 1st, 2010, 06:12 PM   #7
sikorski04 is on a distinguished road
stuck caliper pin
My rear brakes experienced uneven wear on the left side. It was so bad that the inner brake pad eventually fell out when driving.
After investigating the problem during a brake job, I found it was due to a caliper pin no compressing. I tried liquid wrench, twisting it out, hammering it out, and many other combos.
After an hour of messing around, I took the bracket to a local mechanic and he was familiar with these issues. Torched it red hot and pulled the pin out. He didn't want to charge me but i gave him 10 bucks for the help. Was able to reuse it and not have to buy another bracket.
Old September 1st, 2010, 10:17 PM   #8
Who is John Galt?
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant futureEagle2000GT has a brilliant future
Sometimes you have to give up and get a new caliper bracket with new pins. I couldn't beat the pins loose on one of my rear caliper brackets with a hammer. I gave up and bought new parts. I haven't had a problem since.
P.S. Every parts store I've ever been in recently sells caliper lube.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
Mods listed in Garage. http://www.moddedmustangs.com/forums...-member-11329/
Originally Posted by JayC View Post
The one good thing about beating a dead horse is it won't get up and run away!
Old September 6th, 2010, 05:47 PM   #9
1_nice_03_gt's Avatar
2003 ford mustang gt
13.86 @ 100mph
1_nice_03_gt is a jewel in the rough1_nice_03_gt is a jewel in the rough1_nice_03_gt is a jewel in the rough1_nice_03_gt is a jewel in the rough
iTrader: 13 reviews
so is that y it wud make a squiking sound from the left side of my car?
Old September 6th, 2010, 06:27 PM   #10
burner79's Avatar
02 GT
burner79 is on a distinguished road
Just get new pins from autozone. The kit for left and right is about $18 and includes bolts and everything.
I thought this was my only problem, but it turned out to be a warped rotor.
http://www.moddedmustangs.com/forums/signaturepics/sigpic34131_2.gif
Threads Similar to: frozen caliper slide pin?
possibly a Frozen rear caliper? 93HatchsBFF 99-04 9 October 2nd, 2009 09:46 AM
2002 Caliper Slide Bolts. einod V6 Mustangs 2 April 18th, 2009 12:11 AM
little slide show of the hockey team thorpedo26 The Clubhouse 2 October 29th, 2008 11:06 PM
60 Foot Backyard Slide TurboLX The Clubhouse 4 November 1st, 2007 07:34 PM
are 4 pin vs 5 pin relays the same OTreborO 5.0 Mustangs 3 August 21st, 2006 01:24 AM
